Old 11-18-2009, 06:03 PM   #17866
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by cosmo1974 View Post
Hi,
(1) At present, there is a practice day at the new outdoor asphalt track only once every two weeks; fortunately today was a practice day. Ambient temperatures were high at 37 degs C, with a track temp of 60 degs C.
(2) I'm glad to report that the TC behaved like a new car.
I was running the following setup:
-- Hara Thailand TITC 2009 setup
......(almost; no wheel spacer on rear, -1 toe, 5.5mm ride height F+R, R(hub)=2.0_0.5)
-- ATC posts on front (actually some metal PCB mounts + shims)
-- Cut top deck
-- Solid rear (middle) deck
-- Sorex 36 A-Firm inserts on Speedmind rims
Big improvement
Cheers
Korey,
(1) I'm still interested in your opinion on when to use (and not to use) the rear (middle) deck. I remember you saying that sometimes it works and sometimes not. I'm just wondering if there is a pattern (eg: super high grip is a dud, but medium grip is usually ok, or whatever).
(2) As you can see from my previous post, the mods I made were a BIG improvement (just wished I'd tried them sooner). I now know why all the HB Team Drivers are using a cut top deck
Thanks in advance
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 11-19-2009, 04:11 AM   #17867
masher's Avatar
Hi JR007
I've been running my Surikarn on foam outdoor asphault for ages now. I run 35 rears and 32 fronts most of the time. Most of our tracks are medium traction. I'll post a setup sheet that you can try as your starting point. So ask away and i'll try and assist you..
masher is offline   Reply With Quote
Old 11-19-2009, 01:09 PM   #17868
Dog Bone's Avatar
Originally Posted by Xchange View Post
hey guys... i just broke a frame on the rear.... this car is very frustrating!
Every time i touch, i broke!
3knuckle
2c-hub
1rear ingpin
1frame!!!!
Any one have the same problems like me?
This car is beautiful and work very fine but i ran aprox 15min total !!!
I feel your pain. Really, I do.
I should change my handle to 'Conan, Knuckle Destroyer'
I chew through knuckles like they're crackers. Touch a wall, *snap*. <grumble><grumble><wrench><wrench> back on the track, touch a wall, *snap*....later rinse repeat.
Morale of the story? Don't touch the walls. Easier said than done.
Dog Bone is offline   Reply With Quote
Old 11-19-2009, 02:57 PM   #17869
Lonestar's Avatar
Originally Posted by Lonestar View Post
er... anyone? Is it that stupid a question???
Thanks!
Paul
thanks for the info, guys. stiffer... mmh. I run on low-grip carpet tracks, I need the flex. Off to buy a stock deck I go.
thanks!
paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 11-19-2009, 03:13 PM   #17870
Originally Posted by masher View Post
Hi JR007
Awesome, thanks for that. I can't get to the track for a lot of practice, and we have our Nationals coming up in a few months. I like the feel of foams, and want to stay with them, I just need a starter for a set-up that gets me through without chewing tyres. I'm fast-ish, but sometimes look like i'm drifting not racing!
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 11-19-2009, 07:51 PM   #17871
rc pete's Avatar
thanks!
paul
If you already have the TC top deck, just cut it. It gets you pretty close the flex of the original top deck. Cut it lengthwise where the belt tensioner normally mounts. I don't run the belt tensioner on the TC... I haven't seen many who do.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-20-2009, 03:17 PM   #17872
Lonestar's Avatar
nope haven't purchased it yet... thanks for the tip
Paul
Old 11-20-2009, 07:03 PM   #17873
cosmo1974's Avatar
See cut top and rear deck photos at link below (supplied by Phil Chambers).
Hot Bodies Cyclone
Cheers
Old 11-22-2009, 03:00 AM   #17874
JL
Has anyone tried swapping the belts over on the Cyclone TC from one side to the other. It looks like it shouldn't be a problem.
JL is offline   Reply With Quote
Old 11-22-2009, 03:49 AM   #17875
jonny123's Avatar
Yes Phil C along with a few other of the guys in the Uk team have done it. They swap over fine u dont have to mod anything. I'm yet to try it.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 11-22-2009, 03:56 AM   #17876
JL
Jonny
Jonny, looking at the big cutouts under the diff it looks easy enough, however I've got the old cyclone chassis so it's either some dremelling or buying the TC main chassis to get it all to work.
Thanks mate.
Old 11-22-2009, 11:45 AM   #17877
jonny123's Avatar
JL, yes there would be quite abit of dremelling on the moorespeed/standard chassis. The Tc chassis is 2.5mm compared with the standard 2mm on the previous cars. I prefer the feel of the car both indoors and outdoors with the 2.5mm chassis. So maybe getting the TC chassis is the way to go.
Jonny
Old 11-22-2009, 05:56 PM   #17878
BIG RE's Avatar
Trader Rating: 31 (100%+)
Are there any other steering knuckles that can be modded to fit? I am just getting into carpet racing after 11 years of off-road, I have been borrowing a cyclone from Kendall Bennett, owner of amainhobbies. I have not driven any other cars, but I have tweaked the cyclone to a point where I really like it and would like to stay with the cyclone, I just want to make her more durable. I broke nothing on the first outing, but yesterday I broke 3 knuckles, a c-hub, and a cv bone. I am going to buy more knuckles when they come back in stock and build up a web of shoo-goo in the area that they always break, is anyone else doing this? Any other ideas? Thanks
BIG RE is offline   Reply With Quote
Old 11-22-2009, 08:38 PM   #17879
Scott B's Avatar
Trader Rating: 42 (100%+)
I have been running the Cyclone's since they came out and I don't remember any of them having a 2mm chassis.
And I just measured a few older chassis I have and they all measure 2.5mm.
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 11-22-2009, 10:08 PM   #17880
Korey Harbke's Avatar
The older style of chassis plates were still 2.5mm. They have smaller cell slot, and diff cut outs. They also have a slightly different material of carbon fiber as well.
The TC chassis plate is a little softer up front, but stiffer through the middle and rear of the chassis. The older style chassis plates are stiffer up front, but a little softer in the middle and rear.
Lately I've been running an older style chassis (fits my weight plate better ), but they require a different top deck setup. I run the TC topdeck cut where the belt tensioner is, or the older style upper deck. With the TC chassis, I run the TC top deck uncut. Each of those combos are similar in feel. I usually always run an FRP mid plate that is uncut. I find the car works in a wider range of conditions this way.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
