Old 08-01-2009, 12:41 AM   #17101
Super Steve's Avatar
Send a message via AIM to Super Steve
anyone upgrade their driveline to the LCD type?
If you have, someone sell me a pair your old universals.
PM me please
Super Steve is offline   Reply With Quote
Old 08-01-2009, 03:20 AM   #17102
Originally Posted by balistic View Post
As concise as the data here is on what speed (0.10) the servo should be there is still a 100% variance on what torque should be? I plan to err on the high side just to see.
thanks guys.
I think you can only use the torque to a certain extend due to the strength of the servo saver.
Anyway, the most bad ass high speed, high torque servos are the new Associated (Thunder Tiger) and Orion Vortex servos, which has very high speed and very high torque. They are not too pricy as well, both are below $100 I believe. But they are not brushless.
Anyway, if the too is too fast, you can always turn it down on your transmitter.
billythekid is offline   Reply With Quote
Old 08-01-2009, 06:03 PM   #17103
Trader Rating: 20 (100%+)
Default TC and Moore edition
I recently picked up a TC and in the process of trading for a Moore edition. My question is what are the differences? I assume the TC is the current model with a different internal ratio. Can I stock up on parts for one and use on the either.
I plan on running the TC 13.5 brusless and the Moore Black can both rubber.
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 08-01-2009, 06:07 PM   #17104
Trader Rating: 17 (100%+)
I would probably stay with the TC. It has the better diff. Both cars are equally fast though...
Add a Version 3 spool to the TC or add the TC diff to the Moore. and you should be set.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-01-2009, 08:51 PM   #17105
So I just picked up the Lipo Upper Deck kit 67695 and was wondering what the smaller of the two purple aluminum pieces are for? I would think it is to make up the difference between the rear rear bulkhead and the upper deck but I would think it would be a washer instead of a rectangular piece. The hole pattern matches up with the bottom of the rear bulkhead but if I installed it underneath it, then the layshaft would sit ant an angle. Help Hiro, Korey, Art, Race Nuts, anyone with this kit?
Tony Vega is offline   Reply With Quote
Old 08-01-2009, 08:58 PM   #17106
artwork's Avatar
Trader Rating: 56 (100%+)
Someone posted about this earlier...I think it is for one of the older cyclones and is not needed for the TC. You do however need the 2mm round shim that comes with the kit. As long as it looks level you should be good to go.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-01-2009, 09:26 PM   #17107
Got it figured out. The spacer is if you use the BL motor mount. I didn't get a round 2mm spacer in my conversion. Is it just one of the spacers used throughout the kit? 2mm?
Old 08-01-2009, 09:31 PM   #17108
artwork's Avatar
yep...
Old 08-01-2009, 11:35 PM   #17109
STLNLST's Avatar
Trader Rating: 19 (100%+)
Giving advice and helping out others huh........I guess you're not just a good cook Ate the other tri-tip yestersay. Thanks again for everything. See ya in two weeks bro. I love my purple car
STLNLST is offline   Reply With Quote
Old 08-02-2009, 12:55 AM   #17110
Korey Harbke's Avatar
Well, looks like everyone covered what needed to be covered lol. See what happens when I actually go racing? Speaking of, I have a pretty decent parking lot/low-medium asphalt setup now (90 deg air temp).
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 70wt, zero rebound, no foam
Piston: 2 hole 1.2mm (the stock one)
Shock Position: 2 on arm, 3 on tower
Camber Link Position: long, 2mm under inner pivot
Camber: 2 deg
Caster: 4 deg
Toe block: 2.5 deg (try a 2.... it'll give a little bit crisper turn in)
Shims under suspension and toe blocks: 1.0mm
Droop: 5.5mm off of a gauge
Toe: 0
Wheelbase: .7mm behind arm, 2mm in front
Ackerman: 3mm on center bell crank
Front drive: spool
Swaybar: silver (1.4mm with 2mm gap in the links)
Rear:
Spring: HPI pro 4 blue
Piston: 1.2mm 2 hole
Shock position: 4 on tower, 3 on arm
Camber link position: long on bulkhead (1mm under pivot) and short on rear hub (0mm under it).
Toe block: 3 deg
Rear Hub: 0 deg (stock)
Swaybar: copper (1.2mm) with 3mm gap in link
Shims under toe and suspension blocks: 1.5mm
wheelbase: 2mm in front of arm, .7 behind it, 2mm in front of hub, .7mm behind it.
Body: LW Mazdaspeed 6
Wing: HB, mounted back to legal limit
Tires: Sorex 36, black hara v2 insert, schumacher rev lite rims.
Traction compound: Clean with buggy grip, let tire tweak sit as long as possible.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-02-2009, 01:52 AM   #17111
Thanks Korey for sharing your setup. Did you measure the droop to the center of the hinge pin or to the bottom of the arms?
What motor/speedo/ratio were you running?
Thanks.
Old 08-02-2009, 05:20 AM   #17112
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hey Korey - how well would this setup work with X-Patterns or HPI's vintage D-compounds?
Front:
Camber: 2 deg
Caster: 4 deg
Toe: 0
Front drive: spool
Rear:
Toe block: 3 deg
-Korey
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-02-2009, 05:42 AM   #17113
This was with a LRP SPX on profile 7, Trinity Duo 13.5 (middle timing hole) geared at a 5.6 final Drive (smaller track). Droop was measured off the bottom of the arm, just under the outer hinge pin.
Not sure how it would work with those tires. Typically those tires make your car push a little more I would think? I've actually never tried them. The setup makes a lot of grip overall, so I think it should be pretty good. If you find you want the car to be more aggressive overall, try a little bit less arm sweep, or run 3 hole 1.1mm pistons with Losi 40-50wt shock oil.
-Korey
Old 08-02-2009, 07:42 AM   #17114
RC MARKET's Avatar
-Korey
If you use stock motor , can try Tekin RS or Team Wav RB50 ESC same your motor gear ratio ,
can get more punch & full speed ,
if RB50 had Tubro mode !
RC MARKET is offline   Reply With Quote
Old 08-02-2009, 09:14 AM   #17115
Trader Rating: 14 (100%+)
You guys see this?
http://events.redrc.net/event-galler...ros/?nggpage=4
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
