Hot Bodies Cyclone
It is translucent and has fibre reinforcements running along its length.
You can purchase 24mm x 55m roles.
Cheers
Trader Rating: 25 (100%+)
HEY---where can I find the spool for the Cyclone S?? Everyone seems to be out of it??
T
T
does anyone know it the stock rear diff outdrives( the plastic ones) will hold up to a 5.5t brushless i seem to break at least one those Delrin cup joints every weekend and i dont wanna spend 10.00 bucks all the time or can someone give me a solution so i dont keep breaking them.... also does anyone know if on the DJC shaft can it be replaced (the dogbone part) id hate to have to buy one if i happen to break just the shaft
-Korey
parts for sale
Hi, I ve got some spares that I am wanting to sell: all prices are Uk pound and based on Uk postage, but if you want some thing sent some where else get in touch:::
PM me if wnat to make an offer or need more info,
cheers
mi
cheers
mi
Super Moderator
Guys, please put all your for sale stuff on the for sale thread. This thread is for information purposes and not an rc swapmeet.
Thanx.
Thanx.
Quick question ..... where do you look first when trying to get more mid corner / on power steering ? I'm new to the TC but have spent the last year or so running 1/12th scale (lots of corner speed). That said, it just seems to me that I should be able to push the car harder through the corners. I lose a lot of speed waiting for the car to turn enough so I can get back on power. If I push it mid corner it will swing wide. I'm not really looking for suggestions to my current set up as much as I'm looking to peoples theories when trying to resolve such an issue. I believe initial turn in is more of a front end thing, whereas this issue may best be served by rear end adjustments ? Any insight is appreciated.
ok cool ill give them a try im just tired of breaking cup joints... Korey do you happen to know what material the DJC's are made of steel aluminum or some kind of other metal
I dont know if anyone has mentioned it but the only thing that i dislike about my cyclone TC is not been able to change the pinion without removing my battery , any solution ? apart from trimming bit off motor shaft
today had arrived Cyclone TC main chassis !
