Old 12-16-2009, 01:50 PM   #18001
EJ20's Avatar
Originally Posted by billythekid View Post
Any video of the races?
Youtube.com!
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 12-16-2009, 08:22 PM   #18002
Korey Harbke's Avatar
Originally Posted by thejo3 View Post
What's the difference between the suspension mounts with 0, 1, 1.5, 2, 2.5 and 3 deg. ?
When should we use one more than another and which in front and rear ?
I usually always run the 3 deg suspension mount in the rear. This gives 3 deg of toe in, which is the preferred setting for most classes. It provides very stable cornering, and good balance. Sometimes if I want to free up the rear end, I run the 2 or 2.5 deg rear block. This will give the car more steering through the middle and exit.
For the front, I usually start with the 1.5 deg block. This gives 1.5 deg of arm sweep. When you run less arm sweep (0 or 1 deg suspension mount), this will make the car enter the corner more aggressive, but be smoother through the middle and exit of the corner. The more sweep you run (2, 2.5, or 3 deg) will give slightly smoother steering on entry, but have more steering through the middle and exit of the corner.
Hope that helps!
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-17-2009, 02:17 AM   #18003
AGNO's Avatar
Originally Posted by Hi-LowBlow View Post
Sorry AGNO, the droop measured from the setup board to the top of the axle. You can measure it with caliper or ruler.
Thanks,
I'm sorry but I still have some questions to lead: what are the "2.0deg blocks" and the tires are the Solaris? and if that strength?
Thanks in advance
AGNO is offline   Reply With Quote
Old 12-17-2009, 05:11 AM   #18004
ali_g's Avatar
No problem George!
I need to add info that option parts Barry had on his cars.
- DCJ Drive Shafts (used in front)
- Low friction Shock Bodies
- Aluminum Diff Out drives
- HPI Shock Springs (gold up front/Silver in rear)
- HB's ceramic diff balls
- 4mm Hex hubs (used in front)
Hi I noticed that Barry is using 2.0 deg on FF and FR block. What's the effect compared to the stock FF FR blocks?
ali_g is offline   Reply With Quote
Old 12-17-2009, 06:20 AM   #18005
Trader Rating: 18 (100%+)
Yes thanks
Question related to that.
What is the difference (or not) between the toe-in given by the suspension mount, from the turnbuckles and the C-hubs ??
thejo3 is offline   Reply With Quote
Old 12-17-2009, 07:31 AM   #18006
Is there a setup for Barry 13.5 car? if yes please post.
Ramyuras is offline   Reply With Quote
Old 12-17-2009, 08:31 AM   #18007
cyclone x's Avatar
i have alot of hotbodies stuff for sale pm me if ur looking for something
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 12-17-2009, 08:36 AM   #18008
Juan C Munoz's Avatar
Barry Baker KO Grand Prix 2009 Winning Setup (13.5).pdf
Juan C Munoz is offline   Reply With Quote
Old 12-17-2009, 08:55 AM   #18009
Hi Ali,
The difference between using the 2.0 deg blocks for FF/FR and the stock block is that the hinge pin width. With using 2.0 deg block for both FF/FR, we can widen the hinge pin width to 44.8mm. (Stock one is 42mm)
The benefit on using wider block is that we will be able to go softer overall but still not much roll. I can also say the front end will have more stability that will eventually generates more crispier turn in.
We have been trying this for long time and getting very good result with it.
To do this, you will have to make another two holes on the chassis to put the block on, and you will have to dremel the block due to the interference with both steering linkage and front drive belt.
You can also choose the width 43mm by using 1.5 deg block.
Let me know if you need further info.
Thank you.
Hi-LowBlow is offline   Reply With Quote
Old 12-17-2009, 09:40 AM   #18010
jag88's Avatar
Hi Ali,
Thank you.
how does that effect the rear toe angle ? How do you get back to 3 degrees rear toe ?
What width hex do you use also what is over all width (190 ?) ?
Thanks.
jag88 is offline   Reply With Quote
Old 12-17-2009, 09:47 AM   #18011
AGNO's Avatar
Hi Ali,
Thank you.
In practice it widens the roadway but having 0 of anterior open arms?
If possible you might know the brand and tire compound.
Thanks in advance
Old 12-17-2009, 09:57 AM   #18012
burito's Avatar
Originally Posted by Barry Baker View Post
I was using the Airtronic M11x radio with Airtronics sevro and receiver.
I was using the LRP SPX in 13.5 and the LRP SXX in Modified.
Good boy...
Drop me an email if I can be of help in any way Barry, glad to hear you're back racing more often and that you're even winning again...
Reto Koenig
burito is offline   Reply With Quote
Old 12-17-2009, 11:17 AM   #18013
Originally Posted by burito View Post
Good boy...
RETO!!!
Old 12-17-2009, 11:44 AM   #18014
POUNDITRACING's Avatar
Hot Bodies Cyclone TC Anadized Black $275 shipped obo
http://www.rctech.net/forum/r-c-items-sale-trade/352709-f-s-hot-bodies-cyclone-tc-anadized-black.html#post6731995
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 12-17-2009, 01:39 PM   #18015
bukil's Avatar
Trader Rating: 37 (100%+)
Does anyone know why I can't set my regular Cyclone to 5mm ride height using TC shock towers? My shock rings are all the way up, and the ride height is 7-8mm.
Can someone shed a light to this confused soul?
bukil is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
