Old 01-27-2010, 10:07 AM   #18391
Originally Posted by michael.branth View Post
HI,
This is a carpet set-up I used last night, It got me much closer to the A finla than the others I have tried. Still not there but read on, The only thing I would say is I measured the droop from the front of the wish bone, but since the car has anti-dive it would be even lower. I increased the droop for the finla race and the car was really getting there for me- Thanks every one who has pitched in with this:
Front:
Spring: HPI White
Oil: Edit 50 wt
Piston: HB 2 hole
Shock position: 3 on tower, 2 on arm
Camber: 1.0 deg
Camber Link position: long
Shims under camber link: 1mm
Caster: 4 deg
Suspension blocks: 1.5deg FF
Shims under suspension blocks: 1.5mmRear 1mm Front
Droop: 7mm on a droop gauge, measured at the arm right under the outer hinge pin
Ride height: 5mm
Swaybar: 1.4mm,
Front Drive: Ver 3 spool, steel drive cups, MIP's
Wheelbase: 2mm behind arm ( long base)
Wheel Hex:
Rear:
Spring: HPI Silver
Oil: Losi 35 wt
Piston: HB 2 hole
Shock position: 3 on tower and 3 on arm
Camber: 1.5 deg
Camber Link Position: Long on bulkhead, short on hub (standard setup)
Shims under camber link: 3mm
Rear Toe Block: 3 deg
Shims under toe/suspension blocks: 1mm
Droop: 6mm on gauge
Ride Height: 5mm
Swaybar: 1.2mm
Wheelbase: 2mm in front of arm, .7 behind. 2mm in front of hub carrier, .7 behind.
Wheel hex: standard
Other:
Cut top deck
FRP Mid deck cut
Steering bellcrank shim: 4mm
Tires: sweep 32
Body: Protoform Mazda 6
I am ready to dial some more steering inot the car as well as take the anti-dive away so smooth out the steering through out the corner, But I will be running about 7mm front droop to start.
Other things I will be trying areand in this order one at a time)
Full re-bound in all shocks to get responsiveness back
2mm under rear ball stud- just to stop it running out of travel late in the corner.
2mm under front ball stud- to smooth transition
Standing the rear shocks up
Softer front springs
any other ideas to try appricated - and hope its of inspiration to others,
Mi
hmm your from the uk right ? i see your running sweep 32's , ive always used sorex 24's on carpet , do the 32's provide enough grip ? or are you running additive ? is your track permanent too or setup in a hall etc ?
madwestmo is offline   Reply With Quote
Old 01-27-2010, 11:41 AM   #18392
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
HI,
Front:
Spring: HPI White
Oil: Edit 50 wt
Piston: HB 2 hole
Camber: 1.0 deg
Caster: 4 deg
Ride height: 5mm
Swaybar: 1.4mm,
Wheel Hex:
Rear:
Spring: HPI Silver
Oil: Losi 35 wt
Piston: HB 2 hole
Camber: 1.5 deg
Droop: 6mm on gauge
Ride Height: 5mm
Swaybar: 1.2mm
Wheel hex: standard
Other:
Cut top deck
FRP Mid deck cut
Tires: sweep 32
Mi
Any swaybar gap on front or rear?
What rear diff outdrives (plastic or aluminium)?
Have you tried:
-- Solid middle deck (currently cut)?
-- Ackermann = 2mm (currently 4mm)?
-- Rear toe block = 2.5degs (currently 3.0degs)?
-- Front ride height, slightly lower than rear (currently same at 5mm)?
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 01-27-2010, 11:58 AM   #18393
Hi yeah plenty of grip, I've only raced at the club may 5 times now but most people are on sorex32, even going to sorex 36 in summer. The sweep where the only 32 I had. The track is non premanent but we do keep the same track design for a few weeks, so some traction does build off.
I was running nosram carpet additive, full front and rear, then half front later when the grip came up.
michael.branth is offline   Reply With Quote
Old 01-27-2010, 04:45 PM   #18394
trickd122's Avatar
Default hub carrier
When adding shims on the Hub carrier does more shims in front translate to more or less traction?
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 01-28-2010, 05:03 AM   #18395
ah maybe thats why everyone at my club runs sorex 24's .... no additive
Old 01-28-2010, 05:16 AM   #18396
trickd122's Avatar
Default Whats the difference
Whats the difference between the Old sway bars and the new ones
Old 01-28-2010, 07:27 AM   #18397
Originally Posted by Korey Harbke View Post
Change the shims under the camber link to 3mm front, and 2.0mm rear. Maybe stand the rear shock up a hole. That should be pretty good!
-Korey
korey what rebound do you use on your carpet setup you posted on here ?
Old 01-28-2010, 12:07 PM   #18398
Korey Harbke's Avatar
Zero rebound . I don't run the bladder foam, and I drilled a small hole in the shock cap to relieve pressure on top of the bladder.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-28-2010, 12:08 PM   #18399
You're talking under the camber link correct? Just on the outside on the hub? Thats basically like running fewer shims on the inner pivot on the camber link. Usually that will give you less initial grip, and more through the middle and exit of the corner.
-Korey
Old 01-28-2010, 12:12 PM   #18400
The new mounts allow you to adjust swaybar tweak really easy. Sometimes swaybars aren't perfectly flat, and these allow you to adjust for that. I check swaybar tweak by putting my car with no shocks of tires on a setup board. Then I lift up on one suspension, and see how much travel it takes to make the other arm to start lifting. Adjust the length of those links to make it equal.
I also adjust swaybar angle with this. You can lengthen the left and right links equally to get a little more angle on the swaybar. It makes it feel a little more progressive/softer when you have more angle, and linear/stiffer when it's more flat (the ballstud is tightened all the way down)
-Korey
Old 01-28-2010, 12:38 PM   #18401
jonny123's Avatar
Ive been using the older moorespeed ones. Never really had an issue with them being un-even. I like the design of the TC sway bars but the grub screw slips on the sway bar as you can't really tighten it up enough into the plastic. But hb make aluminium versions of the new sway bar holders too.
Hth
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 01-28-2010, 01:46 PM   #18402
tc3 racer sc's Avatar
Hth
Jonny
as of now barry baker tq in 13.5 at the birds if im not wrong 26 laps my hotbodies tc doing ok need more speed here at the birds
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 01-28-2010, 01:58 PM   #18403
ShaunMac's Avatar
Sounds like you need some TEKIN.
ShaunMac is offline   Reply With Quote
Old 01-28-2010, 05:53 PM   #18404
gixer's Avatar
Hi guys,
Not too happy with the HB ball studs, a few slight impacts and they just shear off.
I've ordered a set of the 3racing titanium ones so hopefully these are a little better.
Next question is though, what ball cups are best?
Should i just stick with the A302's, or is there anything better out there please?
Cheers
Mark
HB Cyclone (WCE Exotek) x 2, Pro3 (Penguin chassis), Pro4, M-04M (Eunos Roadster)
Losi MRC, Axial XR-10
ERevo Erbe, HPI Firestorm (Nitro), Blitz,
gixer is offline   Reply With Quote
Old 01-28-2010, 07:22 PM   #18405
trickd122's Avatar
-Korey
Not exactly what I was asking I guess I needed to be more descriptive. I was actually refering to the shims on the hinge pins on the rear upright side. Now what effect does this have?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
