Hey guys, just recently purchased a hot bodies cyclone 1st version (black Version). I will be using it for countersteering drifting and since I mostly have stick battery packs I wanted to know if the sell a kit to adapt it for stick packs???
I donīt have chatter in the steering, with CVD Mips, and spool V3, with the POM outdrives, but i detect a problem, in turn when the suspension is compress the pin of dogbone, in the outdrives, go out and cause excessive wear, i put the washer is in the out of axle, in the part from internal bearing, i think, the cvd go slighty to the outdrives, but not solve the problem.
Now, i read the Korey post, and go to change the CVD, from Universals, but i have 4 CVD news, i have to use it in the rear of car, i think is not a problem? , this not change car handling?
Thanks for all help.
Greetings, Luis C.
## NOSRAM##HB TC Blue Edition##BMI DB12RR+##:)
I'M BACK!!!! HB most controversal racer ever will be back running the car that many in Norcal fear After running Scotty Barnes' car last weekend (not even Hara could stay on pace ) Please direct all statements and questions to Korey. He will be more than happy to answer all pm's
Hiro- I need some stickers bro
LOL!
I think I may be also man. I already have a Cyclone, just needs some parts and its set.
Schumacher/Speed Passion/Black Army Racing/Owen RaCing/NNFaN Paints/Scooter Motorworks
Help !! My son (Alex) has decided to give on-road a try so we bought the Cyclone S, now he wants to change the gearing to the TC gearing ? which would take bigger pulleys ? and different belts ? I went to the hobby store and they did not know what we were talking about. Can somebody provide exactly what we are looking for ? or maybe a place online where I can find these parts
Banzai Motors | Hot Bodies | Bob James - Remembered forever | Bud Light |
The POM ourdrives are made from the same material as the POM differential outdrives that come stock in the TC kit. I've noticed wear is very minimal on these, but they aren't the most durable things in the world. At the reedy race, I ended up using the steel outdrives just for extra peace of mind.
What the team has found, the steel outdrives work best when used with MIP CVD's in the front of the car. The MIP CVD's don't fit as tight in the hub bearings, and give a little bit of slop there. That helps take some of the chatter out as well. When using the POM outdrives, we suggest using the HB Ver 2 universals as they fit tighter in the bearings and the combinded amoutn of slop isn't too much. It seems to be the best combo for the POM outdrives.
As far as other questions about chatter, check to make sure you have at least version 2 HB universals or MIP CVD's. The ball joint and range of motion is greater on these, so they chatter significantly less. Also, there will always be some chatter with a spool, so a little bit isn't much to be worried about. Especially in an unloaded condition like turning the car upside down.
If you guys are still concerned about chatter, hot bodies has just recently released their DCJ driveshafts which have two universal joint in them, much like designs from Losi or Xray.
Very helpful information Korey. All your efforts to help out cyclone racers are truly appreciated. I'll try to find the POM outdrive cups. In the meantime, however, I switched to slightly worn steel drivecups and there is some reduction in chatter. The first 60% steering goes smoother while some chatter remains on the latter 40% towards full steering lock. I will try things out at the track tomorrow and hope to notice less front end chatter under load. Thing is, I never experienced this with my previous cyclone original black edition. Then again, I ran with center and front one ways on that one. Thanks again!
You only wanted to come back because all the cool peeps are on this thread
Plus no one talked with you on the other one
Looking a Andy Moore's cyclone, and also the FXF Cyclone kit the bulkheads dont have that extra brace coming down, so being this cyclone had plastic front bulkheads I tried it out. I dont know that id take this to alu bulks. But if you take away that front part, you can scoot the servo up, drill and tap the bellcrank (I think thats what its called?), pop a ball stud in it, and bam!
Sorry for the crappy pic, took it at 3 in the morn on my cell LOL.. Nothing is stuck down or anything, so yea
