Old 03-04-2010, 12:26 AM   #18646
Originally Posted by JR007 View Post
That is so close to my asphalt set-up it's not funny. I have 4mm ackerman, and silver rear sway, otherwise the same.
That sucks.
It means it's my driving not the car
ha ha
You can try 3 mm ackerman since that make the car slightly less agressive and easier to drive. Together with gold sway bar, your car could rotate and carry more speed thru the corners. I think your overall lap time could improve slightly.
andrew188 is offline   Reply With Quote
Old 03-04-2010, 12:39 AM   #18647
Originally Posted by jag88 View Post
Hiro/Korey have you seen or driven the new prototype ? Can you give us your thoughts/impressions about the changes that were made and how they help the car ?
Any hint of a release date ?
Thanks.
Hara's new car was a class above all other cars during TITC. That is what I honestly believe. I will get it for sure once it is available. I heard it will be June, but may be delayed. I rather have the HB team test it throroughly first, than rushing to release it.
The current car is still a great car that is probably more capable than some of the newer cars in my opinion. I have also tried the T2 and T3, and went back to my Cyclone, because Cyclone always gave me better lap times.
Old 03-04-2010, 10:19 AM   #18648
Giorgio's Avatar
Hello everyone!
After two years of Losi Jrxs-R, I "rejoin" the HB Cyclone.
I've had a Moore edition for few months, two years ago. The Moore was my car between Xray and Losi.
I now bought the Cyclone TC (it will be at my door somewere next week).
Any tips before I start the job?
I'll race outdoor, tires sorex or solaris, lipo and motors anywhere from 13.5 to 10.5 to 4.5, according which class will be available.
Thanks for the help
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 03-04-2010, 11:33 AM   #18649
CL
CL's Avatar
Trader Rating: 32 (100%+)
Thanks.
I heard it was next year.
Believe in yourself!
CL is offline   Reply With Quote
Old 03-04-2010, 12:48 PM   #18650
san.'s Avatar
Trader Rating: 59 (100%+)
Thanks.
Read somewhere that it's scheduled for a June 2010 release, but might be slightly delayed.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 03-04-2010, 01:15 PM   #18651
Trader Rating: 17 (100%+)
Rumors abound but I would guess that it will be available for the Team going to the Worlds. Public release (barring any developmental problems) would be after that.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 03-04-2010, 01:43 PM   #18652
Giorgio's Avatar
Where I can find an editable pdf setup sheet fo rthe TC?
Old 03-04-2010, 02:38 PM   #18653
AGNO's Avatar
http://www.hotbodiesonline.com/pdfs/...ge20090118.pdf
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-05-2010, 02:13 PM   #18654
Originally Posted by aztbone View Post
Does putting a 2 degree pivot block on the front of my Cyclone TC give you more steering? On Barry Baker's set-up sheet from the KO Propo race, he has the 2 degree pivot block on the front. I have always used 0 degree blocks or no shims on all of my others cars. What does sweeping your arms back like that do for you? If somebody could help me out with this, that would be great.
with barry's setup he used a 2.0 degree block on both sides of the hinge pins on the front end of the car. arm sweep was kept at 0 degrees with this setup, but brought the arms our stlightly. it is a special mod that will require you to drill your chassis.
From what i know, this allows you to use slightly softer shock settings on the front while maintaining higher corner speed.
jmann591 is offline   Reply With Quote
Old 03-05-2010, 02:48 PM   #18655
Jochim_18's Avatar
Since it's brushless motor there is no point of mounting it on the endbell by mounting the fun on the side this will cool the motor can better. In the old days of brushed motor all fun is on the end bell to cool down the brushes.
Originally Posted by warnos View Post
Where the fan is placed on Hara's car.. it looks like it was blowing air onto the motor front the back of the car to the front.. I thought the fan sucking air from the front to the rear would be better as the natural air flow would also help..
Is this what others also do??
I have the same fan.. so unless he has his one going in reverse then thats the way its setup..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-06-2010, 01:37 PM   #18656
There is not a lot of natural air flow under a TC body. I know because every time I take my car off ther track there is a layer of fine dust all over it!
The fan blows pretty hard, any subtle natural air flow wouldn't have a noticable effect
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 03-07-2010, 08:22 PM   #18657
RLMW VQ's Avatar
does anyone have a conversion chart for the springs color to weight. please post it. thanks
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 03-07-2010, 10:16 PM   #18658
CSF0623's Avatar
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 03-07-2010, 10:25 PM   #18659
Trader Rating: 24 (100%+)
What overall ratio should I be running on my cyclone with x12 5.5 and a tight track?
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 03-08-2010, 02:41 AM   #18660
Default New HB Touring Car
Its great theres a new car out, but call me old fashioned, every time I see Hara clipping that kerb after Rheinhard made a mistake....................The Cyclone could have been Double world champ!!!!
I'll still be using my old WCE/TC cyclone for a while yet- Been using a TC5 for a few weeks, just for a change and its no where near the cyclone- They just have so much corner speed
michael.branth is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
