Old 07-18-2009, 04:30 PM   #16861
Trader Rating: 20 (100%+)
Default Thanks
Thanks Korey for the input.
I plan on running a novak 13.5ss and GTB controler. I do have a wide selection of 64 pitch gears to matching the combination should be fine. Should I be interested in changing the internal ratio of the chassis to run the brushless?
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 07-18-2009, 05:21 PM   #16862
mr fit's Avatar
it all depends on the size of the track and what is comfortable for you.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 07-18-2009, 10:32 PM   #16863
Korey Harbke's Avatar
Well, HB does offer 18T center pulleys that come on the Cyclone TC (as opposed to 16T) and that lowers the internal ratio from 2.4375 to 2.1667. It'll make it a little easier to gear brushless motors, and will make the drivetrain a tick freer. So if you can find those parts, those are always good to get.
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 07-18-2009, 11:21 PM   #16864
Originally Posted by billythekid View Post
Hey Korey, how would you compare the Subaru with Protoform's new LTCR?
It's smoother I would think. I've honestly had very limited experience with the LTCR, but going off of what others say, the LTCR has more steering than the Mazdaspeed. The Subaru was designed to fall right in between the mazda 6 and the mazdaspeed 6. From testing, it has shown to be very neutral and easy to drive with. I'd say it's worth having in your arsenal of bodies to try . It's actually one of my favorites now.
-Korey
Old 07-18-2009, 11:52 PM   #16865
SammyZ's Avatar
Trader Rating: 138 (100%+)
the 16t pulley's are fine for brushless. I wish i didn't spend the $$ upgrading
to the bigger pulley's and longer belts. I went from an 88t spur to a 100t spur because of the change using the same pinions.
Go with a small spur and the stock pulley's, your good.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 07-19-2009, 01:51 AM   #16866
bydand53's Avatar
Default Gears
I've got a Cyclone TC with the 18 tooth drive gear giving me an IDR of 2.1667.
I want to run 540 brushed, 540 sport brushed and 10 turn brushless with the one car but am having trouble sourcing 64 pitch spur and pinion gears.
Other than HPI, can anybody suggest an alternate manufacturer/supplier?
I'm sick and tired of searching the world to pay $3 for one gear and $30 for postage.
bydand53 is offline   Reply With Quote
Old 07-19-2009, 08:06 AM   #16867
Default li-po conversion kit
Have any one use the conversion kit for the LI-PO kit yet? I am not sure what the third part is use for the long alu part with two holes can someone explain.
Ramyuras is offline   Reply With Quote
Old 07-19-2009, 11:12 AM   #16868
RC MARKET's Avatar
end of this month !
RC MARKET is offline   Reply With Quote
Old 07-19-2009, 11:59 AM   #16869
SammyZ's Avatar
nexusracing will ship int'l and they have all the 64p pinion and spur gears in stock. Just order a lot.
Hotbodies USA
SweepRacing USA
Old 07-19-2009, 12:01 PM   #16870
SammyZ's Avatar
I've noticed that the WCE spool makes the front end of my car shake/vibrate violently with maximum turn angles.
The shaking is so bad that it actually slows the car down in corners during entry and exit.
If i flip the car over and apply throttle and turn the wheel to the max throw in either direction the CVD's make an awful grinding sound.
Is this only the case with the spool? Should i switch to a one-way?
The logical answer would be to turn down dual-rate or
reduce EPA. If i do that I can't get the tight circles I need.
Hotbodies USA
SweepRacing USA
Old 07-19-2009, 03:23 PM   #16871
mr fit's Avatar
I use a ball diff at the rear and one way at the front. This makes the car very smooth and easy to handle. The spool is usually used for smaller and tighter tracks.
Old 07-19-2009, 04:55 PM   #16872
Originally Posted by RC MARKET View Post
end of this month !
What!! I don't know what end of this month mean but that is not what I am asking, I have the conversion kit already just want to know what the part with the two hole is use for.
Old 07-19-2009, 05:42 PM   #16873
dag32's Avatar
Trader Rating: 100 (100%+)
I have the conversion, but have not put it on yet. I think the part in question goes between the chassis and Middle Block Right (large purple part).
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 07-19-2009, 05:52 PM   #16874
Yes, the square piece will go in between the middle block (right side) and the main chassis. But, this is only used if your car has the brushless motor mount. If the car has original bulkheads, you won't need the square parts.
Hope it helps.
Thank you.
Hi-LowBlow is offline   Reply With Quote
Old 07-19-2009, 05:54 PM   #16875
dag32's Avatar
Originally Posted by Hi-LowBlow View Post
Yes, the square peace will go in between the middle block (right side) and the main chassis. But, this is only used if your car has the brushless motor mount. If the car has original bulkheads, you won't need the square parts.
Hope it helps.
Thank you.
Thanks, Hiro!
★ David Garcia ★
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
