Old 06-20-2009, 06:11 PM   #16636
when are they going to be released?
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875,CRC XTi WC, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 06-20-2009, 11:31 PM   #16637
bydand53's Avatar
Originally Posted by Korey Harbke View Post
Also check your hinge pins... I've had some people come up to me complaining about the same thing and they had a bent hinge pin.
You nailed it, it was a bent hinge pin !
bydand53 is offline   Reply With Quote
Old 06-20-2009, 11:43 PM   #16638
Korey Harbke's Avatar
See!!! I'm good for something
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-21-2009, 08:23 AM   #16639
jag88's Avatar
Originally Posted by RC MARKET View Post
new option parts
Korey, is this the new top plate that you were testing ?
If so is there any change in handling ?
jag88 is offline   Reply With Quote
Old 06-21-2009, 05:39 PM   #16640
Indeed it is. I haven't noticed any change in handling, but I did notice it tends to tweak a tiny bit easier. Other than that, it's great. I've been running it for a while now with good success. It sure makes fitting lipo batteries a lot easier. I'm running a Thunderpower 40C 5000mah battery with a PPD Billet Lipo weight plate and still have room to go.
-Korey
Old 06-21-2009, 11:38 PM   #16641
RC MARKET's Avatar
Not have special feel !
steering first respond more direct ,
because steering arm shorter.
RC MARKET is offline   Reply With Quote
Old 06-22-2009, 12:56 AM   #16642
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Scott B View Post
It should be the same as it is with the current topdeck, just minus the right middle bulhead that goes over the battery.
Do you have one?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 06-22-2009, 01:21 AM   #16643
RC MARKET's Avatar
HB DCJ weekend arrive !
Old 06-22-2009, 03:58 AM   #16644
Hello, i run with Cyclone a few years ago, my car is a Surikan Edition, but with a few updates, Diff Pro, TC chassis and upper deck, WC towers,...
But always, i feel the same problem, when the conditions are too hot, or variables, the car are litle unpredictable, a little loose, loses grip,...and i tested more things, but i never solve the problem, when the conditions arent too hot i have very good results in races, i think is a problem of setup, but i tested a lot of springs, oils, CG, RC positions, and the problem continue, i dont can to change the tyres, because are control tyres for all races, Sweep 36R.
Normally, the temps here are, from 30-35C to 40C, and the track are to 50-60C.
Sometimes,i think the chassis is made soft with the heat, and flex a lot of more and i think to change it, but the setup say when soften the car i have best results.
Actually, i run with silver-blue springs, and 55WT oil, 2 mm low pivot blocks, 2 - 1.5 mm in camber link, 1 - 1.5 camber,... the setup are pretty standard.
I need some help, i do not know that i am doing wrong.
Thanks, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 06-22-2009, 08:03 AM   #16645
Hi Luic,
Have you tried thicker oil (~70W)?
Itchy is offline   Reply With Quote
Old 06-22-2009, 08:37 AM   #16646
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Thanks, Luis C.
When i ran the Surikarn ed cyclone i had the exact same problem with hot weather. Now that i run the TC ive never had that problem. Dont know why, they are pretty similar.
mild seven is offline   Reply With Quote
Old 06-22-2009, 09:23 AM   #16647
jag88's Avatar
Korey, when are we going to get an update on your thoughts of the HB version of the double carden front axles ?
Thanks.
Old 06-22-2009, 11:56 AM   #16648
louielou's Avatar
Trader Rating: 16 (100%+)
Default setups
does anyone have a good JACO BLUE tire setup for carpet.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 06-22-2009, 01:04 PM   #16649
Thanks.
I should have a report for you guys in the next few weeks. I'm waiting on my new radio to come in
-Korey
Old 06-22-2009, 01:38 PM   #16650
Originally Posted by Itchy View Post
Hi Luic,
No, i buy then, but i only tested to 60WT, is my next thing to make, Thanks.
Mild seven, thanks, i change all things for a convert it to a TC blue Edition, but i think is there something are diferent, maybe it's time to buy a new car.
Thanks, Luis C.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
