Old 01-14-2010, 12:38 AM   #18286
decibels's Avatar
Originally Posted by Korey Harbke View Post
I haven't tried the older top deck before, so I have nothing to compare it to. Talking with Hiro, they are very similar. I doubt I would be able to tell a difference between the two to be honest.
I cut my upper deck because it smoothed the car out a bit, especially in high grip tracks. It does feel like it creates more grip in the middle and exit of the corner to me, so sometimes you might have to make a setup change or two to get the overall effect you are aiming for.
-Korey
well i actually run the original black cyclone top deck but i cut it through the middle as well as i preferred the stiff feeling more. befor i cut it the car had a tad off understeer at speed on low grip tracks and after cutting it is really nice now. i always run it over the tc deck and i have a cut one as well. plus i cut the rear alloy mid deck so it is stiff front to back but flexes a little side to side. And i get the added benefits of extra motor cooling. I really like this setup whenever i change it sometimes the car feels better but it is slow. I also run slightly lower roll centres only .5mm to 1mm under toe blocks all round.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 01-14-2010, 01:31 AM   #18287
AGNO's Avatar
Originally Posted by Sparx View Post
Apparently the Xray guys are spacing the shocks quite often to change the behaviour of the car..
I didn't think it'd make that big (or at all..) until i tried it a couple of weeks ago.
Mounting the rear shock closer to the tower creates a bit more steering.
I think that shift the burden of the shock affects the center of gravity will move back spot behind the C of G (decreases the power steering), rewinding the scrap, the C of G increases the steering, as I said Tommy.
The same (reversed) for the front shock absorbers.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-14-2010, 09:06 AM   #18288
RC MARKET's Avatar
Purple LED Pit Light arrived !
RC MARKET is offline   Reply With Quote
Old 01-15-2010, 10:41 AM   #18289
Luppi Stefano's Avatar
Hi guys!
Exotek conversion, requires special set-ups to make better?
Requires a set-up more different from the original TC?
thanks
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 01-17-2010, 10:42 AM   #18290
Trader Rating: 66 (100%+)
Default VTA set up
Anyone got a good starting set up for vta with a cyclone running lipo/21.5 on a small med/high grip carpet?
Gwoodrc is offline   Reply With Quote
Old 01-17-2010, 05:04 PM   #18291
Troy Pinkston's Avatar
I'm looking for the same thing. I have a S that I put the TC chassis on. Running the S top deck.
Troy Pinkston is offline   Reply With Quote
Old 01-17-2010, 10:27 PM   #18292
SpidarX's Avatar
Has anyone ever used 30mm rear tires on their cyclone tc before?
Where I run, we use nitro foam tires on asphalt. The rear wheels are 30mm wide, but I'm having clearance issues when running the 30mm wheels. The wheel rubs on the camber link ball stud. Does anyone have any suggestions? Thanks
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 01-17-2010, 10:37 PM   #18293
Jazza's Avatar
Trader Rating: 16 (100%+)
Default 30mm tyres
Spidar X, put the 30mm tyres on a tyre truer.
Turn it on, use a set of calipers set at 26mm
to mark the tyres & then cut them with a stanley knife through the foam & rim at the 26mm mark. Presto 26mm all round.
Cheers Daz
Jazza is offline   Reply With Quote
Old 01-18-2010, 05:53 AM   #18294
Iceman 69's Avatar
try getting the +2 degree offset on the rims and that should sort out your problem,
Cyclone TC~SP GT pro~10.5????????
Cyclone ~ RS Pro ~ SP13.5 V3
Cyclone ~ Spare
Iceman 69 is offline   Reply With Quote
Old 01-18-2010, 11:02 AM   #18295
SpidarX's Avatar
Good idea. I'll look at trying this. I also may have to shave the ball cup on the camber link.
Maclan Racing
Old 01-18-2010, 01:03 PM   #18296
Default Moorespeed and TC
Hi Guys,
I ve just bought a moore speed edition to strip for spares, I know the shock towers and upper bulkheads won'nt fit, what about everything else?
I think I seen the chassis may not fit?
Also there is 2mm in the shock mount height what does this achieve?
thanks again for all the help, its keeping me on the HB side
michael.branth is offline   Reply With Quote
Old 01-19-2010, 01:39 PM   #18297
Korey Harbke's Avatar
Originally Posted by michael.branth View Post
Hi Guys,
If you take the upper bulkheads and the shock towers together, and put them on the cyclone TC they work fine. The Cyclone TC upper bulkheads were beefed up, but when they added material, they had to move the shock tower mounting location 2mm higher. To counteract that, we use the shock towers that are 2mm lower so the overall height is the same as the moorespeed edition.
So... just for ease of reference:
Moorespeed upper bulkheads + moorsespeed shock towers (and older cyclone shock towers) = stock geometry
Cyclone TC upper bullheads + Cyclone TC shock towers = Stock geometry
Moorespeed upper bulkheads + cyclone TC towers = 2mm lower than stock geometry.
Note: I have heard this can have some benefits in super high traction conditions, but I have never tried it personally. It would also allow you to lower your body more for foam tire carpet racing, but even the stock stuff is pretty low as it is.
As far as everything else, everything else can transfer over. The diff from the moorespeec can go into the TC, but it isn't anywhere near as good as the prospec diff that comes in the cyclone TC. You can't mix parts between the differentials though.
Arms, knuckles, caster blocks, rear hubs, hinge pins, chassis, upper deck, ect... all transfer over.
Hope that helps some
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-19-2010, 02:04 PM   #18298
bukil's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Luppi Stefano View Post
Hi guys!
thanks
Yes, it needs a little bit of tweaking. I run mine. It works pretty good.
bukil is offline   Reply With Quote
Old 01-19-2010, 02:31 PM   #18299
Does anyone know which holes on TC arms (front and rear) exactly matches the holes on Moore Speed arms?
billythekid is offline   Reply With Quote
Old 01-19-2010, 02:57 PM   #18300
I think I posted this a LONG time ago, but I'll be happy to post again.
Front: inside to outside holes
#4 on TC arms = #2 on old arms
#3 on TC arms
#2 on TC arms = #1 on old arms
#1 on TC arms
Rear: inside to outside holes
#5 on TC arms = #3 on old arms
#4 on TC arms
#3 on TC arms = #2 on old arms
#2 on TC arms
#1 on TC arms = #1 on old arms
The positions without an equivalent position on the older arms are "inbetweeners" Hope that helps!
-Korey
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
