Old 10-28-2005, 04:24 AM   #1681
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi Guy,
Does anyone have try to used pro 4 harden steel universal joint into cyclone front? because if using the original aluminium drive shaft i think it would twisted easily if runing with front spool.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 10-28-2005, 04:36 AM   #1682
j-sin's Avatar
um, how does that affect the cyclone exactly?
i might be misunderstanding you.
but isnt the "driveshaft" part of a shaft car? and this is belt drive
or is there somethign called that in the cyclone, im new to this so dont hurt me
j-sin is offline   Reply With Quote
Old 10-28-2005, 04:40 AM   #1683
Skill's Avatar
I think he is referring to the drive shafts which go in between the diff outdrives and the axles.
Skill is offline   Reply With Quote
Old 10-28-2005, 04:45 AM   #1684
Stew Noble's Avatar
The Pro4 driveshafts are too long, they do not fit the Cyclone.
New release 61043(front) and 61044(rear) HD Steel drive-shafts, specifically for the Cyclone.
// S N F //
Stew Noble is offline   Reply With Quote
Old 10-28-2005, 04:49 AM   #1685
j-sin's Avatar
ah cool,
do they have another name? i heard someone i think call them a CVD and someone else call them dog bones
cool for clearing that up for me
Old 10-28-2005, 04:49 AM   #1686
Guo Chean's Avatar
what i means is the can the pro 4 harden steel dogbone can fit in the cyclone aluminium dogbone i know pro 4 will be a little longer than cyclone but will it possible to used in cyclone? Skill are correct it was between the diff outdrive and wheel axles.
Old 10-28-2005, 04:52 AM   #1687
Stew Noble's Avatar
CVD is an acronym for Constant Velocity Driveshaft
There are quite a few different names for them, strictly they arent Dogbones, a Dogbone is used where no CV joint is present.
// S N F //
Old 10-28-2005, 04:52 AM   #1688
Guo Chean's Avatar
ah cool,
CVD is design and production by MIP it. for US or Europe version HPI kits will using only but in Asia the not using CVD they will using Universal Joint.
Old 10-28-2005, 04:55 AM   #1689
Guo Chean's Avatar
So for the original kit universal joint will be the same length or different??
Old 10-28-2005, 04:58 AM   #1690
Stew Noble's Avatar
In the kit both front and rear CVD (#70710) are the same length, im not sure of the reason for the new steel CVD parts coming in front and rear packs.
// S N F //
Old 10-28-2005, 05:04 AM   #1691
Guo Chean's Avatar
In the kit both front and rear CVD (#70710) are the same length, im not sure of the reason for the new steel CVD parts coming in front and rear lengths.
From what i had read after translate to english it say that no different maybe they want to make more easier for consumer buying.
Old 10-28-2005, 05:11 AM   #1692
Skill's Avatar
The front and rear HD driveshafts are 44mm long, all we can guess is that the front ones are slightly thicker to take the strain of a one-way/spool.
Old 10-28-2005, 07:47 AM   #1693
Hollowman's Avatar
Send a message via MSN to Hollowman
So what to get, i heard someone talk about tamiya drive shafts & one-way cups ? but i think the hb drive shafts will do the job, my dogbone is already a bit bend and the winter is coming so indoor with those skinny drive shafts will be a blast , and a spool they say here in holland that it's bad to run a spool cause you will destroy your whole drivetrain so what are the benefits of running a spool. i heard someone talk about that the yokomo bd titanium screw kit will fit the cyclone and that you can do the whole car ? so please let me know before i buy things that don't fit !
greetings hollowman
Hollowman is offline   Reply With Quote
Old 10-28-2005, 07:54 AM   #1694
Skill's Avatar
Yea, I noticed a slight bend on one of my front driveshafts after 2 indoor meetings.
Unless you already have the BD titanium screw kit there's no point in buying it for the Cyclone as manufacturers already have a kit for the Cyclone available I would imagine. I know for sure that Titanium Racing do.
Old 10-28-2005, 07:56 AM   #1695
Guo Chean's Avatar
hopefully i can get it before my FEMCA ISTC race. so i can used it
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
