Old 03-15-2010, 12:14 AM   #18736
Send a message via MSN to ramas3d Send a message via Skype™ to ramas3d
Originally Posted by tomracing View Post
does anyone know if the new lrp v-tec 5900 lipos fit to the cyclone?
I am using Vtec 5900 battery, but to fit it without using LiPo conversion Kit I have cutted 2mm of aluminium part place where it connects to upper deck. Also you will need to use shorter screw or cut 1mm of screw.
ramas3d is offline   Reply With Quote
Old 03-15-2010, 12:47 AM   #18737
Default use of optional parts
Hi all,
I am curiuos about optional part like titanium coated shocks, metal diff cups, and other part that do not come in car KIT.
In ETS I have seen that in cyclone these parts are used, but what is the differece and is any better performance in it runing in stock class with 13.5 or 17.5 motors on very high grip carpet.
Old 03-15-2010, 06:24 AM   #18738
Coldn's Avatar
Send a message via MSN to Coldn
Originally Posted by ramas3d View Post
Hi all,
thers more resistent. I think theres no need for 13.5 motors.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-15-2010, 07:57 AM   #18739
Hey guys, I asked a few days ago about solving a rear traction problem with my cyclone and I am working on the changes. Does anyone know what changes to the front diff might help rear traction or help stop the rear from overtaking the front? I am currently running a solid front drive. Would it be better to go to a ball diff or one way up front?
Touring Jr. is offline   Reply With Quote
Old 03-15-2010, 08:05 AM   #18740
timmig's Avatar
Trader Rating: 25 (100%+)
Actually --you'll find the diff in the front will give the front MORE bite and steering. It won't help the rear----- softer springs on the rear---ensure you have 1.5 to 2 degrees of camber--and 3 degrees of tow in!! You could also put a swaybar on the front only--and lean the rear shocks in a little--middle hole on the bottom--3rd or 4th hole in on the top. All of that will help plant the rear.
FWIW
Tim
timmig is offline   Reply With Quote
Old 03-15-2010, 08:43 AM   #18741
Thanks Tim. What do you think would be better for the front, The solid or the one way? We are running on low traction carpet.
Carl
Old 03-15-2010, 08:49 AM   #18742
timmig's Avatar
Carl
The one ways will give a little more steering I THINK on carpet--the spool should be your best bet-- it will also allow you to get 4 wheel braking which is a good thing!!
Old 03-15-2010, 09:01 AM   #18743
jag88's Avatar
Carl
I like a ball diff in the front only because I feel it is easier to drive, the problem is that you can't get off the corner with any speed/power. A one way will get you off the corner but I find that it has a mind of its own in which direction it's going to take to the next corner. It does carry good corner speed though. I run the spool.
The only way is to try all three and see what your lap times are.
jag88 is offline   Reply With Quote
Old 03-15-2010, 09:15 AM   #18744
Thanks Guys
Carl
Old 03-15-2010, 01:32 PM   #18745
For those who run in RCGT series with the Cyclone TC, here is a setup sheet for it.
I have run the setup at the west coast rc race way (indoor high bite track) last weekend and worked very well. I thought it would be good to share with everybody who loves RCGT.
Hi-LowBlow is offline   Reply With Quote
Old 03-15-2010, 02:50 PM   #18746
rocketron's Avatar
Trader Rating: 16 (100%+)
Hiro was very quick with this setup everyone.... great race Hiro San
rocketron is offline   Reply With Quote
Old 03-15-2010, 03:04 PM   #18747
Old Tech's Avatar
Carl
As a rule, you'll like that one way better on fast tracks with large sweeping corners. They carry speed well, but due to only having 2 wheels braking can get a little dicey under braking. The spool (solid axle) won't turn in as hard, but will claw like a pissed off badger coming out of the corner. The ball diff is somewhere in the middle...you can get it to act somewhat like a spool if you tighten it up. I agree with jag88, the easiest to drive is with the diff up front.
Old Tech is offline   Reply With Quote
Old 03-15-2010, 04:40 PM   #18748
Thank you Ron!
Old 03-15-2010, 04:42 PM   #18749
Fred Hubbard's Avatar
Yes he was!!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 03-15-2010, 07:15 PM   #18750
RLMW VQ's Avatar
if anyone has a moore or hara chassis plate that they want to sell please pm me im looking for one asap has to run on carpet only and little to no scatchs. thanks
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
