Old 04-12-2010, 12:51 PM   #18916
SpidarX's Avatar
Originally Posted by Outtacontrol58 View Post
Huge Question, I just got the TC, my Lipo battery does not fit the chassis because its hitting the purple aluminum piece on the other side of the motor mount (sorry i forgot the name). do i just shave it to where it wont fit or will this mess the chassis up because it connects to the upper deck. THanks and i cannot wait to run it! I am running the 40C SMC lipo
Most people just shave off about 2mm from the underside of the mount.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 04-12-2010, 03:38 PM   #18917
cherry2blost's Avatar
+1 just sand it down by hand don't use a dremel too messy
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 04-12-2010, 03:42 PM   #18918
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by tomracing View Post
wheel rate has nothing to do with weight transfer.
wheel rate is like a spring rate but transfered to the wheel center.
so if it tells you the force per wheel travel.
the total weight transfer is calculated as
weight*lateral acceleration*cg height / track width
so reducing the track width increases weight transfer
Thanks.
Do you have a reference to the formulae, and how it is derived
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 04-12-2010, 05:43 PM   #18919
Originally Posted by charlie_b View Post
Sounds like a droop or maybe even a spring tension issue. Check both and see whether they are even from left to right.
Charlie, When you say spring tension you are talking about ride height correct?
Thanks for your feedback.TJ
Touring Jr. is offline   Reply With Quote
Old 04-12-2010, 08:21 PM   #18920
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Thanks for the reply! I will get to sanding
Outtacontrol58 is offline   Reply With Quote
Old 04-13-2010, 12:42 AM   #18921
tomracing's Avatar
Originally Posted by cosmo1974 View Post
Thanks.
okay small physics summary:
basically it is the reaction in the outside tire to the lateral acceleration on the mass at height.
not taking into account gravity only lateral acceleration we take the sum of the moments about the inside tire central contact point.
sumM_insidewheel=0=mass*lat_a*cg_height - Fouterwheel*trackwidth
so
Fdue to lateral G= mass*lat_a*cg_height/trackwidth
to get it into mass units do F/gravity
to get the total weight on the outside wheel you would start like this:
sumM_insidewheel=0=mass*lat_a*cg_height - Fouterwheel*trackwidth + mass*gravity*0.5wheelbase
and bring out the Fouterwheel again.
and finding the inside wheelload would be sumF_vertical=0=Foutside+Finside-mass*gravity
Finside=mass*gravity-Foutside
hope that makes it a bit clearer
to get these kind of things easier may i also advise either of these books
-competition car suspension by allan staniforth (simplified and easy to read)
-race car vehicle dynamics by milliken&milliken (more complicated but the best book though not in SI-units)
-fundamentals of vehicle dynamics by thomas gillespie (complete basics)
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 04-13-2010, 01:53 AM   #18922
smk
Default Cyclone TC :D
Hi,
Just got my cyclone TC world edition and I want to prepare it for a race on saturday. Could you please let me know what should I take into consideration when building the KIT? Should I do something different , is there any tip you can give me when building the car?
Also , I will use a 13.5 motor , and I want to gear it to 4 - 4,5 , could you please let me know what Spur/pinion will fit? Also will the 48p spur/pinion will fit , and if yes , what combination of spur/pinion will I have to have to gear it at 4 - 4,5.
smk is offline   Reply With Quote
Old 04-13-2010, 02:22 AM   #18923
cosmo1974's Avatar
so
My basic issue is now resolved, that is, the derivation of :
-- Fdue to lateral G= mass*lat_a*cg_height/trackwidth
I also did some google searches to get a different perspective on things (some have diagrams which always helps).
I will look into your references as well.
All good bedtime reading.
Old 04-13-2010, 07:47 AM   #18924
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Originally Posted by smk View Post
Hi,
Hello man, you must look into GEARCHART.COM ... i did a calculation that shows your alternatives on the FDR you need, but you can go to gearchart.com and try another combinations :
cya !!!
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-13-2010, 11:31 PM   #18925
tha Beast's Avatar
Trader Rating: 100 (99%+)
Hi,
46 pinion and 100 spur(64 pitch) that gives you 4.71 ratio and 42.68 rolloutgood combo for me
tha Beast is offline   Reply With Quote
Old 04-13-2010, 11:34 PM   #18926
tha Beast's Avatar
Default asphalt setup????
besides Hara's setup are there any of you out there with a BADA$$ asphalt setup i can borrow i run on a med. to high grip track and i need some advice. ive looked through about 100pages on this thread and all i seem to find are carpet setups and my eyes hurt from reading so much can someone hook a brotha up????
Old 04-14-2010, 05:55 AM   #18927
whoopass's Avatar
i thought the ratio for the cyclone WCE in the manual is 2.4375?
isn't it large pulley divided by small pulley?
39/16=2.4375
whoopass is offline   Reply With Quote
Old 04-14-2010, 06:06 AM   #18928
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Cyclone TC came with 18T pulley.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 04-14-2010, 03:06 PM   #18929
GasGod's Avatar
I've heard rumors of a new kit--True??
Was gonna redo mine for this year but if there is a new kit in the works--
Parts are a pita to get and if I have to wait for parts I might spring for a new car if it's true.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-14-2010, 06:52 PM   #18930
RLMW VQ's Avatar
its true but i think its going to be a few months till its out
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
