Old 06-03-2009, 03:49 PM   #16501
Default Gears
Hello all, can one of you guys tell me the smallest and largerst pinion I can run on my Cyclone with a 100t spur? Im trying to get some different ratios ordered and wanna make sure of what Im getting.
Thanks in advance
Ron P.
RMP750 is offline   Reply With Quote
Old 06-03-2009, 04:47 PM   #16502
Mike E.'s Avatar
Trader Rating: 17 (100%+)
Send a message via Yahoo to Mike E.
Well that depends on what the final drive ratio you're trying to achieve. Depends on the track you're running too. What motor do you have in it? Is it the TC or the earlier model because the have different "transmission" ratios. In my TC I'm currently running the 100 spur and a 50 pinion. That put me at a 4.7 FDR. With a 13.5 you could go as low as 4.2-4.4 without any problem
Just in case this doesn't help I know that this link will. It made my life a lot easier. Gear chart Just punch in your car info. If you have the TC you'll have to manually enter the trans ratio which is 2.167 to get the chart you need.
www.facebook.com/LuckyThirteenRCGraphics
Venom Group International / Atomik RC / Addiction RC
2 Dudes RC Hobbies
Luck 13 RC Graphics
Mike E. is offline   Reply With Quote
Old 06-03-2009, 05:05 PM   #16503
Thanks for the quick reply, on one chassis im running 17.5 and the other Im running 13.5, the reason I asked the question that way was so I could order different pinions to play around with the FDR. In 17.5 i running a 4.0 the my Tekin Pro but would like to get a little higher and a little lower to see results. In 13.5 i shoot for 4.8 fdr and looking to do the same. I dont want to order gears that will not physically fit the chassis. That is what I am trying to avoid.
Old 06-03-2009, 05:29 PM   #16504
Mike E.'s Avatar
Not sure of the biggest pinion you can get on there. Like I said I have the 50 on it and there's room for more. Not sure how much more but I can find out tonight. I have a bunch of new pinions waiting at home for me. I think I went as high as a 52 on my purchase.
That Gear chart link is very helpful. You should go check it out. You have the option to have your gearing at the begining, middle or end of the chart you create.
2 Dudes RC Hobbies
Luck 13 RC Graphics
Old 06-03-2009, 06:36 PM   #16505
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
The smallest spur gear I've gotten in mine is a 76t - I was that with a 64t pinion, I would have try a 65t but the shop didn't have anymore in stock
this was with my VTA 4cell/17.5
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-03-2009, 08:20 PM   #16506
ASM
ASM's Avatar
Originally Posted by racenut123 View Post
That plate is too thick to run with most of the popular 40c batteries.Poor design.Wasted my money after the sales guy at Stormer said it would fit with minimal hassle.Right!
I just got mine to fit as of tonight. I had to have it milled down to about .045 thick which equated to half the thickness being taken off. After additional work on the top deck mount and the screw, I'm happy to say it now fits my 5000 packs. It's going to be a big help in limiting the pack from side to side movement. I'll be testing/racing it this Sunday for the first time as well. The fit feels real sweet!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 06-03-2009, 11:13 PM   #16507
303slowdown's Avatar
Trader Rating: 21 (100%+)
Mike E I think your math is off if your running the TC your ratio would be 4.33
not 4.7 .
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 06-03-2009, 11:14 PM   #16508
bydand53's Avatar
Thanks for the advice Korey. I've got a heap of alloy parts coming through Customs at the moment so hopefully they will solve the problem. If not, all I can do is assume that the holes in the chassis plate have been mis-drilled and either replace the chassis plate or ream out the mounting holes for the front pivot block so that I can adjust it sideways and equalise the toe-in.
Is anybody else aware of a problem with mis-drilled chassis plates ?
Richard
bydand53 is offline   Reply With Quote
Old 06-04-2009, 12:12 PM   #16509
Suspended
Originally Posted by Hi-LowBlow View Post
Now we have the option parts called "Low gear unit" that allow you to use bigger spur gear for the brush less motor.
#61298 Low Gear Unit (Black)
#61329 Low Gear Unit (Purple)
#61360 Low Gear unit (Blue)
when you use these units, you will be able to have smoother drive train too,due to the less angle belt mounts. Even if you're not brush less system user, these parts are still good for you guys.
in addition, we will soon have 18T drive pulley that is 2 tooth bigger than the original one. This will make the drive train way more free!!
Christopher13 is offline   Reply With Quote
Old 06-04-2009, 01:58 PM   #16510
We have changed the name for those to "Brushless Motor Mount". Part numbers are still the same.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 06-04-2009, 02:20 PM   #16511
Suspended
Originally Posted by STLNLST View Post
It was on carpet with rubber tire's. I don't know what set up Scotty was running. He is running the BMI chassis though. I wi;; post my set up on www.gearchart.com sometime tomorrow.
Clint - did you want that BMI kit? Check back a page or two about what I have for you if you really wanted it.
Old 06-04-2009, 02:35 PM   #16512
Scott B's Avatar
Trader Rating: 42 (100%+)
Clint hasen't ran a Cyclone for the last 6 months, so I don't think he'll need a BMI chassis for one...
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks, Protoform...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 06-04-2009, 02:50 PM   #16513
Yeah, too bad he quit HB. He would be faster with a Cyclone.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 06-04-2009, 07:46 PM   #16514
Team STPN's Avatar
You all know he was slow in the first place but was just a little faster with an HB
Team STPN is offline   Reply With Quote
Old 06-04-2009, 08:08 PM   #16515
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hahahaha. Poor Clint
I never thought hed go to Tamiya though. That was a weird one
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
