Old 02-12-2010, 04:13 PM   #18511
Korey Harbke's Avatar
Originally Posted by AGNO View Post
Hello Korey I ask you a question:
How many degrees of steering used on asphalt and carpet.
On my Ko radio, I set the steering travel to 100%, then set the endpoints till the wheels lock. Then I back off the steering travel adjustment to 90%. So it's about 90% of full travel.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-13-2010, 04:59 AM   #18512
trickd122's Avatar
Default terrible handlind
SO I decided to stiip the car down to it's kit form. On the final stage after setting the droop I discovered that in the front I can only get 4mm ride height. Could this be the bulkheds or the shock tower. this is the TC
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 02-13-2010, 09:37 AM   #18513
Either you have too much Droop (I run max. 6mm on Blocks when using Sorex Tires) or your Dampers might be too short.
Make sure, that the Downstop screw doesn't limit the rideheight.
You could also check your suspension blocks and shafts if they are flat/straight.
But normaly, if I couldn't make rideheight, it were the Downstop screws.
bonda is offline   Reply With Quote
Old 02-13-2010, 09:50 AM   #18514
AGNO's Avatar
-Korey
Thanks Korey, I thought that for the carpet to use less steering angle.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-13-2010, 11:21 PM   #18515
billythekid is offline   Reply With Quote
Old 02-14-2010, 11:24 PM   #18516
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Here's a pretty cool video from saturdays practice
+ YouTube Video
Laptimes around 8.4 on these laps, 6.5 turn
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-15-2010, 03:53 AM   #18517
I just drilled the holes needed for the FR blocks on a mill at work..
Is there any idea to also drill holes for the RF blocks? I dont have my TC at work so i cant check if there's enough clearance for the belt..
Old 02-15-2010, 11:01 AM   #18518
mac853's Avatar
Questions??
Could anybody tell me if Cyclone shock fits TRF pistons(53573), please?
In fact i am looking for 3 holes ones.
Best regards
mac853 is offline   Reply With Quote
Old 02-15-2010, 11:06 AM   #18519
+ YouTube Video
That's great video to watch! Thanks for sharing that.
I thought my computer is super slow when i started the video LoL
Hi-LowBlow is offline   Reply With Quote
Old 02-15-2010, 01:07 PM   #18520
jag88's Avatar
Korey/Hiro, do you tune your chassis using spacers under the outer steering link (bump steer) ? When I look at the geometry it looks like adding more spacers would induce a bump steer on the outside (loaded) tire and could be useful in getting more midcorner but when I try it it seems like it takes steering away or deadens the steering.
Just wondering if either of you have worked with it.
Thanks.
jag88 is offline   Reply With Quote
Old 02-15-2010, 01:43 PM   #18521
Trader Rating: 67 (100%+)
Send a message via AIM to joey
Best regards
they fit Mac, ive been using them for awhile in my surikarn edition
=Joe Wright=
joey is offline   Reply With Quote
Old 02-15-2010, 05:27 PM   #18522
Best regards
They fit. I use the tamiya 3 hole pistons interchangeably with the hb 1.1mm 3 hole pistons. Thats pretty much what a tamiya piston is, but the outer diameter is ever so slightly larger. Personally, I can't really tell the difference on the track, so I use both.
-Korey
Old 02-15-2010, 05:28 PM   #18523
Thanks.
I've never bothered to mess with it. Bump steer is something I've honestly never bothered to mess with too much in a touring car. Only in extreme cases where the original suspension geometry was REALLY weird (I won't say which car lol), and needed adjustment to take most of it out.
Might be something I play with in the future though.
-Korey
Old 02-16-2010, 03:50 AM   #18524
mac853's Avatar
-Korey
What, larger?
Well I wonder using the HB original ones, if i could find it.
Thanks!
Old 02-16-2010, 04:21 AM   #18525
Trader Rating: 20 (100%+)
Front
pink springs
40wt AE oil
4 position on front tower Try #3 on the tower
outside hole on front pro4 arm
1.4 front sway bar
1.5 front block Try 2.5 deg block it should give you more initial turn in better
droop 2mm on blocks
1.0mm under all front suspension blocks. Go up to 1.5mm to get quicker responce
4mm ackerm
3mm spacer under front camber tie rod Try start with 2.0mm
2 of camber
5.5mm ride height If the track is not bumpy, try 4.5-5.0mm
Rear
silver springs
40wt AE oil
#2 pistons 1.1mm 3 holes would work better if you want the car aggresive
4 on the shock tower
middle hole on old pro 4 arm
1.2 rear sway bar
3.0 rear block
droop 3-3.5mm
1.5 mm shims under all suspension blocks.
rear hub spacers 0.75 in front 2.0 in rear change it to 2.0/front, 0.75/rear
2mm spacer under rear camber tie rod Try 1.5mm or stay with 2.0mm and then go #3 hole on tower.
arms all the way back (spacers in front of arms) Should be 2.0mm in front of arm, 0.75 behind of arm.
2 degrees of camber
6mm ride height
Originally Posted by Hi-LowBlow View Post
That would help if you could give us a bit more track info. but here are my suggestions to try...
Let me know after you try it.
Thanks,
the car felt much more reactive at the beginning of a corner, much more steering. But im still suffering from a little on-power understeer at the mid and exit of the corners. Any fix for this.
goots is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
