Old 05-29-2009, 05:13 PM   #16411
Originally Posted by Korey Harbke View Post
1-7-3-3 on the SPX, no posts, normal FRP plate, and the new arms.
-Korey
Hey Korey, what was your timing set at on your Duo and what were the temps coming off the motor. Also, did you run a fan on motor?
Thanks.
dannybcaitlyn is offline   Reply With Quote
Old 05-29-2009, 05:28 PM   #16412
Default More steering
Hi everyone, what front would you all recommend to get some more steering in my Cyclone,I run on a fairly tight track and I am using a supplied one-way at the moment and suffer from bad understeer,any help or advise would be appreciated,cheers.
P.S.....or maybe I need to control my trigger finger a little better...
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 05-29-2009, 07:55 PM   #16413
Korey Harbke's Avatar
Thanks.
Timing was at the middle hole, motor temps were comming off at about 170 with 2 fans. Without the fans it was around 200 deg.... but that gearing felt the best overall so I did what I could to bring the temps down. The trinity rotors are really good, so even if you get them hot a few times, they can survive it.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-29-2009, 07:58 PM   #16414
tc3 racer sc's Avatar
-Korey
ru going to post ur set up
tc3 racer sc is offline   Reply With Quote
Old 05-29-2009, 08:00 PM   #16415
Trader Rating: 28 (100%+)
Tough room in here! Yeah car was very good 1st run on Friday,tried a bunch of wacky stuff and by the end of the day,I was back to my original start point.FAIL.I go home that night,kind of burnt out for lack of sleep and never woke up the next day until I heard my phone ringing.I was late.FAIL.I should have hit up the HB guys earlier,but didnt.FAIL.Thanks Chris for the pep talk!
Originally Posted by Hebiki View Post
why? you'll just get within 0.1 of the fast lap... pack it up..and go home.
(i heard you did a 17.0 on friday.. but FAILED to show up on sat)
btw.. good to see you again and the rest of the norcal crew.
i failed so bad in RCGT i renamed myself to Ling Hicks.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-29-2009, 08:02 PM   #16416
im sorry i see it on the other page
Old 05-29-2009, 09:59 PM   #16417
lightfoot's Avatar
Default upper deck ?
Does anyone know when the new upper deck will be out ?
I bought a weight tray that slides under the battery, and I can't use it because
I can't fit weight tray and battery in at the same time... Oh my...
lightfoot is offline   Reply With Quote
Old 05-30-2009, 05:05 AM   #16418
-Korey
Thanks for all your help Korey.
Old 05-30-2009, 05:18 AM   #16419
cyclone x's Avatar
Originally Posted by charlie_b View Post
Here is mine with Hiro's set up.
hey charlie is this ur tracks setup
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-30-2009, 06:31 AM   #16420
Congratulations กกก, for the good results, and thank you very much for share your setups, are there a lot of cyclones drivers all the world, listen here and are good ideas for testing at track.
Thanks, again.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 05-30-2009, 07:09 AM   #16421
Trader Rating: 14 (100%+)
Send a message via Yahoo to MKO3jzgte
anyone want my cyclone S? i have no use for it anymore
Associated TC4 CF
Yokomo CGM
Tamiya tt01 x2
Tamiya TA03
MKO3jzgte is offline   Reply With Quote
Old 05-30-2009, 07:22 AM   #16422
Well, I'm back in Bellingham doing the normal school stuff. I'm taking a break from my studies to post up my Reedy Race setup. The car was very easy to drive in the given conditions. Track was pretty high grip, and we were using Jaco Blues.
Front:
Spring: HPI Pro 4 Pink
Oil: Losi 45
Piston: HB 1.1mm 3 hole
Shock position: 3 on tower, 2 on arm
Rebound: Full rebound with no foam
Camber link Position: long, with 2mm under the inner mount.
Camber: 2.5 deg
Toe: 1 deg out
Caster: 4 deg
Toe block: 2.0 deg
Shims under suspension blocks: 1.0mm all around
Swaybar: 1.4mm w/ new style mount, with the screws backed out 3mm
Droop: 9.0mm from the center of the outer hinge pin to the setup board
Ride height: 5mm
Wheelbase: .7mm behind arm, 2mm in front
Rear:
Spring: Silver
Oil: Losi 35wt
Rebound: full without foam
Shock position: 4 on tower, 3 on arm
Camber: 2.5 deg
Camber Link Position: long with 1.5mm under the inner pivot, and 1mm on the outer pivot.
Toe block: 2 deg
Shims under suspension mounts: 1.5mm all around
Swaybar: 1.2mm on new style mount with screws backed out 1mm.
Droop: 8.5mm measured from the outer hinge pin to the setup board.
Ride Height: 5mm
Wheelbase: 2mm in front of arm, .7mm behind it, and 2mm in front of hub, .7mm behind it.
Other:
Front Drive: Ver 3 spool with MIP CVD's
Body: LW Protoform Mazdaspeed 6 mounted a tick forward
Wing: LW wing
Tires: Jaco blue premounts
Sauce: tweak/buggy grip
Motor: Team Trinity Duo 13.5
ESC: LRP SPX
Gearing: 100/40
Hope thats everything! Let me know if you have any questions.
-Korey
Hey Korey, which shims did you use for ackerman?
Old 05-30-2009, 08:52 AM   #16423
mr fit's Avatar
shorten your wheelbase. you might want to use a front diff or a solid front diff. also it depends on what tires you are using ( foam or rubber) try adding more tire traction to the front wheels. also check the camber and toe settings. try starting from the original set up. good luck
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 05-30-2009, 09:18 AM   #16424
jag88's Avatar
Korey, what is the difference between Losi oil and AE oil ? Is the Losi softer given the same weight ?
Thanks.
jag88 is offline   Reply With Quote
Old 05-30-2009, 09:58 AM   #16425
I used 4mm for the ackerman shims.
Losi oil is a bit thicker I think. Hara did a lot of testing on a bunch of different shock oils and he said Losi was the best. That's probably the only reason I use Losi oil now... and it comes in cool colors!
-Korey
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
