Old 11-11-2005, 03:23 AM   #1831
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
My ride
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 11-11-2005, 09:49 AM   #1832
nordheim's Avatar
Originally Posted by rc-zombies
I just checked mine too...5 holes..
old setup sheet was incorrect...
Mine only has 4. Looks like the fifth hole is added on the inside. The spacing looks the same.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 11-11-2005, 10:06 AM   #1833
whats the final drive ratio....thanks
Bobby J is offline   Reply With Quote
Old 11-11-2005, 10:31 AM   #1834
rc-zombies's Avatar
same as Pro4's.. 2.4375
Old 11-11-2005, 10:49 AM   #1835
Word
Old 11-11-2005, 02:13 PM   #1836
Skill's Avatar
Strange...mine has 5...
Skill is offline   Reply With Quote
Old 11-11-2005, 09:23 PM   #1837
pucho's Avatar
Send a message via AIM to pucho
Are those Pro4 outdrives in the front? I spoke with Hara at the nats he told me they would work but in the rear only, wich was strange to me because it should be tha same front and rear. He also told me that the Pro4 spool would work but with lots of shimming and Pro4 axels. What have you guys foun out reguarding this?
Originally Posted by Nexus Racing
Here is the car I have been racing on carpet the last month or so :
pucho is offline   Reply With Quote
Old 11-11-2005, 11:53 PM   #1838
rc-zombies's Avatar
the Pro4 outdrives will require alot of shimming as well. to build the front diff better to stay with the stock outdrives...same delrin material as the pro4 but in black. the Pro4 spools wears out fairly quickly...now that the TIR Spool is available... the best one to get..plus it has replacable outdrives with an option to choose between aluminum or delrin drive cups.
Old 11-12-2005, 12:16 AM   #1839
Skill's Avatar
Raced my Cyclone for the 3rd time on foam tyres. The other 2 times I've run on foams the car has been horrible, with way too much steering. I ended up finding a very good setup, which although still gave me a little bit of twitchiness out of the corners was very good. I should have finished 2nd in the top final but crashed on the last corner to see 2 people go straight past!
I'll post my setup a bit later in case anyone wants to use it...
Old 11-12-2005, 05:05 AM   #1840
Skill's Avatar
OK here's my setup, still has a little twitchiness out of the corners but worked quite well for me.
Old 11-12-2005, 08:17 AM   #1841
Please help, I drive rubber on carpet, so far the car is very nervous and difficult to drive, set up is base on Hara Reedy race Asia with some miner changes. We try many things but only help a little bit, the car remain nervous. I use KO 2365(very fast) servo, can this be the cause of the problem?Also the car make strange noise when acelerates out of corner, it seems the noise comes from the belts,any ideas why. Thanks
caveman is offline   Reply With Quote
Old 11-12-2005, 08:25 AM   #1842
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
try hara's rubber vegas tire set-up. its on top of page 40.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 11-12-2005, 08:29 AM   #1843
Skill's Avatar
For rubbers on carpet I'm using Sorex 24R tyres with LRP Top Traction additive. Stock setup except no rear sway bar and the rear shocks laid in 1 more hole. Try turning down the steering travel on your transmitter, and also the steering curve if you can do so.
If the car is making a clicking noise under acceleration which is coming from the rear belt then try tightening it a bit, using the hex shaped bearing holders on the rear diff.
Old 11-12-2005, 09:59 AM   #1844
rc-zombies's Avatar
All of Hara's carpet set-up for both Rubber and Foam tires can be downloaded from the HPI Japan site or the HB site.
Asphalt set-ups can be downloaded as well.
Old 11-12-2005, 03:12 PM   #1845
i ran stock yesterday and the car handled very well (right on the money).... back of the manual settings. i just changed the droop to compensate for ride height. from this settings..... how would hara's stock settings differ in terms of handling?
thanks all in advance.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
