Old 05-31-2009, 06:43 AM   #16441
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i know this a stupid question... but just wanted to ask if the new POM diff from the TC can handle 4.0 mod? running rubber tires on med grip asphalt
Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-31-2009, 06:54 AM   #16442
YLLIB's Avatar
Thanks!
yes, with no problems. Just make sure you use the outer ring supports. Those will support the diff from spreading out and breaking.
YLLIB is offline   Reply With Quote
Old 05-31-2009, 07:00 AM   #16443
VooDooPH's Avatar
will do! thanks!
Old 05-31-2009, 07:36 AM   #16444
Originally Posted by cyclone x View Post
hey charlie is this ur tracks setup
Hey Korey, Looking at this setup sheet can you tell me which holes ( 1,2,3,4) you used on your camber links. Inner Front and Inner rear and Rear Hub. Also, does the TC come with 1 degree rear hubs or 0 degree hubs. And which one did you use for your reedy setup.
thanks again.
dannybcaitlyn is offline   Reply With Quote
Old 05-31-2009, 07:37 AM   #16445
Scratch that. I see thats the older setup sheet. On the TC setup sheet would it be 1 or 2 on the front and rear inner links. And the inner hole on the rear hubs.?
Old 05-31-2009, 10:19 AM   #16446
EJ20's Avatar
He used the longest camber links position at the front and the rear on his TC.
EJ20 is offline   Reply With Quote
Old 05-31-2009, 05:04 PM   #16447
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by racenut123 View Post
Am I gonna have to get Whoopass to come here now?
Bring it
STLNLST is offline   Reply With Quote
Old 05-31-2009, 05:52 PM   #16448
Korey Harbke's Avatar
http://www.ppdbillet.com/RC_accessories.html
Here's the link to Kevin's website. He makes nice stuff, and at a reasonable price as well. Sounds like there is more and more interest in a Cyclone TC specific plate, so maybe he'll make one. You guys just need to tell him you want one, and actually buy it!!!
If you do some searching around on his website, he also produces a tweak plate that I use regularly. It's great for making sure your car is completely flat and tweak free.
For camber links, it's position 2 on the cyclone TC upper bulkheads. I used the "inner" hole on the rear hub. Basically box stock camber link setup, except the shims under the pivots. I tried position 1 (short) but it wasn't that great. The car would turn in super hard, then get a really bad push through the longer corners. The longer link setup we typically use was much better overall because it was more stable, and produced more mid-exit steering.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-31-2009, 07:45 PM   #16449
STLNLST's Avatar
-Korey
I think I had the 2nd Cyclone plate ever made and the first in Sac. Kevin is a real nice guy and his stuff is top notche.
Old 06-01-2009, 08:32 AM   #16450
-Korey
Not sure what setup to use anymore I have been trying to get my car to rotate in the 180 deg corners and it just push coming out with every setup I can find on the TC online and more, I tried my buddy car the 416 and I could not get my car the rotate or steer has his, any one with a setup for a med traction track with a lot of 180 deg corner please.
Ramyuras is offline   Reply With Quote
Old 06-01-2009, 08:51 AM   #16451
louielou's Avatar
Trader Rating: 16 (100%+)
Default balancing
anyone know the right way to balance the cyclone tc left to right with a thunder power 5000 lipo pack.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 06-01-2009, 09:02 AM   #16452
GasGod's Avatar
Any one know of a diff that fits the cyclone?Will an xray fit?I shattered one of my outdrives and no parts--are avail--I know the pulley count is different,but will the outdrives/diff halves work? I have a big race coming up and no one seems to have parts--
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 06-01-2009, 09:46 AM   #16453
EJ20's Avatar
If you ever try to use less ackerman spacer? I tried 0.5 spacer on ackerman and it gives more mid corner steering. Or, try the front hole on the front knuckle, it makes big difference on steering too. Hope this help!
Old 06-01-2009, 10:14 AM   #16454
EJ20's Avatar
The Pro-spec ball diff (#67720) for Cyclone is a good one besides if you want to try other manufacturer's. It's hold up pretty good even on Mod motor with the POM outdrives. The old one is using 2mm diff screw but the Pro-spec's is 2.6mm which is a lot stronger and it comes with ceramic ball which gives a silk smooth feel.
Old 06-01-2009, 10:20 AM   #16455
GasGod's Avatar
Thanks for the reply; but as I said -- no parts avail till ???? all are b/o .I am asking if any other mfg. diff will fit.
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
