Hot Bodies Cyclone
I was wondering if someone can point me in the direction to safely securing a lipo into my (new to me) cyclone TC. I have scene all sort of lipo braces for other TC's. I have tried the search bar on this forum and googled it but have not found what I am looking for. I understand there is a new lipo upper deck kit offered my HB, I was looking more for a side impact type brace and hold down kit, other then tape. At my local track we require lipos to be charged in fire bags, so taping them in is a hastle.
What I did to prevent the side impact is like the other's mentioned. Find the plastic servo mount(2), mount it on the center of the bottom deck, it can prevent the lipo move in and hit the gears by the side impact. You don't really need to worry about the lipo itself, the case (trackpower) is strong enough for that. Hope these help.
I just bought the new zero degree rear hubs and the ball stud seems to long. Is there a particular ball stud I need to buy for the new hubs?
Cheers
Adrian
Cheers
Adrian
There are two different sizes...I would try these they are only 10.3mm instead of 13mm.
http://www.hotbodiesonline.com/products/en/75115.html
They also make an aluminum version as well.
swaybar gap
The kit Cyclone TC setup uses a 1.0mm gap on the swaybar linkage for both front and rear.
Hara RROC setup uses a gap of 2.5mm on the front, and 3.0mm on the rear.
What does increasing and decreasing this gap actually affect ?
Cheers
Cheers
I run 2.0mm up front, and 3.0mm in the back almost everywhere. You might need to use a longer ball stud to make sure it has enough thread in the swaybar link.
-Korey
This is actually a really cool adjustment. The bigger that gap is, the more the swaybar is slanted. The more slant it has, the less "direct" it will feel. It becomes more progressive, so it will give the feeling of a softer swaybar initially, then get stiffer further into the turn.
-Korey
-Korey
(2) Another query. The downstop values used by Hara and yourself are 9.0mm front and 8.5mm rear. I'm setting up my car at the moment and find that this causes the downstop screws to hit the chassis under static load. Is this correct (I guess not), or am I measuring something wrong (more likely)?
Cheers
(1) This sounds similar to the effect caused by slanting the top shock position (ie: softer initially, then harder as compressed = progressive).
Cheers
Cheers
-Korey
-Korey
Thanks,
internal secrets being leaked zomggggg
Thanks Korey for posting this. This is exactly what i explained to you about the gap between the sway bar links BUT it is just from my experiences so others may feel differently. I just wanted to share my thought. (I didn't know Korey will post this to tell everyone!!)
Thanks,
Thanks,
Out of the topic, I personally really please for everybody if we can share our experiences more often on here so we could improve alot not only driving but also tunning and building it acuate especially for some new Cyclone drivers.
THANKS.
I am sorry but there are just way to many ways to tune myself into a hole on current Touring cars!.
Bedtime Reading
Hi Hiro San, Korey, actually I have another experience want to share beside your's which is really good option for setting up the swaybar. On mine's (and friends) other thought is we could use it for tunning the sway bar raise up more evenly on both side. That is a lot easier for us to tune it compare to the old style's.
THANKS.
THANKS.
(1) Hudy Setup Book. However, the Xray T2 Setup Book is 98% in common and is available for download from the Xray site (pdf).
(2) RC Car Handling - theory (http://home.scarlet.be/~be067749/58/)
Read and understand these two references and you will be the local pro
Cheers
Thanks,
Thanks,
So more gap in the rear seemed to make the rotate better in the rear going into the corner. When I reduced that gap, it actually locked in the rear end a little more. It will have varied results depending on how much grip is on the track though. For everyone, I'd say it's a worthwhile adjustment to at least try, and see what it does. Post your results here and let us know.
EJ20- I'm assuming that was actually the REAL intent of the design. It's to make slight tweaks to the swaybar to make sure it acts evenly on both sides of the car. Plus you can make much finer adjustments with the new mounting system, compared with the old.
-Korey
