Old 09-11-2009, 09:42 PM   #17341
Korey Harbke's Avatar
You hit the nail on the head!
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-15-2009, 06:18 AM   #17342
Coldn's Avatar
Send a message via MSN to Coldn
Hello peplo
what is the better grease for diff and trhust pro spec with ceramic balls??
I using the Associated but with motor 4.0 I note that I losse control in 10min (2 finals)
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 09-15-2009, 06:27 AM   #17343
artwork's Avatar
Trader Rating: 60 (100%+)
Originally Posted by Coldn View Post
Hello peplo
Try either the Corally or the Schumacher grease.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-15-2009, 07:37 AM   #17344
Coldn's Avatar
the "Moly Axle Grease - Pot" is that??
Nanotech 6000mah
Old 09-15-2009, 07:43 AM   #17345
artwork's Avatar
http://demonpowerproducts.co.uk/prod...oducts_id=4490
Old 09-15-2009, 07:49 AM   #17346
Coldn's Avatar
thank you very much!!!
Nanotech 6000mah
Old 09-15-2009, 08:47 AM   #17347
Schumacher diff grease is BY FAR the best diff grease I've ever used. It doesn't break down anywhere near as fast as others, so it gives very consistent diff action throughout the run. Plus it's like a wax... it doesn't fling off, so it last for a long time inbetween rebuilds as well.
-Korey
Old 09-15-2009, 11:43 AM   #17348
Coldn's Avatar
-Korey
hellooo Korey and artwork.. do you know if schumacher have a trust grease?
Nanotech 6000mah
Old 09-15-2009, 12:54 PM   #17349
artwork's Avatar
Use Schumacher grease on the diff balls and rings, but always use Associated black grease on the thrust.
http://www.hobbypeople.net/gallery/380488.asp
Old 09-15-2009, 01:22 PM   #17350
RC MARKET's Avatar
You can see Hara Andy moore ... all is choice Associated grease for Diff ball
RC MARKET is offline   Reply With Quote
Old 09-15-2009, 01:35 PM   #17351
artwork's Avatar
I spent the last week with Andy at IIC...we talked at length about diff greases. I am sure he likes the associated grease, but it was clear to me that Schumacher grease was his preference on diff balls and rings.
Old 09-15-2009, 01:41 PM   #17352
Trader Rating: 17 (100%+)
Art,
Nice to meet you at the IIC. You had some good runs!
the other Art
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-15-2009, 01:48 PM   #17353
RC MARKET's Avatar
do you have test ?
if tested good or bad can you tell me ?
Thanks !
Old 09-15-2009, 02:07 PM   #17354
artwork's Avatar
do you have test ?
Thanks !
The Schumacher grease was great...I had been using in the past but was not using enough of it in the diff. Here is what I ended up doing:
Clean all of the diff parts prior to rebuild...sanded diff rings with 600 then 1000.
1)Smear the schumacher diff lub on the rings
2)Coat the diff balls with the schumacher diff lube (on a paper towel)
3)Put diff lub in each diff ball hole.
4)black associated grease on the thrust (should use a lot here)
5) Put the diff together and break it in slowly.
Old 09-16-2009, 02:10 AM   #17355
Well it's 2am, and I've finally finished a long drawn out search to figure out what the heck was tweaking my car so bad lately. I've noticed there was a tweak in mt car and no matter how many times I loosened all the bulkhead screws and tighten them back up, the car still had a twist.
As a result of my displeasure, I took apart the car entirely and slowly built it back up. Checking each piece of a sheet of glass to check to bent or tweaked parts. There were a few bulkheads in question, but that wasn't the case. It was a screw!!!! The screw itself was bent from some impact a long time ago. The bent screw was stressing the suspension block so much that it tweaked the chassis.
After that was figured out the overall tweak in the chassis was much better... Yet there was still a small amount left. I now loosened the servo mounts up and re tightened them down carefully. BINGO no more tweak.
I know this may seem kind of stupid of me to write this, but these are often very overlooked factors when maintaining your car. I try to tear my car down completely every month of racing. to check for bent bulkheads and whatnot.
-Korey
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
