Old 10-05-2009, 03:39 PM   #17581
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
car handled nice Mike.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 10-05-2009, 08:30 PM   #17582
Dang that Exotech chassis looks sweet! I love the lipo mounting setup, and the battery hold down strap. Hate taping batteries in. HB should be taking notes for their next revision of the car.
Not sure I can justify spending $100 for chassis and battery strap just for the limited VTA running I do. Maybe someday soon.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-06-2009, 07:24 AM   #17583
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
whats Exotech's website?
kriiiss is offline   Reply With Quote
Old 10-06-2009, 12:01 PM   #17584
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi,
www.exotekracing.com
thx, M
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-06-2009, 05:57 PM   #17585
dose anyone have or know a setup for low traction carpet foam tire for cyclone?
edplumber123 is offline   Reply With Quote
Old 10-06-2009, 06:26 PM   #17586
Trader Rating: 244 (99%+)
Originally Posted by MikeR View Post
Here is footage from a recent friendly race while running the Exotek HBX chassis in the yellow car....
http://gallery.me.com/iigq4u#100552
Car was super locked in while driving on a medium grip temporary track against factory drivers.
Thanks to IIGQ4U for the footage.
When will this be available?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 10-06-2009, 07:43 PM   #17587
SpidarX's Avatar
Hi, I just finished building a new TC, and I had a few build questions. I tried using search, but didn't find everything that I needed.
1) Should you put loctite on all the screws that go into the bulkheads? The instructions don't say to, but it seems like you would want to.
2) The sway bar ends on the front of the car come extremely close to hitting the drive shafts. What do people do to avoid this?
3) The steering linkage seems to rub on the FR suspension block. It looked like some people suggested sanding the block, but I don't want to mess up the purple It looks like once the weight of the car is on all 4 tires, then the steering linkage may clear better, but is there something else that can be done to help the clearance?
4) Finally, when mounting the shocks on the shock end balls, there is a lot of play left in the mounted shock. Are you supposed to tighten the shocks to the point where the shock end balls expand and take up the slop? I could do this on the shock tower, but I couldn't when tightening up the bottom shock mount on the a-arm.
Thanks in advance!
SpidarX is offline   Reply With Quote
Old 10-06-2009, 08:21 PM   #17588
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
>> i've put threadlock on the bottom screws only. the ones on top don't need it i think. also put threadlock on the lower screw holding the steering knuckle to the c-hub...
>> add the 2mm spacer to the front of the arms instead of behind them
>> when the chassis is on the ground on all 4 wheels, and after you set-up the droop, it should clear the suspension block by a fraction of an mm... but sanding it down is still a good idea to avoice any jamming during runs.
- i chucked the shock ball ends and used Xray's pivot bushings for the top and the longer lower shock ends with some 10mm grub screws...
hope this helps
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-06-2009, 09:14 PM   #17589
POUNDITRACING's Avatar
No need for locktight. You are putting a steel screw into a alum. bukhead.
You can turn the plastic part of the mount that connects to the bar.
Most set-ups call for 1.5mm under the blocks. That should makeit clear.
You can tighten the nut until the plastic takes up the play or you can buy http://www.hotbodiesonline.com/products/en/61326.html and not worry about the slop.
Thanks in advance!
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 10-07-2009, 07:53 AM   #17590
SpidarX's Avatar
Thanks for the help everyone.
Old 10-07-2009, 08:53 AM   #17591
MikeR's Avatar
This Friday
Old 10-07-2009, 09:00 AM   #17592
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Video can be seen below as well but the detail isn't as good.
+ YouTube Video
IIGQ4U is offline   Reply With Quote
Old 10-07-2009, 09:48 AM   #17593
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Just built a new TC, ready for this years first indoor race on sunday.
Wiring needs a lot more work, but the speedo is temporary so didn't feel like putting too much work into it..
http://img260.imageshack.us/img260/2306/dsc04495.jpg
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-07-2009, 10:27 AM   #17594
Korey Harbke's Avatar
This Friday
Car looked great Mike! I'll have to try one of these chassis out soon.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-07-2009, 11:28 AM   #17595
ZEe_NYC's Avatar
Trader Rating: 27 (100%+)
Mike R, sick driving dude.
if that second place dude (that you passed) wasn't holding you back, you'd be battling for first.
ZEe_NYC is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
