Old 09-28-2009, 12:32 AM   #17491
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Do the IP4200 trinity hardcase lipos fit in the Cyclone (i have a hara edition) just fine?
Weight: 8.29oz, or 235 grams
Length:5.43", or 134mm
Width: 1.84", or 47.8mm
Height: 0.92", or 23.3mm.
Syber Serulean is offline   Reply With Quote
Old 09-28-2009, 12:39 AM   #17492
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
IP4200 fit right in, i use the IP 5000 which need some filing on the right bulkhead when youre not using the plastic tray.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 09-28-2009, 12:39 AM   #17493
Korey Harbke's Avatar
Alright. I'm going to give a rundown of the shock positions since it seems to be a very commonly asked question.
From furthest out on the arm to the furthest inside
Front:
New #1
Old #1 = New #2
New #3
Old #2 = New #4
Rear:
Old #1 = New #1
New #2
Old #2 = New #3
New #4
Old #3 = New #5
The other changes on the TC just allow for more durable upper bulkheads. Because there is extra meat there, they had to raise the shock mounting point. So they made "lowered" shock towers to maintain the same overall geometry. So in the end, there isn't any change to the geometry of the suspension besides the new arms. Other changes include a slightly different chassis plate, some hardware differences, the 2 way diff, and the pro spec diff.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-28-2009, 12:46 AM   #17494
thanks!
Old 09-28-2009, 05:28 AM   #17495
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BlackedOutREVO View Post
Hes working to hard at Ford Thats the problem
Slaving is more like it....
The HB was working pretty well this weekend. I'll have my set up posted on gearchart later on today when I get some time. Korey gave me the set up and I tweaked it to fit.
Thanks Korey for all your help.
Hiro- Race report will come shortly. I'm still tired but I have to go to work now
STLNLST is offline   Reply With Quote
Old 09-28-2009, 07:33 PM   #17496
bukil's Avatar
Trader Rating: 37 (100%+)
Does anyone know where I can get a chassis protector for the cyclone TC?
bukil is offline   Reply With Quote
Old 09-28-2009, 07:52 PM   #17497
balistic's Avatar
Trader Rating: 113 (100%+)
I have two of these films, they are great;
rommel1977 ( 294 [Feedback score is 100 to 499] )
100.0%
eBay Store: Rommels R/C World
balistic is offline   Reply With Quote
Old 09-29-2009, 06:21 AM   #17498
Trader Rating: 52 (100%+)
hopefully someone can help me
just got an original cyclone(black edition) and i've been trying to get a rubber tire setup on the car. all the sheets i've found are showing 1.5mm under the hinge pin holders,in the front, the arm spacing is 2.3mm rear, .5mm front, and ackerman is 4mm. when i put this setup on the car, the steering tierods jam against the rear hinge pin block(they actually rub slightly with no spacing under the hinge pin block)
how do you get this setup to work or am i misunderstanding it ?
any help would be greatly appreciated
rcracer1958 is offline   Reply With Quote
Old 09-29-2009, 06:28 AM   #17499
Trader Rating: 65 (100%+)
Send a message via AIM to joey
when i ran a black cyclone i would dremel some material off the hinge pin block so it would not rub agaist the tie rod..
=Joe Wright=
joey is offline   Reply With Quote
Old 09-29-2009, 07:57 AM   #17500
POUNDITRACING's Avatar
Make sure that you are in the #2 hole on the axel carrier. It's the one away from the wheel.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 09-29-2009, 08:13 AM   #17501
dstyles's Avatar
yup, just dremel off the edge of the block under both steering tierods.
it's an easy fix.
dstyles is offline   Reply With Quote
Old 09-29-2009, 08:43 AM   #17502
i'll do that
just curious...is that 1.5 mm spacing under the hinge pin blocks the ticket for running rubber on carpet ?
running 17.5 brushless/5K lipo (already modded the bulkhead to fit the lipo)
just wondering if i need that much roll center height or not
thanks again
Old 09-29-2009, 08:56 AM   #17503
dstyles's Avatar
it's not the 'ticket' but it is part of the over all set-up.
from a couple of pages back:
The suspension blocks do change roll center and camber change characteristics much like the camber link shims do... but the shims under the suspension blocks have a much greater effect on roll center than it does on the camber change characteristics. More shims under the suspension blocks raises the roll center. This gives more initial grip, less roll, but less overall grip in the middle and exit of the corner. Think of it as if the car feels... stiffer. Fewer shims will lower the roll center. The result is a car that rolls more and has more overall grip in the middle and exit of the corner. It does smooth out the car entering the corner though.
Old 09-29-2009, 11:34 AM   #17504
what circumstance would i use 1mm or zero spacers under the suspension blocks ?
madwestmo is offline   Reply With Quote
Old 09-29-2009, 03:25 PM   #17505
When you want your car to roll a lot.
billythekid is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
