Old 11-16-2009, 08:40 PM   #17851
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Originally Posted by balistic View Post
I have run mine several times and took it to WCRCR last week and after a few min I grazed the outside wall and lost steering, veered across the straight and grazed the inside wall. from the stand I couldn't see the front wheel? I walked down and had snapped both front arms outside of the shock and both front wheels were inside the wind shield. most damage I have done to it and the softest hits, the irony of hidden damage.
that's funny.. the same thing happened to me.. same track... last Wednesday
I was coming too hot down the back straight with my RCGT TC and grazed the sweeper... broke the front arm on the left side... of course WCRCR was out of TC front arms.... had to use a Cyclone S front arm... meh
akura2 is offline   Reply With Quote
Old 11-16-2009, 08:58 PM   #17852
RCFREAK's Avatar
Trader Rating: 17 (100%+)
You may need to get creative.. i ended up making a front Kydex bumper from another manufacture, and left it a little wider than the stock foam bumper. This helped alot!!
As for arms breaking, try using softer arms... we have found using the HPI pro4 arms with lots of plastic/nylon rather than the harder newer graphite arms held up better...plus it should create more traction with softer arms..
And if you are breaking steering knuckles, try the optional aluminum HB ones... nice finish to the front end... Although i would stay away from the 3racing options, because the metal is weaker, and the geometry isn't exactly like the stock ones.....
Good Luck!!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 11-16-2009, 09:48 PM   #17853
rc pete's Avatar
If you're running the #2 position on the TC front arms, you simply have to keep it off the boards.
The #1 position keeps less pressure off the point where they snap off... but if you're doing that, do as suggested above: run the Pro4 / original cyclone front arms. The outside position on those is the same as the TC #1. If you like the feel of the #2 hole, you'll have to run 5W softer damping and one rate softer spring with the #1 hole... it's not exactly the same in the end, but it gets you close.
Having said that, on carpet, I run the #2 position on smooth high bite tracks and #1 on lower traction or rougher tracks... TC arms only and I've only gone through 3 front arms (well deserved hits too) over the last 4 major races and 20-odd club races.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-16-2009, 11:48 PM   #17854
vadersing's Avatar
Has anyone tried the exotekracing lipo chassis for Cyclone?
Some feedback please.
http://www.exotekracing.com/EXOTEK_N.../9/30_HBX.html
vadersing is offline   Reply With Quote
Old 11-17-2009, 12:17 AM   #17855
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
I've watched them run in pro classes and the car looked great. Very capable. I haven't drove one though.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-17-2009, 01:16 AM   #17856
TheCoolCanFanMan's Avatar
Yep, put one on my outside car, as the chassis needed replacing from the out door season, and popped the running gear straight on the lipo chassis to use indoors. The one difference was that you can make the front of the car 0.75mm longer, and I also run the bat strap, coz I hate the tape idea and always have.
Used it for the first time in anger on a Sunday indoor series in the UK, and put it 4th in the A, and took the win in the first final, and second on in the second final, which gave me the win on the day
The car seems to be more responsive, and transition is better than the standard chassis with cell slots in it.
The chassis is also 11m narrower and is 2mm thick instead of the 2.5mm standard one.
Overal very impressed with with it, I may buy one for my newer car
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 11-17-2009, 05:50 AM   #17857
Wow awesome post.
Thanks for sharing with us
[url=www.ebcbrakes.com/motorcycle_brake/custom_rotors_american_motorcycle/harley_conversion.shtml]harley brakes[/url]
harleybrakes is offline   Reply With Quote
Old 11-17-2009, 06:29 AM   #17858
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Hi,
(1) Has any tried the following product in the TC Rear Diff ??
-- Ceramic Grooved Thrust Bearing 2x6x3mm with 8 x 1.5mm balls
by RC Hobby and available at RC MARKET.
http://rcmarket.com.hk/product_info....q2egblvj97um82
(2) The kit TC Rear Diff is a slightly different configuration.
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/[email protected],138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 11-17-2009, 08:55 AM   #17859
Lonestar's Avatar
Originally Posted by Lonestar View Post
Hey guys
I broke my cyclone hara's upper deck the other day (ouch). Is there a point replacing it by a TC's (I still have the stock lower deck) or shall I stick to the stock one? Do they have the same mounting specs anyway?
Thanks!
Paul
er... anyone? Is it that stupid a question???
Thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 11-17-2009, 09:21 AM   #17860
EJ20's Avatar
Thanks!
Paul
Hi Paul, the TC top deck has same mounting holes on it and I think it's a slightly stiffer than the Hara's top deck and it's little cheaper too.
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 11-17-2009, 10:10 AM   #17861
SNIPR's Avatar
I have been eying this chassis myself - thanks so much for the helpful reply..! I have heard through the grapevine that HB is coming out with its own lipo chassis as well..?
Cheers Malc
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 11-17-2009, 10:26 AM   #17862
Korey Harbke's Avatar
Yup! TC top deck drops right on. Its made from a slightly different carbon fiber product. I think I remember the resin being a little different, so it's a tick stiffer.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-17-2009, 12:52 PM   #17863
RC MARKET's Avatar
Originally Posted by cosmo1974 View Post
Hi,
Cheers
This Thrust ball bearing 2x6x3 is for old ver. Cyclone ball diff.
New ver. Cyclone TC ball diff isn't fit.
Thanks !
RC MARKET is offline   Reply With Quote
Old 11-18-2009, 03:36 PM   #17864
I'm trying foams on my Surikarn and looking for an outdoor asphalt set-up to start with. I used them the other weekend and had a real loose rear and coned foams, so am keen to go back to scratch rather than try and tweak my set-up.
The track is a very large outdoor asphalt track (1/8 nitro international spec), and down here the temperature is fairly consistent, not that that is a big deal for foams as far as I know.
I'm running in a 13.5 class, currently with NiMh, but will be going to Lipo soon.
The foams I have been running are 30sh rear and 32sh front, is that too soft for a start?
Lots of questions, need lots of answers
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 11-18-2009, 04:56 PM   #17865
cosmo1974's Avatar
Thanks !
Thanks for the information
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
