Old 03-17-2010, 11:23 AM   #18781
Korey Harbke's Avatar
Use a file or a dremel with a sanding drum to take .75mm off the bottom of the steering knuckle. Then put a shim on top of it like the picture Tommy posted shows.
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-17-2010, 11:39 AM   #18782
Originally Posted by Korey Harbke View Post
Lowering the steering knuckle changes the roll center slightly. its a small change but its enough to notice it.
Hey Korey,what does this do in terms of handling?
grouchy is offline   Reply With Quote
Old 03-17-2010, 11:45 AM   #18783
As Hiro and Tommy had mentioned before, it gives the car a slightly lower front roll center. If you look at some off road cars (like the Team Associated B4) they have a similar adjustment on their car. This just balances out the roll center a little better.
For me, it just resulted in more steering overall. I would only run it with 1.5mm shims under the main suspension blocks. If you use 1.0mm under the suspension blocks, AND lower the steering knuckle, it makes the roll center way to low. The car became very inconsistent and hard to drive for me. So just run 1.5mm under the suspension blocks if you want to try the lowered steering knuckle.
-Korey
Old 03-17-2010, 11:50 AM   #18784
-Korey
thank you
Old 03-17-2010, 11:52 AM   #18785
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
-Korey
call it a newbie question (but i've never bother with shims under the suspension blocks since i run mainly on parking lot tracks), but i'm assuming its 1.5mm under the front and rear of the car?
i guess you could do this (much more painfully) with aluminum knuckles as well?
Bodies By Bean | Team Belly
k_bojar is online now   Reply With Quote
Old 03-17-2010, 11:56 AM   #18786
Just about everyone starts with 1.5mm under all the suspension blocks (FF, FR, RF, RR). It's just a good starting place that works well in almost every condition. Sometimes is more grip is needed, we drop it down to 1.0mm. I can't say that I've ever tried 0 shims under the suspension blocks though.
-Korey
Old 03-17-2010, 01:27 PM   #18787
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Me and my team mate has run the blocks flat on the chassis sometimes if the grip is extremely low, that's the case when we run some of the regional series on non-permanent tracks.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-17-2010, 01:35 PM   #18788
-Korey
Thanks for the info Korey
DOTMAN is offline   Reply With Quote
Old 03-17-2010, 03:11 PM   #18789
Trader Rating: 55 (100%+)
Default Suspension block shims
I've always been confused by the fact that the HPI Pro4 setup guide recommends increasing the height of the suspension block shims for low traction situations. The advice for the Cyclone seems to be just the opposite, even though the suspension geometry between the two cars is basically the same. Any thoughts??
WatchOut is offline   Reply With Quote
Old 03-17-2010, 03:19 PM   #18790
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
It's basically the same thing..just kinda lost in translation. "MOVE UP" for less traction surfaces=adding more spacers in the bottom for tracks that do not need more grip.
"Move Down" for track that need more grip(on the car that is)
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 03-17-2010, 03:35 PM   #18791
Yes, it might sounds odd, but actually both are correct i believe.
Lowering the roll center by lowering the suspension blocks let the car have more roll easier, This will generate more traction overall. However in some situation, raising up the roll center generates more traction too. Because of the rigidity effect for the roll, suspension gives more pressure to each tire and it sometimes gives better traction no matter how the suspension works.
They both are just different ways or theory i think?
Hi-LowBlow is offline   Reply With Quote
Old 03-18-2010, 07:54 AM   #18792
jag88's Avatar
Originally Posted by jag88 View Post
I use xray spindles. They are stonger and they are .75mm shorter so no grinding. Use the forward most hole to duplicate the steering geometry.
Thanks for the set up sheets.
To further add to the confusion, if you are using xray knuckles and want to lower it .75 mm
then you would have to file .37 mm off the bottom and add it back at the top (that is, everything else being equal) .
Korey, which top deck are you using on your Exotec chassis ? TC 2.5 mm, lipo or original ?
jag88 is offline   Reply With Quote
Old 03-18-2010, 08:30 AM   #18793
I'm using the upper deck that comes stock in the TC kit. I'm pretty sure they are 2mm thick though
Old 03-18-2010, 10:24 AM   #18794
jag88's Avatar
Yes they are 2 mm. I'm not sure where I got 2.5 from .....
Another question, which Exotec chassis are you using, the one with the carbon battery 'fingers' or the one with the steel fingers ? The reason I ask is that I just got the carbon finger chassis and find that it is way more soft then the steel finger one. Its still 2mm but narrower and has more cut outs .... kinda a bummin' about that as I thought the original was a little soft.
Thanks for your time.
Old 03-18-2010, 10:42 AM   #18795
We have #61286 2.5mm Solid Upper Deck, may be this is what you have?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
