Old 04-07-2010, 01:26 AM   #18901
Korey Harbke's Avatar
Originally Posted by cosmo1974 View Post
Hi,
When NARROWING the rear track width (thin hexes), the Hudy setup book indicates following:
· Increases grip at corner exit (* I'm assuming this means rear grip *)
· Increases high-speed understeer.
· Increases front grip in hairpin turns.
I think Korey mentioned the same thing about Hara's RROC 2008 setup (ie: thin rear hexes, 72044, for more rear end grip).
REF: Hot Bodies Cyclone
If D2 gets less (and nothing else is changed), Wheel Rate gets larger:
---- Wheel rate = spring rate * (D1/D2)˛ * sin (a)
Not sure about roll centre change.
Why does narrowing the rear track width INCREASE grip at corner exit ??
Thanks in advance
Track width is interesting. In my experience, narrower track widths usually give more traction. The problem is when you exceed the limit of traction, the car is really unstable. With a wider car, I typically find there is less overall grip. BUT when you go beyond the limits of the tires, the car just slides progressively. It's not an abrupt snap. It's a give and take type of situation. It's something you just have to try. Luckily its easy to change.
I sometimes go up to the driver stand, make a few laps, pull in and make a small change. I usually carry a few tools in my pocket just in case I just want to make a small change.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-10-2010, 10:32 AM   #18902
Robert G's Avatar
i have a painted body for sale for a cyclone tc if anyone is interested thanks
cyclone tc painted body
Robert G is offline   Reply With Quote
Old 04-10-2010, 07:32 PM   #18903
SpeedySST's Avatar
Default Question about FDR
I just spent the last half hour looking for a good FDR for a low-med traction outdoor parking lot track, medium size, using a SPX (for now) and an Ion 13.5 motor. I was unsuccessful. Please help!
SpeedySST is offline   Reply With Quote
Old 04-10-2010, 08:42 PM   #18904
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Predating the Tekin era, 13.5's were geared between a 4.0 to 4.7.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 04-10-2010, 09:08 PM   #18905
SpeedySST's Avatar
As soon as I can get one, I plan on getting the Speed Passion 2.1 so what would the FDR be? Thank you very much!
Mark
Old 04-10-2010, 10:01 PM   #18906
05forfun's Avatar
Trader Rating: 81 (100%+)
When narrowing the track width,the car will have more lateral weight transfer in either direction, so with more weight being transferred to one side, that side will have more normal load on the tire, which means more traction. But as Korey stated, the car is easier to exceed the limit and then has prompt slide
Hi,
Thanks in advance
05forfun is offline   Reply With Quote
Old 04-11-2010, 12:15 AM   #18907
Super Moderator
charlie_b's Avatar
Mark
With the SP stuff, according to your track, 6.9- 7.6. This will also depend on the many combos you can run with the 2.1.
Old 04-11-2010, 12:55 AM   #18908
SpeedySST's Avatar
Thanks guys! I appreciate the help especially considering the outdoor season is upon us!
Old 04-12-2010, 07:14 AM   #18909
Hey Guys, Just raced @ our local club yesterday and still working out some bugs. Car pulls right under hard acceleration and I cant really find any problems in set up or chassis tweak. Could the steering servo be the problem? I will admit I am running a cheap hk metal gear unit. Is the torque of the brushless motor creating torque steer?
Touring Jr. is offline   Reply With Quote
Old 04-12-2010, 07:48 AM   #18910
Super Moderator
charlie_b's Avatar
Sounds like a droop or maybe even a spring tension issue. Check both and see whether they are even from left to right.
Old 04-12-2010, 08:08 AM   #18911
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
But why is there more lateral weight transfer
This is the thing I am having trouble visualising
As mentioned before:
This seems to indicate the opposite, so there are other "forces" at work here which I need some educating on
For example, is the Roll Centre getting LOWER, and the resultant force (increased leverage) outweighing the INCREASED Wheel Rate (I just dont know)
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 04-12-2010, 08:54 AM   #18912
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
You don’t really get torque steered on a belt driven cars. First thing you want to check is a set screw on your pulley and spur adapter. Makes sure they are tight.
Are you running diff front and rear or rear diff and spool up front? Check the diff makes it doesn’t slip under heavy acceleration. If you are running one-way makes sure it’s still a “One-Way” not two-way.
Normally when one of those above happened to me the car generally pulled to the left though. I have had a front belt flipped on me one time and it pulled to the left. Not sure what would caused it to pull to the right.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 04-12-2010, 09:22 AM   #18913
Thanks Komkit,
I am running front spool and rear diff. Rear seams to be smooth and tight I think? When I hold the tires and push It with my thumb I cant turn it. But if a loose rear diff causes a pull( or push per say ) to the left I guess that doesnt apply here anyway?
Old 04-12-2010, 10:13 AM   #18914
tomracing's Avatar
wheel rate has nothing to do with weight transfer.
wheel rate is like a spring rate but transfered to the wheel center.
so if it tells you the force per wheel travel.
the total weight transfer is calculated as
weight*lateral acceleration*cg height / track width
so reducing the track width increases weight transfer
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 04-12-2010, 11:58 AM   #18915
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Exclamation LIPO Fit????
Huge Question, I just got the TC, my Lipo battery does not fit the chassis because its hitting the purple aluminum piece on the other side of the motor mount (sorry i forgot the name). do i just shave it to where it wont fit or will this mess the chassis up because it connects to the upper deck. THanks and i cannot wait to run it! I am running the 40C SMC lipo
Outtacontrol58 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
