Old 02-24-2010, 01:05 PM   #18586
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Hi-LowBlow View Post
Hi,
I have checked all the instruction manuals for cyclone series but all show that the center one-way pulley is for front drive belt.
To adjust the center one-way pulley, you need to adjust the spur gear holder and spur gear holder actually holds the one-way center pulley.
Thanks,
Thanks Hiro, but the Cyclone manual I have (the pdf) definitely shows the one way going to the rear, I even had someone else look at it to make sure i wasn't blind and/or nuts
and thanks for the way to hold the pulley in place
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-26-2010, 09:14 AM   #18587
Luppi Stefano's Avatar
on TITC Hara is back!
1 10 JILLES GROSKAMP 19 5:05.820 NETHERLANDS
2 1 ATSUSHI HARA 19 5:07.909 JAPAN
3 3 SHINNOSUKE ADACHI 19 5:09.730 JAPAN
4 11 MEEN V. 19 5:09.929 THAILAND
5 2 TAKAYUKI KOUNO 19 5:11.960 JAPAN
6 10 SIMON NICHOLSON 19 5:12.632 AUSTRALIA
7 9 KIYOKAZU SUZUKI 19 5:12.848 JAPAN
8 11 CHARLEE P. 19 5:12.974 THAILAND
9 2 ANDY MOORE 19 5:13.939 UK
10 7 SURIKARN C. 19 5:14.908 THAILAND
News from Hot Bodies?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 02-26-2010, 07:53 PM   #18588
303slowdown's Avatar
Trader Rating: 21 (100%+)
Hoping someone can help me
My car seems to have drag break when their is none in the speedo. I have replaced all the bearings in the car and it still has a ton of drag what else should i check, any help would be great.
303slowdown is offline   Reply With Quote
Old 02-26-2010, 08:02 PM   #18589
Trader Rating: 20 (100%+)
does your car roll freely without your electronics installed. I had an issue of my center pulley binding because it was not centered properly
goots is offline   Reply With Quote
Old 02-27-2010, 04:53 AM   #18590
warnos's Avatar
I had a similar problem when I replaced the belts in my car.. the old ones where allot looser.. so I moved the diff holders to the looses position for the belts and it fixed my problem..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 02-27-2010, 06:20 PM   #18591
With my Cyclone the threaded end of the inner link ball studs hit the diff bearing carriers.
Lazer Guy is offline   Reply With Quote
Old 02-27-2010, 11:44 PM   #18592
hi-tech-redneck's Avatar
you might want to check your ball stud placement,short ones are for the bulkheads and the long ones are for the susp. if you put the long ones in the bulkhead they will hit the diff.
tularecountyrc.com/the chicken ranch/exeter hobbies/nor-cal hobbies,ripon raceway/hara tcx/losi 22/top photon vta/tekin/reedy/hpi racing/3racing/AT&T/much more/upgrade rc
hi-tech-redneck is offline   Reply With Quote
Old 02-28-2010, 04:25 AM   #18593
jarkkom's Avatar
Send a message via MSN to jarkkom
Any pics of the new car being victorious at the TITC?
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 02-28-2010, 05:50 AM   #18594
Trader Rating: 24 (100%+)
www.titc.in.th/
FYI for some current info. Don't know about good pics though.
Hi All, I'm not a cyclone driver yet but very sure it'll be my next car. Can someone lead me to a good source where I can get familiar with the various models of cyclone that have come out. I'd like to know for sure what I'm buying if I find a good used car.
Evoracer is offline   Reply With Quote
Old 02-28-2010, 08:39 AM   #18595
tomracing's Avatar
photos courtesy of www.rcblood.com
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 02-28-2010, 08:55 AM   #18596
mac853's Avatar
Exclamation
Nothing newer than lower, upper deck and the belts changed the side, that's all!
Could somebody tell me if the is possible to find gear diff for Cyclone?
Best regards
mac853 is offline   Reply With Quote
Old 02-28-2010, 09:07 AM   #18597
Best regards
look again the servo is in a different place
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 02-28-2010, 09:15 AM   #18598
changed a lot!
still need more detailed pictures
Lab F1-01
Old 02-28-2010, 09:23 AM   #18599
tomracing's Avatar
first of all i think the cyclone geometry as it was is still very good the only thing it needs is better lipo support.
this car I think it changed quite a bit.
so far obvious visual changes i've seen:
-new chassis plate
-new one piece topdeck (now including the old rear topdeck)
Originally Posted by andrew188
The top deck looks like a 1 piece, but it is actually a 2 piece design.
-new motor mount bulkhead (coming across the chassis?)
-belts changed side
-new central pulleys (thinner, no more boss so mounted like yokomo?)
-steering servo rotated
-used (new?) alloy front steering blocks
-different FR suspension block?
-new rear shock tower? (this one is notched in the middle and we didn't have that yet)
and i can't see very well but there must be a new alloy bulkhead front or rear holding the spool or diff as the current cyclone cannot support a long topdeck over he entire car. so far i think it is at the front.
btw if you find more or better pictures please do post here!
Tom van den Brink
Old 02-28-2010, 11:29 AM   #18600
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
I'm interested if HB will release a whole new car, or it will just be something to add on to the Cyclone. It seems like a lot to add on to the car.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
