Old 08-02-2009, 09:40 AM   #17116
Originally Posted by DG Designs View Post
Same of the prototype parts seen at previous ETS race such as front spindles, steering assembly etc seems to be missing this time.
billythekid is offline   Reply With Quote
Old 08-02-2009, 11:37 AM   #17117
Trader Rating: 17 (100%+)
Originally Posted by STLNLST View Post
Giving advice and helping out others huh........I guess you're not just a good cook Ate the other tri-tip yestersay. Thanks again for everything. See ya in two weeks bro. I love my purple car
You were supposed to keep that quiet. I don't cook for very many people...if people start showing up at my house at dinner time, I'm sending you the bill! LMAO!!!
You love the purple car huh??? I guess this means you're sponsored by Team Davenport. When are you going to start running the stickers??? LOL
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-02-2009, 11:46 AM   #17118
STLNLST's Avatar
Trader Rating: 19 (100%+)
When I receive some Starting to feel like I'm sponsored by Orion again Damn.....I feel off the chair.
STLNLST is offline   Reply With Quote
Old 08-02-2009, 11:48 AM   #17119
STLNLST's Avatar
Originally Posted by Korey Harbke View Post
Well, looks like everyone covered what needed to be covered lol. See what happens when I actually go racing? Speaking of, I have a pretty decent parking lot/low-medium asphalt setup now (90 deg air temp).
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 70wt, zero rebound, no foam
Piston: 2 hole 1.2mm (the stock one)
Shock Position: 2 on arm, 3 on tower
Camber Link Position: long, 2mm under inner pivot
Camber: 2 deg
Caster: 4 deg
Toe block: 2.5 deg (try a 2.... it'll give a little bit crisper turn in)
Shims under suspension and toe blocks: 1.0mm
Droop: 5.5mm off of a gauge
Toe: 0
Wheelbase: .7mm behind arm, 2mm in front
Ackerman: 3mm on center bell crank
Front drive: spool
Swaybar: silver (1.4mm with 2mm gap in the links)
Rear:
Spring: HPI pro 4 blue
Piston: 1.2mm 2 hole
Shock position: 4 on tower, 3 on arm
Camber link position: long on bulkhead (1mm under pivot) and short on rear hub (0mm under it).
Toe block: 3 deg
Rear Hub: 0 deg (stock)
Swaybar: copper (1.2mm) with 3mm gap in link
Shims under toe and suspension blocks: 1.5mm
wheelbase: 2mm in front of arm, .7 behind it, 2mm in front of hub, .7mm behind it.
Body: LW Mazdaspeed 6
Wing: HB, mounted back to legal limit
Tires: Sorex 36, black hara v2 insert, schumacher rev lite rims.
Traction compound: Clean with buggy grip, let tire tweak sit as long as possible.
-Korey
Check your email/pm/voicemail. I'm taking this whole stalker thing to the next level
Old 08-02-2009, 11:58 AM   #17120
Hmmm...well I guess I'll just have to dig out the sticker machine again. While I'm at it...anything else?
Old 08-02-2009, 03:43 PM   #17121
STLNLST's Avatar
Make some that say "FORCE CHOKING IS GAY"
Old 08-04-2009, 10:11 AM   #17122
louielou's Avatar
Trader Rating: 16 (100%+)
Default diff
HOTBODIES, needs to come out with a sealed diff! Does anyone know a seeled diff that will fit a cyclone tc.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 08-04-2009, 11:00 AM   #17123
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Hey Louis the rear gear diff from the Nitro RS4 will work just need to shim it a little bit
Old 08-04-2009, 10:07 PM   #17124
EJ20's Avatar
Hi Hiro, ygpm. Thanks.
EJ20 is offline   Reply With Quote
Old 08-07-2009, 08:35 AM   #17125
dizzy1's Avatar
Trader Rating: 24 (100%+)
Any of the factory guys know what the hold up is on new TC kits? Been waiting to get a fresh car for IIC in Vegas, been on backorder since mid June. Tower had them as late July, then early August, now just plain old on order which is a bad sign if tower is saying that.
Have to say been racing HPI since Pro4 first came out never switched to anyone else now run cyclone, must say most disappointing thing is parts support and the stock available. Frustrating at times!!
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is online now   Reply With Quote
Old 08-07-2009, 08:46 AM   #17126
Super Moderator
Marcos.J's Avatar
here it is Louis
Old 08-07-2009, 05:24 PM   #17127
balistic's Avatar
Trader Rating: 113 (100%+)
Originally Posted by Marcos.J View Post
here it is Louis
Thats the gas diff? do you have a part #? How much does it weigh?
balistic is offline   Reply With Quote
Old 08-08-2009, 09:49 AM   #17128
bigz's Avatar
is this a global phenomenon????
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 08-08-2009, 04:54 PM   #17129
EJ20's Avatar
http://www.rcplanet.com/Hot_Bodies_C...p/hbs67700.htm
I'm not for sure if they have it instock, but you could try to call them to make sure.
Old 08-08-2009, 11:02 PM   #17130
artwork's Avatar
Trader Rating: 56 (100%+)
Been busy working on trying to get a good setup put together for IIC this year. I spent this weekend really trying to get the car to work on our high bite carpet track with a mock IIC layout. Since I have seen people requesting a carpet setup I figured I would post a complete one. Let me know if you have any questions or feedback. Car worked well with both a spool and a diff, just a few less clicks on dual rate for the spool.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
