Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-23-2009, 04:27 PM
  #17221
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Are the silver springs that come on the cyclone S the hpi silvers? They are silver, but are they the same?
BlackedOutREVO is offline
Old 08-23-2009, 04:39 PM
  #17222
Scott B's Avatar
Trader Rating: 47 (100%+)
Yes, but they won't work on a Schuie!!!
Scott B is offline
Old 08-23-2009, 04:40 PM
  #17223
STLNLST's Avatar
Trader Rating: 32 (100%+)
STLNLST is offline
Old 08-23-2009, 05:00 PM
  #17224
Haha who said they were going on my car?
thanks!
Old 08-23-2009, 07:23 PM
  #17225
STLNLST's Avatar
thanks!
We all know that your car will never hit the track again
STLNLST is offline
Old 08-23-2009, 07:24 PM
  #17226
lol 2 weeks. No more.
Ordering my car this week, FINALLY. its my B-day present
Old 08-23-2009, 07:28 PM
  #17227
STLNLST's Avatar
Right.....don't worry....you can alwaqys hold mine when you put it down for the A-main
STLNLST is offline
Old 08-23-2009, 08:02 PM
  #17228
Where have you been racing? I
I will actually get my car this time lol. B-day is thursday.
Old 08-24-2009, 08:07 AM
  #17229
cyclone speed's Avatar
Lol guys , anyway ; thanks for the help about the weight guys , great tips , and by the way , good to see again the people that helped me a while ago , they know who they are as i was a i kept asking them question .
Again , thanks alot
cyclone speed is offline
Old 08-24-2009, 08:53 AM
  #17230
Yes you can use the diffs from the TC in the older cars and the arms as well. What type of carpet racing will you be racing.....foam or rubber tire's?
Foam.
Detroitlion is offline
Old 08-24-2009, 09:11 AM
  #17231
tomracing's Avatar
Originally Posted by Phil C
Hi Cosmo,
No problem at all, sorry its taken so long for me to reply...
Here is a pic of how I have cut the topdecks and a base setup sheet for asphalt which I usually work from.
I will be testing with Andy M from Friday-Sunday at Snetterton Park track in the UK as it is the venue for the next UK national. I will post the setup I end up on if you like, as it is low-medium grip and could also be a good setup to work from.
Hope this helps,
Phil.
phil,
how did the racing in snetterton go?
learn anything new there?
when i look at your top deck cut i seem to think it is more flex then the one andy moore ran. last time i tried a cut top deck was a std topdeck cut where the belt tensioner is. i found this to be slower then the full std deck and the full tc deck. but perhaps grip levels are different for it to work less well?
is that track right on the doorstep of the real snetterton race circuit actually?
tomracing is offline
Old 08-24-2009, 09:12 AM
  #17232
Hi again , i have balanced my car side to side and done what ive been told , but just a question of curiousity , to get to the minimum weight limit , iv'e added a strip of 60 gr to the outside of my lipo , its not sticking out of the chassis but i did it like this because on the motor side , the server is just on the edge of the chassis , same for the receiver and esc and motor is sticking , so i did it so it would be equal both side , but i was wondering if i should take the 60 gr off and put it on the chassis behind and in front of the lipo pack , will it make the CG ( center of ... ) higher or not , or is it best to get a lipo weight tray to make the CG lower . by the way , i had to trim 1.5 mm of the bulkhead , so would a tray fit ?
Thanks to everyone in advance .
Old 08-24-2009, 09:16 AM
  #17233
Originally Posted by tomracing
phil,
Do you mean the GP real circuit ? If yes , yea , snetterton RC track is right on the doorstep of the real race circuit . I went to the national to
Old 08-24-2009, 09:44 AM
  #17234
POUNDITRACING's Avatar
A lower CG is always better but you should try to equal the other side of the chassis. I would say to use the lipo tray and then stack the extra weights infront and behind the battery.
POUNDITRACING is offline
Old 08-24-2009, 10:54 AM
  #17235
This is the first HB body that I have painted. Think the boss will be happy?
