Old 03-20-2010, 08:45 PM   #18811
Originally Posted by JamesArluck View Post
Korey or Hiro,
Can you post a mod setup for outdoor asphalt? I'm going to shake down my TC tomorrow and am looking for a starting setup.
-James
Hi James,
I know it is already very known setup but i still think this would be the best one to start with. I'm glad that you drive a cyclone tc now.
File Type: pdf Atsushi Hara Reedy Race 2008 Winning Setup.pdf (408.6 KB, 182 views)
Hi-LowBlow is offline   Reply With Quote
Old 03-21-2010, 07:48 AM   #18812
Default swap:
Hi, I have a Cyclone brushless motor mount set which I don'nt use. Its in as new condition.
I am looking to swap for TC rear upper bulkheads/ Alloy shock mounts(ball stud)/ 1 or 1.5 degree toe block. I've also got 2.5 degree and 3 degree toe blocks as well which I would swap of include
Open to any offers before I end up putting them on e-bay.
cheers,
Mi
michael.branth is offline   Reply With Quote
Old 03-21-2010, 01:22 PM   #18813
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by Korey Harbke View Post
RCS, I have never been there. But it is in Thailand... And a lot of the changes I see on Hara's car are to tone it down so he doesn't overheat the tires. That's why he's running such thick shock oil, and the shocks are layed way down, and other changes. His TITC setup is better suited for a high grip track, in extremely hot weather, with a pretty flowing layout.
-Korey
Hi Korey,
(1) The topic about "cooking" the tires came up at the weekend practice day.
I realised I did not fully understand the logic behind this.
If the shocks are laid way down:
-- The wheel rate is reduced ("softer"), but on the other hand,
-- The shock is not working as much
(2) So, why does laying the shocks down (a lot) reduce tire heating (at a TITC like track) ??
Thanks in advance
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 03-21-2010, 04:03 PM   #18814
SpidarX's Avatar
Does anyone have a good setup for running foam tires on medium grip/bumpy asphalt?
If not, then if I take a setup for medium grip asphalt on rubber tires, what changes should I make due to running foams? Stiffer springs?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 03-21-2010, 04:05 PM   #18815
warnos's Avatar
Originally Posted by Hi-LowBlow View Post
Hi James,
In Hara's setup... With the shims that have been used on the front and rear hinge pin and rear wheels.. what affect does this have.. its like the wheels have been moved back and there is less play in the front hinge and there is more play in the rear of the car..
Anyone know what this does to the car??
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 03-21-2010, 08:51 PM   #18816
RLMW VQ's Avatar
korey how is the exotek chassis?
what are the differences between the stock tc chassis and exotek?
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 03-21-2010, 09:45 PM   #18817
DirtDrop's Avatar
had a blast with the tc today at hobbytown. thanks hiro and mark for helping me set it up
DirtDrop is offline   Reply With Quote
Old 03-22-2010, 02:22 AM   #18818
Korey Harbke's Avatar
Originally Posted by cosmo1974 View Post
Hi Korey,
Thanks in advance
Generally the tire is loaded and unloaded really fast and aggressively with stood up shocks. Shocks that are more laid down make the the car transfer weight slower side to side. So it helps not load the tire so abruptly. Thats how I feel it keeps tire temperatures a little cooler... to a point. You still need to make sure the car isn't sliding around. I feel shock oil has a greater effect on tire temperature. If you are overheating your tires, thicker oil helps a lot.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-22-2010, 02:24 AM   #18819
Its really good. It's helped my car out a lot in lower traction conditions, and makes the car very easy to drive. Felt like it had more grip overall, most likely due to the added flex. Plus balancing out the chassis is super easy.
-Korey
Old 03-22-2010, 03:18 AM   #18820
cosmo1974's Avatar
-Korey
I will be able to pass this info onto others as well.
Old 03-22-2010, 06:16 AM   #18821
Trader Rating: 18 (100%+)
HI,
I raced yesterday with my Cyclone on indoor carpet with a 17.5 Novak motor/GTB ESC. I was able to complete a qualif of 8 minutes normally but I found the motor was a little hot. First time racing 8 minutes so I thought it should be okay for the main and I could check the gearing later. But in the main (still 8 minutes) I was able to only race for 5 minutes before the motor got cut off by ESC because it was wayyy too hot.
I'm running the following gearing and would like suggestion for next race.
Spur = 100 64P
Pinion = 50 64P
Pulley = 18T
FDR = 4.33
Tire = Sorex 28
Thanks,
thejo3 is offline   Reply With Quote
Old 03-22-2010, 04:26 PM   #18822
cyclone x's Avatar
is it true there will be a new cyclone soon
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 03-22-2010, 04:47 PM   #18823
callender89's Avatar
Trader Rating: 33 (100%+)
Just picked up a cyclone TC, new to this on road world. I was wondering what type of servo should i go with?
Thanks in advance
Southern California's only LOCAL DEDICATED FORUM
www.SOCAL-RC.com
callender89 is offline   Reply With Quote
Old 03-22-2010, 05:03 PM   #18824
RLMW VQ's Avatar
ko 2413ics servo is the best
and cyclone x yes there is a new car coming
Old 03-22-2010, 06:53 PM   #18825
cosmo1974's Avatar
Thanks in advance
I purchased one of the servos recommended to me on this forum.
Its the Futaba BLS 551, brushless, low profile.
Very nice
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
