Old 04-25-2010, 01:15 AM   #18961
AGNO's Avatar
Default Setup 17.5
The track can be seen here:
http://www.laurenziana.it/modellismo/
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-25-2010, 07:50 PM   #18962
warnos's Avatar
Default MIP CVD or DCJ or Version 2 Drive Shaft
Hi
Has anyone compared the MIP CVD's v's DCJ..
I have just snapped the black part of the MIP CVD (part#80824) which caused the pin to elongate the hole on the drive shaft.. I am finding it hard to locate these MIP CVD's now.. and HB won't sell outside the US..
So I have purchased a couple of DCJ's I am just concered that they are not as smooth as the MIP CVD's.. has anyone got some opinions on the DCJ's when compared to the other types of drive shafts for the Cyclone.. also how durable are they?? better then the MIP or not as durable as the Version 2 HD drive shafts??
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 04-25-2010, 08:03 PM   #18963
Hi, I have used DCJ for about 6 months and I can say they stay smooth and last longer than the steel drive shafts. I normally run 11.5T and 10.5T, and a pair would last at least 2-3 months. Just remember to swap them left/right every 1-2 weeks. I have not tried MIP, but I suspect DCJ will probably last longer because there are 2 joints so the angles of each join is only half of the regular UJ when you turn the wheels. Furthermore they are completely made of steel, not alum like the MIPs.
Originally Posted by warnos View Post
Hi
Cheers
andrew188 is offline   Reply With Quote
Old 04-27-2010, 02:06 AM   #18964
tomracing's Avatar
Originally Posted by cosmo1974 View Post
Hi Korey & Co,
(1) My setup is similar to Hara TITC 2009 and has morphed a bit using the Asphalt Base Setup by Phil Chambers (cut top and rear decks, stood up rear shock, & more recently the 3.5deg rear toe). The primary changes were made to fix a problem with the rear end breaking loose. The outdoor asphalt track is quite large, with an 80m front straight (photo attached).
(2) At my latest race meet, one of the other drivers marshalling (has an xray or two, as does most other drivers for that matter) indicated that my chassis was rolling a lot in the rear. This got me to thinking, as the underside, outside edges of my chassis have been scrapped & worn quite a bit (lots of roll?).
(3) Are other drivers (Team Drivers) who are running on asphalt, having the same wear on the underside, outside edges of the chassis ??
Thanks in advance
I'm a bit surprised no response to this has come. last weekend i also saw some strange rolling motions on my cyclone after laying in the rear shocks a bit.
can you write down your full setup in a sheet as you run it including the weight your running at. talking to another cyclone user we discussed the possibility of the lower weight then the cyclone was designed for as possible upset factor.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 04-27-2010, 02:41 AM   #18965
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Hi,
Recent setups as follows.
Latest change has a more stable rear end.
Any insights appreciated.
** THIS SETUP USED UNTIL RECENTLY **
Drive:________F=SpoolV3 + R=Diff
Ackermann:____F=2.0
Shock Spring:__F=Silver + R=Silver
Shock Oil:_____F=AE60 + R=AE60 + FullRebound + Foam
Shock Piston:___F=2hole_1.2mm + R=2hole_1.2mm
Shock Position:__F=3+1 + R=2+2
Camber Link:____F=2.0 + R=1.5 + F=Long + R=Long
Camber:_______F=2.20 + R=1.75
Toe Block:______F=1.5 + R=3.0
Toe:__________F=neg_1.0
Block Shims:____F=1.5_1.5 + R=1.5_1.5
Wheelbase:_____F=2.0_0.5 + R=2.0_0.5 + R(hub)=2.0_0.5
Hex Hub:_______F=std + R=std
Swaybar:_______F=1.4 + R=1.2
Swaybar Gap:___F=2.0 + R=1.5
Downstops:_____F=8.0 + R=8.0
Ride Height:____F=5.2 + R=5.5
Middle Deck:___Cut=yes
Top Deck:______FrontPosts=no + Cut=yes
Miscellaneous:___BodyType=Mazda6 + Weight=approx 1425gms
Tires:_________F=S36AF + R=S36AF
Electronics:____TeamEpic2(5degs) + TekinRS(444K612K21402) + 81/23 (7.60) + Fan x2
#Note:_Downstops measured from centre of hinge pin (shaft) at end of sus arm.
