Old 06-04-2009, 09:27 PM   #16516
louielou's Avatar
Trader Rating: 16 (100%+)
Default spur gear
does anyone know what spur gear would i be able to use to run 13.5 and 5.5 pinions with out having to change spur gears.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 06-04-2009, 11:19 PM   #16517
Mike E.'s Avatar
Trader Rating: 17 (100%+)
Send a message via Yahoo to Mike E.
Originally Posted by 303slowdown View Post
Mike E I think your math is off if your running the TC your ratio would be 4.33
not 4.7 .
Ya that's my bad. I had a 46 pinion not 50.
www.facebook.com/LuckyThirteenRCGraphics
Venom Group International / Atomik RC / Addiction RC
2 Dudes RC Hobbies
Luck 13 RC Graphics
Mike E. is offline   Reply With Quote
Old 06-06-2009, 06:53 AM   #16518
Team STPN's Avatar
Originally Posted by Korey Harbke View Post
Well, I'm back in Bellingham doing the normal school stuff. I'm taking a break from my studies to post up my Reedy Race setup. The car was very easy to drive in the given conditions. Track was pretty high grip, and we were using Jaco Blues.
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 45
Piston: HB 1.1mm 3 hole
Shock position: 3 on tower, 2 on arm
Rebound: Full rebound with no foam
Camber link Position: long, with 2mm under the inner mount.
Camber: 2.5 deg
Toe: 1 deg out
Caster: 4 deg
Toe block: 2.0 deg
Shims under suspension blocks: 1.0mm all around
Swaybar: 1.4mm w/ new style mount, with the screws backed out 3mm
Droop: 9.0mm from the center of the outer hinge pin to the setup board
Ride height: 5mm
Wheelbase: .7mm behind arm, 2mm in front
Rear:
Spring: Silver
Oil: Losi 35wt
Rebound: full without foam
Shock position: 4 on tower, 3 on arm
Camber: 2.5 deg
Camber Link Position: long with 1.5mm under the inner pivot, and 1mm on the outer pivot.
Toe block: 2 deg
Shims under suspension mounts: 1.5mm all around
Swaybar: 1.2mm on new style mount with screws backed out 1mm.
Droop: 8.5mm measured from the outer hinge pin to the setup board.
Ride Height: 5mm
Wheelbase: 2mm in front of arm, .7mm behind it, and 2mm in front of hub, .7mm behind it.
Other:
Front Drive: Ver 3 spool with MIP CVD's
Body: LW Protoform Mazdaspeed 6 mounted a tick forward
Wing: LW wing
Tires: Jaco blue premounts
Sauce: tweak/buggy grip
Motor: Team Trinity Duo 13.5
ESC: LRP SPX
Gearing: 100/40
Hope thats everything! Let me know if you have any questions.
-Korey
Hey Korey,
I have question on this set up for the rear, "the long camber link set
Camber Link Position: long with 1.5mm under the inner pivot, and 1mm on the outer pivot." The rear hub carrier has 2 positions, using the positon (inside wheel) to make the longest link possible won't it rub with the wheel rim??
Team STPN is offline   Reply With Quote
Old 06-06-2009, 11:01 AM   #16519
Korey Harbke's Avatar
I think what I said was misleading... It's basically just the kit link setup, but with the 1mm under the ballstud on the rear hub carrier. We were running Jaco Blues at the reedy race, and they have the edge of the wheel that is very rounded, so there is plenty of room for the ballcup.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-06-2009, 11:12 AM   #16520
-Korey
Hi Korey, what is the outside diameter of the Jaco Blues you ran?
billythekid is offline   Reply With Quote
Old 06-06-2009, 12:13 PM   #16521
Without compressing them a bit to get the airgap out... it's 63mm. When compressing a bit.. it's roughly 61.
-Korey
Old 06-06-2009, 03:17 PM   #16522
RC MARKET's Avatar
my cyclone update
& waitting this new parts
RC MARKET is offline   Reply With Quote
Old 06-06-2009, 08:37 PM   #16523
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I ran 55/96 today and wanted to go higher (ended up running 28' total timing to get the straight away speed).... I think a 94t spur would be ideal, then you could run 51-57t pinions for our tracks.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 06-06-2009, 08:53 PM   #16524
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by RC MARKET View Post
my cyclone update
how did you do that?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 06-07-2009, 08:30 AM   #16525
RC MARKET's Avatar
unknow
Old 06-07-2009, 03:49 PM   #16526
kschu's Avatar
Send a message via MSN to kschu
unknow
i think he diy himself......
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-07-2009, 03:55 PM   #16527
jag88's Avatar
unknow
What does it do for you ?
jag88 is offline   Reply With Quote
Old 06-07-2009, 06:46 PM   #16528
It looks like it just gives a lot of room for electronics if you use low profile servos. It could also move weight a littlemore forward making the car smoother to drive... but I doubt it's veyr noticable.
-Korey
Old 06-07-2009, 07:09 PM   #16529
jag88's Avatar
Looks like you have to shoe goo it to the chassis. Not something I like doing.
Old 06-07-2009, 11:14 PM   #16530
kschu's Avatar
u can use servo tape to stick ur servo on d chassis....
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
