Old 02-22-2010, 04:56 PM   #18571
RLMW VQ's Avatar
thanks korey
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Old 02-22-2010, 08:50 PM   #18572
Trader Rating: 20 (100%+)
Front
pink springs
40wt AE oil
3 position on the shock tower
2 hole piston
outside hole on front pro4 arm
1.4 front sway bar
2.5 front block
droop 3mm on blocks
1.5 mm under all front suspension blocksresponce
4mm ackerm
2mm spacer under front camber tie rod
2 of camber
5.5mm ride height
Rear
blue springs
40wt AE oil
#2 pistons
4 position on the shock tower
middle hole on old pro 4 arm
1.2 rear sway bar
3.0 rear block
droop 4mm
1.5 mm shims under all suspension blocks.
rear hub spacers 2.0/front, 0.75/rear
1.5mm spacer under rear camber tie rod
arms all the way back 2.0mm in front of arm, 0.75 behind of arm.
2 degrees of camber
6mm ride height
This is my setup at the moment on sores 36R. 2nd place in the mains 3rd fastest in qualifying. Car felt really good. Car kinda feels soft for me in the rear with the blue springs, but I can get used to that.
My question now would be the 3 hole pistons. What kind of handling chages will I feel? And maybe upping the front oil rate to say 45w and leaving the rear at 40W
The track is a a little bit bumpy, hence the higher ride height. Can anyone tell me also if my droop seems correct? I am still learning about this setting.
goots is offline   Reply With Quote
Old 02-22-2010, 10:28 PM   #18573
bukil's Avatar
Trader Rating: 37 (100%+)
Just dropping by to say THANK YOU HIRO!. Blake and I had fun at westcoast this past Saturday. You're a genius when it comes to setups.
Thank you for helping us out .
bukil is offline   Reply With Quote
Old 02-23-2010, 02:43 PM   #18574
No problem! i had fun time at there too. See you next time.
Hi-LowBlow is offline   Reply With Quote
Old 02-23-2010, 05:48 PM   #18575
bigkoitat's Avatar
Trader Rating: 6 (88%+)
Hiro is a Wizrd when it comes to setup I finally got my car DIALED this Saturday, after the races though. Cant wait till this Saturday to race.
JAWS
TRF-416WE & 416-X / DHW / TEAMRCR.NET
bigkoitat is offline   Reply With Quote
Old 02-23-2010, 05:56 PM   #18576
san.'s Avatar
Trader Rating: 59 (100%+)
Huge Garage Sale @ HB's website:
http://www.hotbodiesonline.com/garagesale/
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 02-23-2010, 06:58 PM   #18577
RockyMania's Avatar
Trader Rating: 17 (100%+)
Do you/they ship outside the US? Cheers!
RockyMania is offline   Reply With Quote
Old 02-24-2010, 07:57 AM   #18578
Coldn's Avatar
Send a message via MSN to Coldn
I put this post in Brazilian forum!! they will be very happy with this news
http://www.rceletrico.net/phpBB3/vie...3433&start=120
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 02-24-2010, 08:07 AM   #18579
jag88's Avatar
not 100% sure but I thought I saw something that said US and Canada only ...
jag88 is offline   Reply With Quote
Old 02-24-2010, 09:30 AM   #18580
Luppi Stefano's Avatar
my last setup on Moquette
translate of notes
"WC Arms, Cut Middle Deck, Topdeck WC, Exotek Chassis, Battery Brace TOP.
Droop is Misured raising wheels with height Gauge, below the height from the ground."
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 02-24-2010, 09:55 AM   #18581
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
translate of notes
hey Luppi - do you have a link or information about the TOP Battery Brace?
Bodies By Bean | Team Belly
k_bojar is online now   Reply With Quote
Old 02-24-2010, 10:23 AM   #18582
Hi!!!
I removed the battery brace Exotek, because, for m il too heavy.
and replaced with battery Brace Top.
Battery brace TOP is much lighter and adjustable, comes with 2 mounting options, short lateral support (mounted in photo) and support laterlale to add any weight.
I preferred the Move Lipo for my cyclone
is perfect for Exotek Chassis.
Lab F1-01
Old 02-24-2010, 11:15 AM   #18583
Dog Bone's Avatar
Absolutely correct - when you sign in and confirm you address, this is posted at the top of the page:
Please note:
Online ordering is available for the US or Canada only. All other orders will be cancelled immediately.
And thanks to san for the heads up on the sale....
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 02-24-2010, 11:20 AM   #18584
k_bojar's Avatar
ok guys, i got a really, really, really, really, really, really silly question...
the center oneway - does the one way pulley go to the front or the rear? its always been my understanding the oneway pulley goes to the front (be it a diff or spool or oneway), but i was looking at the Cyclone manual (on page 12) and it DEFINITELY shows the one way pulley going to the rear - which is kinda stumping me as to why...
So Korey, Hiro anyone got an explanation why it would go to the rear instead of the front? or is it just a mis-print in the manual??
I just looked at a WCE manual and it shows the center oneway on the front belt...
so i'm assuming the 'standard' cyclone just has a misprint?
so if it is a mis-print in the 'standard' manual, what are you guys using to hold the oneway pulley in place and not sliding around on the center shaft?
make any sense
thanks!
Old 02-24-2010, 01:01 PM   #18585
make any sense
thanks!
Hi,
I have checked all the instruction manuals for cyclone series but all show that the center one-way pulley is for front drive belt.
To adjust the center one-way pulley, you need to adjust the spur gear holder and spur gear holder actually holds the one-way center pulley.
Thanks,
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
