Old 08-12-2009, 09:22 AM   #17176
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
If anyone is interested, there are 5 HB Cyclone TC kits at RC MART (I emailed them a couple of days ago to confirm stock). Strangely, none of the other mail order websites are reporting any stock.
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 08-12-2009, 09:37 AM   #17177
mac853's Avatar
Thumbs up
Originally Posted by luic View Post
A trick to avoid being broken is boiled in water, it will make them more flexible.
About 10 minutes, is more sufficient.
Thanks for your tip about boiled in water.
But i want to know if this could work also on old version arms?
In fact i don't think is enough just changing suspension arms.
Our new track's corners is made by concrete, they are really tough, i saw a gas car broke arm in 1st lap, was just a slightly touch.
Originally Posted by Phil C View Post
Yes thats the correct part number for the old style arms.
The old front arms are swept back, so you will need to shim them differently to the TC arms in order to maintain the same wheelbase. With the TC arms I run 2.75mm at the front and 0mm behind. With the old style wisbones I run 0.75mm at the front and 2mm behind.
Hope this helps
Thanks for your help about the wheelbase!
mac853 is offline   Reply With Quote
Old 08-14-2009, 06:15 PM   #17178
Vicko's Avatar
Trader Rating: 14 (100%+)
anyone have the spring rates for all the hara springs?
Vicko is online now   Reply With Quote
Old 08-14-2009, 06:26 PM   #17179
Here you go:
Brand/Colour......Comp./ Ratio
Hara Yellow..........12.89lb/ 230g
Hara White...........13.98lb/ 250g
Hara Black............15.11lb/ 270g
Hot Bodies Blue.....15.3lb/ 273g
Hara Purple...........16.24lb/ 290g
Hot Bodies Silver....16.9lb/ 302g
Hara Red..............17.36lb/ 310g
Hot Bodies Pink......18.0lb/320g
Hot Bodies Gold......19.0lb/340g
Hot Bodies White....20.3lb/363g
Hot Bodies Yellow...21.7lb/388g
Hot Bodies Red.......22.4lb/400g
billythekid is offline   Reply With Quote
Old 08-14-2009, 06:39 PM   #17180
Vicko's Avatar
thanks
Old 08-15-2009, 07:43 AM   #17181
color0's Avatar
Hi everyone, new owner of a second-hand Cyclone S...
Did a quick search and haven't found what I want to know, is there a DIY solution to protecting the diff outdrives (standard Cyclone ball diffs as far as I can tell) from the dogbones? My car doesn't have the CVD's, they're free-floating dogbones and I'm a little worried that over time they'll just kind of eat into the outdrive aluminum.
Any help would be appreciated, thanks!
Brian Ma
Greyscale Racing
color0 is offline   Reply With Quote
Old 08-15-2009, 11:42 AM   #17182
Even universals aren't connected on the diff side, they float like dog bones.
It will wear in time, but it takes a long time unless you are running serious power!
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 08-15-2009, 12:20 PM   #17183
mac853's Avatar
Questions??
Hi guys, in fact i couldn't find more genuine diff cushion for alum. diff. in any shop.
Could somebody tell me if that 1 of 3racing (CY-08A) could use on HB original pro spec alum. diff. of TC, please?
Best regards
Old 08-15-2009, 01:20 PM   #17184
Yes, it work, for all plastic parts, include the tyres, but without rubber, only rings, this make the plastic compound more flex, does not prevent you from being broken, but it is more shock-resistant.
This change the structure of compound, and the behavior, and is posssible you need a litle change in setup, because is a litle more soft suspension.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 08-15-2009, 01:35 PM   #17185
RC MARKET's Avatar
Best regards
Yes can !
RC MARKET is offline   Reply With Quote
Old 08-15-2009, 06:06 PM   #17186
markhat250's Avatar
Trader Rating: 65 (100%+)
I'm thinking of bailing my B44 and going D4 just for kix. I know nothing about it, but had a few questions I hope the forum could direct me with........
How much money will I need to spend after I buy the kit? Like absolutley neccessary things. ie) Hara's spring kit. LiPo Tray?
This car looks just like a B44 but more expensive, and I'm a sucker for that crap. Ha!!
markhat250 is offline   Reply With Quote
Old 08-15-2009, 06:19 PM   #17187
RaceAce701's Avatar
Trader Rating: 84 (99%+)
Hot Bodies Cyclone D4 EP buggy
try here for a quicker and better answer
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-15-2009, 07:09 PM   #17188
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Any of the experienced RCGT drivers have a setup for this class..running on parking lot surface... running a black cyclone. thanks!!
LMK thanks
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 08-15-2009, 09:07 PM   #17189
CSF0623's Avatar
I tried Korey's set up which works pretty well for me on parking lot races as well as indoor asphalt.
parking lot/low-medium asphalt setup now (90 deg air temp).
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 70wt, zero rebound, no foam
Piston: 2 hole 1.2mm (the stock one)
Shock Position: 2 on arm, 3 on tower
Camber Link Position: long, 2mm under inner pivot
Camber: 2 deg
Caster: 4 deg
Toe block: 2.5 deg (try a 2.... it'll give a little bit crisper turn in)
Shims under suspension and toe blocks: 1.0mm
Droop: 5.5mm off of a gauge
Toe: 0
Wheelbase: .7mm behind arm, 2mm in front
Ackerman: 3mm on center bell crank
Front drive: spool
Swaybar: silver (1.4mm with 2mm gap in the links)
Rear:
Spring: HPI pro 4 blue
Piston: 1.2mm 2 hole
Shock position: 4 on tower, 3 on arm
Camber link position: long on bulkhead (1mm under pivot) and short on rear hub (0mm under it).
Toe block: 3 deg
Rear Hub: 0 deg (stock)
Swaybar: copper (1.2mm) with 3mm gap in link
Shims under toe and suspension blocks: 1.5mm
wheelbase: 2mm in front of arm,
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 08-16-2009, 08:55 AM   #17190
mac853's Avatar
Questions??
Originally Posted by RC MARKET View Post
Yes can !
But how about its reliability?
Even the HB 1 is weak, i don't believe the 3racing's 1 is better, isn't it?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
