Old 11-10-2009, 12:48 AM   #17836
Trader Rating: 19 (100%+)
Originally Posted by a.seffrood View Post
just wondering if anyone else has had cvd's problem as i have broken the front two?
I broke a "Titanium Racing Products" cvd recently and a fairly light brush with a plastic pipe, have now changed back to hotbodies ones now,cheers.
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 11-10-2009, 07:18 AM   #17837
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
what do you guys think about the DCJ drive shafts?
is it good for drifting since its a 3-piece drive shaft and in drifting we have a lot of steering angle and recently I have been hearing a grinding noise at full lock when I drift
kriiiss is offline   Reply With Quote
Old 11-10-2009, 11:28 PM   #17838
decibels's Avatar
yeh the dcj's will eliminate the chatter you are hearing!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 11-11-2009, 12:55 PM   #17839
Hey guys!
just curious, got a cyclone off of a guy and I am thinking of upgrading the motor and esc to a novak gtb system or an Orion, and my question is what is a good gearing that some of you run to get speeds around 60mph?
i am totally new to the electric stuff and gearing confuses me
Mista Mustard is offline   Reply With Quote
Old 11-11-2009, 02:42 PM   #17840
SpidarX's Avatar
Originally Posted by Mista Mustard View Post
Hey guys!
That would depend on what turn motor your are running. Are you planning on running a 3.5?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 11-11-2009, 04:01 PM   #17841
I am actually not sure, I was looking at the 3.5r that they package with an esc. Right now the car has an hpi motiv system and I have no clue what turn it is.
the kind of racing I have gotten into is mostly setting up fairly large courses in a huge parking lot. usually a sweeper and a few chicanes and a long straight. This is because the league that was starting up had problems with the hobby shop and ended up not happening so we kinda formed our own.
Old 11-16-2009, 06:39 AM   #17842
Lonestar's Avatar
Hey guys
I broke my cyclone hara's upper deck the other day (ouch). Is there a point replacing it by a TC's (I still have the stock lower deck) or shall I stick to the stock one? Do they have the same mounting specs anyway?
Thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 11-16-2009, 02:35 PM   #17843
Has anyone driven the new HB Gumball premounted tires?
They don't list any information about the tire compound or tire temperature range. Are they like other companies 28r or 36r?
They have better availability than Sorex at our tracks hobby shop.
Eddie_E is offline   Reply With Quote
Old 11-16-2009, 02:52 PM   #17844
RCFREAK's Avatar
Trader Rating: 17 (100%+)
The gumballs are spec tire for HPI races. When new in package, they feel almost like plastic!! but when everyone has to run the same tire, there is no advantage..
On the other hand we ran them at 301 raceway where the track is permanent and high traction!! they actually performed outstanding!! and no tire wear at all!! ran one set in mod class running a 4.5orion motor, TQ'd that weekend.....
Open nitro sedan lap times with foam tires between 20 sec to 23 sec... we ran full track also with no shortcuts and ran gumballs with 24 second lap times... not too bad with these tires...but the grip HAS to be there!!
they almost feel like between 32 and 36 shore rubber tires..
hope this helps.
BTW..we still used tire warmers, for about 10-15 minutes before we ran..
And the tires are glued really good!!!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 11-16-2009, 03:04 PM   #17845
jag88's Avatar
I also believe they are a non-belted tire.
jag88 is offline   Reply With Quote
Old 11-16-2009, 03:07 PM   #17846
RCFREAK's Avatar
yup they are NOT belted!! with a 4.5 motor..... these things "Balloon up" talk about changing Rollout on the "FLY"!! hahaha you can almost see the ride height change on the back straight!!!hehehheehe
Arv.
Old 11-16-2009, 06:01 PM   #17847
TheCoolCanFanMan's Avatar
whats the best diff ballls to use in the HB TC ?
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 11-16-2009, 07:33 PM   #17848
rc pete's Avatar
Cheers Malc
The stock carbide balls are good. But the Hotbodies ceramic 3mm balls are better.
For the thrust balls, the stock carbide balls are surprisingly smooth and last much longer than I expected. In my XRay diffs I could only run ceramics, because carbides wouldn't cut it. I just got some Acer 1/16" thrust balls to try in the TC diff, but haven't installed them yet.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-16-2009, 07:40 PM   #17849
Xchange's Avatar
Trader Rating: 10 (92%+)
hey guys... i just broke a frame on the rear.... this car is very frustrating!
Every time i touch, i broke!
3knuckle
2c-hub
1rear ingpin
1frame!!!!
Any one have the same problems like me?
This car is beautiful and work very fine but i ran aprox 15min total !!!
Xchange is offline   Reply With Quote
Old 11-16-2009, 08:04 PM   #17850
balistic's Avatar
Trader Rating: 113 (100%+)
3knuckle
2c-hub
1rear ingpin
1frame!!!!
I have run mine several times and took it to WCRCR last week and after a few min I grazed the outside wall and lost steering, veered across the straight and grazed the inside wall. from the stand I couldn't see the front wheel? I walked down and had snapped both front arms outside of the shock and both front wheels were inside the wind shield. most damage I have done to it and the softest hits, the irony of hidden damage.
balistic is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