#Note:_Downstops (centre of axle) = Downstops (hinge_pin) + 14.5mm (* Check camber first *)
** FOLLOWING CHANGE WAS USED LAST RACE MEET **
Ackermann:____F=2.0
Shock Spring:__F= Silver + R=Silver
Shock Position:__F=3+1 + R=5+2
Camber:_______ F=1.5 + R=1.5 + Fgain=0.6 + Rgain=0.7 + Ffull-lock=2.0_0.0
Toe Block:_____F=1.5 + R=2.5 + R(out)=1.0 (* Rtotal=3.5 *)
Toe:__________F=pos_1.0
Downstops:_____F=10.0 + R=9.5
Ride Height:____F=5.5 + R=6.0
Electronics:____TeamEpic2(6degs) + TekinRS(504K713K01202) + 81/23 (7.60) + Fan x2
END.
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
Last edited by cosmo1974; 04-28-2010 at 02:23 AM. Reason: Added Motor and TekinRS settings.
cosmo1974 is offline   Reply With Quote
Old 04-27-2010, 06:53 PM   #18966
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Default pinion
So a 26tooth pinion is a good start for a 17.5 motor? I have a race this weekend and finally getting the car built, can wait to get back into onroad!! Let me know about my question thanks
Outtacontrol58 is offline   Reply With Quote
Old 04-27-2010, 06:57 PM   #18967
EJ20's Avatar
Hi,
It's really depends on what Motor, ESC, Indoor or Outdoor? Let us know.
Thanks!
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 04-27-2010, 07:01 PM   #18968
CycloneS66six's Avatar
i will be racing on an outdoor track that is small/medium in largeness in florida using a speed passion lpf and an epic duo 17.5 motor and a cyclone s. what is a recommended fdr to have to use that with the new beta 231 software? would a 5.54 or a 8.3 be acceptable to use without overheating
DREW FOREST-Team Terribles R/C Racing Team Member
Team Epic Duo 17.5T Brushless Motor + Speed Passion LPF ESC
Dynamite 4200 Lithium-Polymer Battery
Spektrum Receiver + Servo + DX3E Controller
Hot Bodies Cyclone S + Associated TC4
CycloneS66six is offline   Reply With Quote
Old 04-27-2010, 07:03 PM   #18969
EJ20's Avatar
Default ROAR Region 12
Congrats Hiro / Team HB at ROAR Region 12.
Old 04-27-2010, 07:05 PM   #18970
mlight13's Avatar
Trader Rating: 40 (100%+)
I have almost the same setup as you and I just ran software 230 last weekend with a 6.5 FDR and it is too low for my small/medium parking lot track. My motor went up to 200*. I geared it to 7.05 and it's good now...fast and temps around 140*. You will either be too overgeared or too undergeared. Spend a few bucks on gears instead of having to spend more on a new motor.
Mark
mlight13 is offline   Reply With Quote
Old 04-27-2010, 07:11 PM   #18971
ok well i have to download the software first from a guy at my track but i have the gears to get a 7.3 but they wont interlock inside the car cuz theyre too small
Old 04-27-2010, 09:23 PM   #18972
Thank you George!!
Hi-LowBlow is offline   Reply With Quote
Old 04-27-2010, 09:58 PM   #18973
tha Beast's Avatar
Trader Rating: 100 (99%+)
Default i NEED HELP WITH GEARING
hi guys in running on a large asphalt here is a link http://www.mikes-hobbyshop.com/OnRoadTrack.html
anyway im going to run 13.5 on a TC not the older version so im looking to get some tips on gearing can any of you guys help me out with a starting point before i go buy a bunch of gears/pinions. anything will help hopefully some of you pro guys can hook a brotha up thanks in advance
tha Beast is offline   Reply With Quote
Old 04-28-2010, 05:42 AM   #18974
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Hey guys.
just wanting to know who has the 0 deg suspension blocks instock? dont mind ordering from US or asia.
cheers
mild seven is online now   Reply With Quote
Old 04-28-2010, 06:52 AM   #18975
EJ20's Avatar
Originally Posted by mild seven View Post
Hey guys.
cheers
https://www.ssl-stormerhobbies.com/c...ns&pn=HPI75156
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
