Old 12-21-2009, 07:52 AM   #18061
jag88's Avatar
Korey, could you tell me if cutting the top plate would be a benefit on a carpet track with medium to high grip using Jaco blues all around ? I'm running 17.5 . I'm also running the lipo top deck.
Thanks.
jag88 is offline   Reply With Quote
Old 12-21-2009, 08:27 AM   #18062
Protus's Avatar
I am in need of an Exotek HBX but can't find any in stock. Does anyone know of a place that has them in stock?
George H. - www.youtube.com/user/protusx
The Coliseum at Hobbytown USA - Frederick, MD
I Survived the 2010 24 Hours of Jackson!!!
Protus is offline   Reply With Quote
Old 12-21-2009, 08:45 AM   #18063
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi,
Stormer Hobbies will get their reorder of these this week, possibly Wednesday
Thanks!
Mike
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-21-2009, 08:52 AM   #18064
Protus's Avatar
Originally Posted by MikeR View Post
Hi,
Thanks!
Mike
Great, I already signed up for their notification. Good to know they'll ahve them soon.
Old 12-21-2009, 09:26 AM   #18065
Originally Posted by jag88 View Post
I tried this for the first time yesterday. I was very impressed with how easy it was to drive.
Lap times were faster too ! (carpet, rubber)
That's great to hear you had good result with the mod. I still recommend to start with the stock one every time you go to find good setup. Stock 42.0mm is still the best width to start with.
Hi-LowBlow is offline   Reply With Quote
Old 12-21-2009, 09:46 AM   #18066
cheehtae's Avatar
Trader Rating: 15 (100%+)
I'm also thinking of getting an exotek HBX chassis, whta's the feedback on this?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-21-2009, 11:06 AM   #18067
Korey Harbke's Avatar
Jag88-
I'm a little different than some of the people on the team. Some like a tick more flex in high grip conditions to smooth out the car, but I feel it makes the car become unresponsive to setup changes when the grip is really high. I generally run a full upper deck, and mid deck.... sometimes with ATC posts. It just makes the car a little more responsive to setup changes, and I got better corner speed through the middle of the corner like that.
But... everyone is different . So I would get a spare upper deck and cut it to try out. They only take a few seconds to change out. It would be a really easy back to back comparison.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-21-2009, 10:30 PM   #18068
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Hi,
I'm looking for a 17.5T motor for use on a large, outdoor, high grip, asphalt track. I want to gear it for high speed in the straight. I have an SPX (profile 7). Anyone have any comments on the following ??
  • Novak Ballistic Spec Brushless Motor 17.5T
  • Team Checkpoint 17.5T Brushless Spec Motor
  • Trinity Nemesis Spec Brushless Motor 17.5T
  • Team Epic Duo 2 Spec Brushless Motor 17.5T
Thanks in advance
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 12-21-2009, 11:43 PM   #18069
Default vintage setup
Hi everyone, I got an early present and am trying to set it up. It's a used Cyclone S, front diff, direct drive center, rear diff. the center pulleys are different sizes (16 & 18). When Igot it the 18/39 rear and 16/39 front so understeer was bad. I've since flipped it so the front is overdriven 2.1 ratio the rear is stock 2.4375. by the way iI used a 171 tooth Shumacher belt to make this work. But I'm unsure on the chassis setup right now I have 5mm ride height and 2mm droop, hpi vintage tires and a Pegassus 70' big fish body (71 Hemi Cuda). The local track is extremely smooth ozite with a sixty foot back straight. I'm used to 1/12 Tplate cars so not sure what to adjust to do what.
SETUP
0* front toe
3* rear toe
27t motor
27 pinion
110 spur
0 ackerman
no stabilizers front or rear
right now it still pushs through any corners
broqenjeep is offline   Reply With Quote
Old 12-22-2009, 04:02 AM   #18070
cheehtae's Avatar
what servo horn are you guys using?
Old 12-22-2009, 06:55 AM   #18071
POUNDITRACING's Avatar
SETUP
0* front toe
3* rear toe
27t motor
27 pinion
110 spur
0 ackerman
Are you you running RCGT?
What are your shhock settings IE: Springs, oil, pistons, rebound, and positions on the car?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 12-22-2009, 07:38 AM   #18072
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
in both my cyclones, i'm using the stock plastic ones that came in the kit...
I have both a black cyclone and a Cyclone TC and both work fine
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-22-2009, 12:53 PM   #18073
kentech's Avatar
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 12-22-2009, 01:29 PM   #18074
Scott B's Avatar
Trader Rating: 42 (100%+)
Looks like a stock TC chassis too me!!
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 12-22-2009, 02:27 PM   #18075
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by kentech View Post
Interesting chassis on Atsushi's car...
Any other changes?
better pic http://kentech.blogs.se/
Speed passion motor?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
