Hot Bodies Cyclone
Thanks but ouch at the postage to UK
If anyone has any other ideas please feel free to post
i don't have any pictures at this moment, but i can take some later and post it. BTW, i thought Tommy posted a picture of the mod before?
Hi,
Im currently struggling to get my Cyclone TC to handle the way i would like it too...
I have been using Andy Moore's 2008 IIC setup but with the following things changed..
HPI gold springs front and HPI Silver on rear
30wt Losi oil all round
Only top deck cut (std middle deck still)
Plastic arms used to try to get more grip
I always struggle to get grip no matter which track i race at , my diff has been rebuilt loads of times and is smooth but not slipping , I run 13.5T rubber TC class , I have always used Sorex 24 tyres as this is what everyone seems to use at club with tyre warmers but NO additive is allowed , I have been told the carpet is quite low grip as its quite old but its also never had additive on it and its relayed each week (not a permanant track)
The only way i have been able to get grip is using Schumacher Carpet Dragon tyres, These provide so much grip that i wonder why everyone uses slicks at all, I find i cant go as quick as the guys on slicks so i am hoping to use slicks too if only i could get some grip
As a relative beginner to TC im not really smooth yet with the steering and find it hard to be with the steering so twitchy, The back end seems to step out on corner exit from what i can tell, Is the problem the front end ?
Any advice on what i can do to change this would be a great help
Thanks !
Thanks !
Can you post a mod setup for outdoor asphalt? I'm going to shake down my TC tomorrow and am looking for a starting setup.
-James
You coming out to Speedworld? Hit Scotty up for a set up. He modified Barry's KO set up and his car was pretty fast last time out. We'll be running it tomorrow.....Did you do the chassis mod????
Yes, I will kick a man while he is down.
I know it is already very known setup but i still think this would be the best one to start with. I'm glad that you drive a cyclone tc now.
swap:
Hi, I have a Cyclone brushless motor mount set which I don'nt use. Its in as new condition.
I am looking to swap for TC rear upper bulkheads/ Alloy shock mounts(ball stud)/ 1 or 1.5 degree toe block. I've also got 2.5 degree and 3 degree toe blocks as well which I would swap of include
Open to any offers before I end up putting them on e-bay.
cheers,
Mi
cheers,
Mi
RCS, I have never been there. But it is in Thailand... And a lot of the changes I see on Hara's car are to tone it down so he doesn't overheat the tires. That's why he's running such thick shock oil, and the shocks are layed way down, and other changes. His TITC setup is better suited for a high grip track, in extremely hot weather, with a pretty flowing layout.
-Korey
-Korey
(1) The topic about "cooking" the tires came up at the weekend practice day.
I realised I did not fully understand the logic behind this.
If the shocks are laid way down:
-- The wheel rate is reduced ("softer"), but on the other hand,
-- The shock is not working as much
(2) So, why does laying the shocks down (a lot) reduce tire heating (at a TITC like track) ??
Thanks in advance
Does anyone have a good setup for running foam tires on medium grip/bumpy asphalt?
If not, then if I take a setup for medium grip asphalt on rubber tires, what changes should I make due to running foams? Stiffer springs?
Anyone know what this does to the car??
korey how is the exotek chassis?
what are the differences between the stock tc chassis and exotek?
had a blast with the tc today at hobbytown. thanks hiro and mark for helping me set it up
