Old 09-16-2009, 03:41 AM   #17356
jarkkom's Avatar
Send a message via MSN to jarkkom
Does anyone have the setups from the IIC?
Also if someone has straight rear bulkheads lying around please send to me..
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 09-16-2009, 04:31 AM   #17357
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Originally Posted by Korey Harbke View Post
Well it's 2am, and I've finally finished a long drawn out search to figure out what the heck was tweaking my car so bad lately. I've noticed there was a tweak in mt car and no matter how many times I loosened all the bulkhead screws and tighten them back up, the car still had a twist.
As a result of my displeasure, I took apart the car entirely and slowly built it back up. Checking each piece of a sheet of glass to check to bent or tweaked parts. There were a few bulkheads in question, but that wasn't the case. It was a screw!!!! The screw itself was bent from some impact a long time ago. The bent screw was stressing the suspension block so much that it tweaked the chassis.
After that was figured out the overall tweak in the chassis was much better... Yet there was still a small amount left. I now loosened the servo mounts up and re tightened them down carefully. BINGO no more tweak.
I know this may seem kind of stupid of me to write this, but these are often very overlooked factors when maintaining your car. I try to tear my car down completely every month of racing. to check for bent bulkheads and whatnot.
-Korey
Its good to hear these war stories.
I'm sure it will help others diagnose like problems downstream.
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 09-16-2009, 05:30 AM   #17358
STLNLST's Avatar
Trader Rating: 19 (100%+)
Schumacher diff grease is BY FAR the best diff grease I've ever used. It doesn't break down anywhere near as fast as others, so it gives very consistent diff action throughout the run. Plus it's like a wax... it doesn't fling off, so it last for a long time inbetween rebuilds as well.
-Korey
I've said this for years and no one would listen to me. Maybe if I was as fast as you people would listen
-Korey
You might have finished earlier if I didn't keep texting you
STLNLST is offline   Reply With Quote
Old 09-16-2009, 06:36 AM   #17359
RCFREAK's Avatar
Trader Rating: 17 (100%+)
BENT SCREWS!!!!!!!!! gotta check mine then... car is off slightly. thanks for the tips... sorry for the war story!!
Arv.
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 09-16-2009, 11:03 PM   #17360
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Well, i think im proud to say that my Cyclone S is a pretty darn good car. I won the A with it 2 weeks ago in Stock 17.5 and had no problems with speed at GLARC this weekend(140+' straight). If i had a fully charged battery, i would have been in the top 3. Im using the plastic shocks as well as the dogbones. It has less adjustments than my Moorespeed Cyclone, but im enjoying the face that im actually winning with it against cars 2-3 times as much. Great product Hotbodies/HPI!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 09-17-2009, 12:30 AM   #17361
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
hey charlie got a setup sheet i can pass over to Chris Torley so he can put it on his Cyclone S?
glad to hear you're doing good with it. Stock 17.5? This means i coulda faced you outside of RCGT or do i got it wrong? hehe.
Syber Serulean is offline   Reply With Quote
Old 09-17-2009, 02:14 AM   #17362
Super Moderator
charlie_b's Avatar
Yes, this was outside RCGT...and man..the car just gets better and better as i run it. I think my Moorespeed is getting lonely.
Old 09-17-2009, 05:27 AM   #17363
lowcel's Avatar
Trader Rating: 80 (100%+)
Anybody using a ZIPPY Flightmax 5000mAh 2S1P 30C hardcase pack battery pack in their cyclone s? I would like to make sure it will fit before I order three of them. I haven't received my cyclone yet so I can't take measurements.
The battery measures 137x45x23mm.
Also, anyone try a Turnigy 5000mAh 2S 30C Lipo Pack by any chance? It measurements a little longer. It measures 143 x 49 x 16mm.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 09-17-2009, 12:30 PM   #17364
Does anyone know if 416's driveshafts and axle could fit right into Cyclone TC? I found these DCJ for 416.
http://www.egrracing.com/shop/cv-uni...16-p-3368.html
billythekid is offline   Reply With Quote
Old 09-17-2009, 12:55 PM   #17365
Trader Rating: 66 (100%+)
Send a message via AIM to joey
hotbodies makes them already...
http://www.speedtechrc.com/store/ebp...id=475&id=8509
=Joe Wright=
joey is offline   Reply With Quote
Old 09-17-2009, 01:52 PM   #17366
Originally Posted by joey View Post
They are always out of stock.
Old 09-17-2009, 03:55 PM   #17367
i am considering getting a the cyclone but have some questions as the last time i raced the losi xxx-s was what i raced... does anything need to be done to run lipo packs and if so what packs can i run? what breaks and what spares to buy? Also if there is anything that is needed to get the car ready for rubber carpet racing let me know.
jiggamacdaddy is offline   Reply With Quote
Old 09-17-2009, 06:09 PM   #17368
mickrcarver's Avatar
Trader Rating: 98 (100%+)
selling my brand new cyclone tc
new cyclone tc/extras
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is offline   Reply With Quote
Old 09-17-2009, 07:29 PM   #17369
artwork's Avatar
Trader Rating: 56 (100%+)
IIC 13.5 Carpet setup...Car was very easy to drive and worked great. Wish I would have finished a little better, but sometimes that is how it goes. My Mod car was very close to this setup. If anyone wants It I can post the mod setup as well.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 09-17-2009, 07:45 PM   #17370
Scott B's Avatar
Trader Rating: 42 (100%+)
Some of the lower profile lipos fit no problem, like the TP 3200, SMC 4100, Orion 3800, 5200. As for the larger profile lipos you can mill or just dremal the bottom of the middle right bulkhead were it goes over the battery or you can get the new lipo topdeck with new middle right bulkhead...
http://www.hotbodiesonline.com/piw.p...=67695&lang=en
The Cyclone TC will work great out of the box for rubber carpet racing. As for spares I would get steering knuckles, castor blocks and I would suggest getting the original cyclone front arms to replace the TC arms as the TC arms are not a strong as the original ones plus I hear they give you more steering.
http://www.hotbodiesonline.com/piw.p...=73506&lang=en
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
