Old 02-04-2010, 10:24 AM   #18451
Ok guys, here is Barry's setup sheet from Snowbirds 2010.
I think he ran the same setup for both mod and 13.5 (i will confirm with him). The FDR for 13.5 was,,,,
Spur Gear: 108t
Pinion: 31t
FDR:7.546
Thanks.
Hi-LowBlow is offline   Reply With Quote
Old 02-04-2010, 12:09 PM   #18452
Korey Harbke's Avatar
Totally agree with what Hiro said. You cal also run a little bit of arm sweep by running a 2.5 or 3.0 block in the FF block.
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 02-04-2010, 12:50 PM   #18453
trickd122's Avatar
Default Rear toe issue
-Korey
How do I fix the rear toe issue on my car. I spoke to several guys and they say that they have bent the rear alu hub. So if I use a 3 deg on the Hudy gauges it's a little less that 2.5.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 02-04-2010, 12:55 PM   #18454
Originally Posted by trickd122 View Post
-Korey
Well, there was a small run of rear hub carriers that had the holes drilled a little weird. Good way to check the rear hubs is to see if the holes are in the same spot on both ends of the hub carrier. If it isn't drill straight, one will be a little offset.
I personally use the aluminum ones so I wouldn't have to worry about that. I haven't had any issues with them for about a year of racing. HB uses a pretty good aluminum for those particular parts.
Also check your hinge pins and make sure they are straight. Those can have an affect on rear toe in as well.
-Korey
Old 02-04-2010, 02:54 PM   #18455
mlight13's Avatar
Trader Rating: 40 (100%+)
Hey all...please help!
I just finished building my Cyclone S and have had nothing but problems so far. Most have been resolved except for the last one. After I installed all electrical components, all was well until I hit the throttle. It makes a consistent ticking noise at low to mid throttle and I can't figure out where it is coming from. At full throttle, I do not hear it at all. I am running a brand new Team Scream Racing 27T Epic ROAR motor, Robinson Racing Super spur and aluminum pro pinion which were meshed with a piece of paper, and I checked the belts, diffs, etc for tightness. Does anyone have ideas to what is causing this? It just doesn't sound right and I don't want to look like a tool when I show up at the track and have a clicking car. It is already embarrasing enough that I am running a brushed motor Please help.
Mark
mlight13 is offline   Reply With Quote
Old 02-04-2010, 06:32 PM   #18456
Had a similar thing happen on my S once. Try placing a washer between the motor screws and the motor plate. It sounds a little like the motor screws might be touching the armature.
Fllyer is offline   Reply With Quote
Old 02-05-2010, 06:56 AM   #18457
Dog Bone's Avatar
Check the pins on the front drive shafts - if the pin is protruding from the axle cup, it can cause a ticking sound. Don't ask me how I know
Also, make sure spur is clean - if something is wedged into the teeth, it may cause a ticking sound as well.
Dog Bone is offline   Reply With Quote
Old 02-05-2010, 07:31 AM   #18458
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by Dog Bone View Post
Check the pins on the front drive shafts - if the pin is protruding from the axle cup, it can cause a ticking sound. .
I think unless he has CVD's, i don't think the dogbones will have this problem in his Cylone S. I had this same issue as well...
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 02-05-2010, 08:33 AM   #18459
Luppi Stefano's Avatar
Spur Gear: 108t
Pinion: 31t
FDR:7.546
Thanks.
was used Chassis TC? Or Exotek?
Topdeck?
Cut Middle Deck?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 02-05-2010, 09:13 AM   #18460
Topdeck?
Cut Middle Deck?
thanks
I'm pretty sure he ran the chassis that is included with the moorespeed edition car, and typical upper deck and mid deck (not cut).
-Korey
Old 02-05-2010, 11:30 AM   #18461
-Korey
thanks Korey!!!
Spacer 1,5mm under Rear Pivot Block is useful for increase rear traction?
Lab F1-01
Old 02-05-2010, 12:00 PM   #18462
thanks Korey!!!
It usually depends on how much grip is actually on the track. In very high traction conditions, the 1.5mm will make the back end of the car corner flatter than say... 1.0mm. This can sometimes produce MORE rear traction. In lower grip conditions, you need the car to roll a little more sometimes, so running 1.0mm would allow that, and create more grip.
I usually always run a 1.5mm in the back just as a starting point. I usually run 1.5mm up front as well, but every now and then if I want to smooth out the car, and gain mid-exit steering... I run 1.0mm in the front.
-Korey
Old 02-05-2010, 12:30 PM   #18463
-Korey
You are the best!!
Lab F1-01
Old 02-05-2010, 12:32 PM   #18464
Topdeck?
Cut Middle Deck?
thanks
He said he ran the AME chassis with cut middle deck.
Thanks,
Old 02-05-2010, 02:19 PM   #18465
mlight13's Avatar
That was the ticket! Thank you Fllyer, now I can enjoy a quiet car. I never had that happen on any of my cars before, but there is always a first for everything I suppose.
Mark
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
