Old 03-11-2010, 04:59 AM   #18706
AGNO's Avatar
Did you know that Exotek also makes a chassis kit with the Europeans in mind? Instead of the stainless steel battery retainers, it's all carbon fiber. I'm not sure if he positioned them any different, but you would still get the other benefits of the chassis plate.
http://www41.instantestore.net/merchant10762/pd-hbx.cfm
-Korey
Not know ... very interesting.
Thanks korey
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-11-2010, 05:03 AM   #18707
tomracing's Avatar
-Korey
gotta say that annoys me a bit as i just got the original hbx chassis and I was working on making it lighter to fit the rules here. plus this new chassis seems to have some other nice features.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 03-11-2010, 05:39 AM   #18708
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
-Korey
I didn't know MikeR revised this chassis so that the belts can be reversed
anyone else try reversing the belts like Hara's prototype used at the TITC??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-11-2010, 07:01 AM   #18709
Coldn's Avatar
Send a message via MSN to Coldn
here in brazil some guys reverse the belts. to use electric more in center of the car. but we dont use exoteck chassi.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-11-2010, 07:17 AM   #18710
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I ran my drivetrain flipped at DHI using stock TC chassis.
Flip diffs and layshaft, then add an extra bearing on the left side to space out the play.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-11-2010, 08:19 AM   #18711
AGNO's Avatar
If you use heavy batteries of 280 gr mh type 5000 is not necessary to turn the transmission, the car is balanced only by moving outside the batteries without moving into electronics.
Moving the transmission and electronics to balance the machine is needed when using lightweight batteries 3800/4000 mh of 240 grams, with this configuration makes the car very light and balanced.
The prototype of Hara, from what we can see from the photos shows a very narrow transmission, batteries are in place almost within the standard model even with the transmission then reversed it becomes necessary to move the electronics inside the balance With this configuration you have a car with weights very centered with advantage on handling.
Old 03-11-2010, 09:22 AM   #18712
k_bojar's Avatar
gotcha - i was just curious about flipping the belts to see if i can get the front belt off the motor mount
i'm assuming the rear diff won't loosen when its put in backwards?
Old 03-11-2010, 09:28 AM   #18713
k_bojar's Avatar
left as in electronics side? American drivers' side?
wouldn't spacing out the locked pulleys to eliminate side-side play do the same thing?
how would you handle a one-way pulley? put the extra bearing between the one way and the spur gear?
Old 03-11-2010, 09:39 AM   #18714
AGNO's Avatar
I tried to turn the trasmisione once but now I use the standard configuration, however, no problem of loosening of the differential.
Old 03-11-2010, 06:03 PM   #18715
trickd122's Avatar
looking at this chassis it appears as though it has the hole already made for the Fr/FF block modification. Can anyone clarify/verify?
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 03-11-2010, 06:10 PM   #18716
trickd122's Avatar
Have you noticed any differences in handling v/s standard drive train replacement?
Old 03-11-2010, 06:18 PM   #18717
k_bojar's Avatar
Nah, that's not it... My exotek chassis has those mounting positions and mine is about 6 months old
but there is an extra cutout by the motor that's interesting
Old 03-11-2010, 06:22 PM   #18718
Trader Rating: 63 (100%+)
Send a message via AIM to joey
mine doesnt have the holes for the FR block mod..
=Joe Wright=
joey is offline   Reply With Quote
Old 03-11-2010, 06:45 PM   #18719
k_bojar's Avatar
Well ok then I just looked at mine and i stand corrected - was thinking about the stock cyclone chassis I got - oopsie
Old 03-11-2010, 08:57 PM   #18720
JKL1031's Avatar
hey folk,,im planning to put the sway bar kit on my sprint 2, and so far besides the sway bars themselves, i know i need
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
what else is missing? also which sway bar u all would recommend?
JKL1031 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
