Old 05-20-2009, 12:52 PM   #16321
Coldn's Avatar
Send a message via MSN to Coldn
anybody here have some troble with center pulley??
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 05-20-2009, 05:36 PM   #16322
RaceAce701's Avatar
Trader Rating: 84 (99%+)
what type of trouble
i know mine like 2 loose up every so often even with loc tight on it
and i have had my one way pully start to slip but it actualy wore down the lay shaft (that was in the 1st get cyclone im not sure if that has been fixed or not)
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 05-20-2009, 07:46 PM   #16323
rocketabyss's Avatar
Hey,
I'm running a Cyclone S Drift Special Edition. Using a 96t spur with 39t pinion with 2.4375 transmission rate which makes the gear ratios at 6.00.
Got a new motor recently, a 13turn brushed motor..upgraded from my previous 25turn brushed motor.
Will there be any change in the gear ratios because of the increase amount of RPM generated from the new motor? Would it be best to change the spur/pinion size so I dont have to deal with overheating my ESC?
At the moment my ESC maintains about 60 degrees celcius before I installed a cooling fan. Motor maintains about 58-60 degrees celcius with heat sink and fan.
Any advice on the gear size? I would like to maintain a gear ratio of 6.00 with the 13turn brushed motor.
Thanks!
TP RCSC | The Sliders
rocketabyss is offline   Reply With Quote
Old 05-21-2009, 02:01 AM   #16324
adri-13's Avatar
never one way pulley !! only spool! for mode perf...
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 05-21-2009, 07:14 AM   #16325
Coldn's Avatar
its happening with me too.. i think that hb can put a axle and screw to fix the pulley. in Cyclone S the central pulley, is fixed with axle, maybe in TC hb can fixed with axle and screw.. maybe that way. we dont need to put a much lock adesive in screws.
Nanotech 6000mah
Old 05-21-2009, 07:30 AM   #16326
ASM
ASM's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Korey Harbke View Post
Last I checked they were. Should be very very very soon.
-Korey
Will these fit the WCE? Thanks.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-21-2009, 02:31 PM   #16327
TheCoolCanFanMan's Avatar
Hi Coldn;5838251
The best way round the problem of the grub screw coming lose on the centre lay shaft pulley, is to drill 3 more holes in the pulley, and file a flat on the opposite side of the flat that is already on the lay-shaft, so that you can have a grub screw holding either side of the lay-shaft, then if you strip out one of the holes in the pulley, you utilize the other 2 holes to do exactly the same thing, hope this makes sense but don't forget to lock-tight the grub screw.
TCCFM
Oh and another tip, on the purple spur holder, you are told to put 1 grub screw in to hold it onto the lay-shaft, its advisable to put another 1 on top of that 1, that way the 1st 1 don't come undone, as it acts like a locking nut.
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-21-2009, 04:27 PM   #16328
cyclone x's Avatar
Originally Posted by Tabushi View Post
Well guys, first race with the super-hoped-up cyclone for me, short format, 3 x 8 minutes heats in groups, best timing/laps wins :
1st heat - 3rd place overal, great handling but lacks of speed on the main straight.
2nd heat - my batt came loose (first time on strap tape) ... so i abandoned.
3rd heat - was in 2nd place, but i made couple mistakes and ended 6th overal.
It was a great weekend, i won on GT Class and even when i didnt ended good on touring electric, im very very happy with the car, i already put the full graphite parts but the car still its heavier than TC5 or XRAY's.
Im preocupied with the final speed because im already on 3.94 FDR , engine its cool but still lacks just a little of final speed, thats on 13.5 brushless + nimh 6 cells on rubber/asphalt.
Here are couple pics, red car its mine :
Hope to make it better next time ...
cya !!
Pat
what track is that at
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 05-21-2009, 04:32 PM   #16329
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Pardon my ignorance guys...
How many HB Cyclone editions has there been???
Im aware of these ones:
-Normal Edition
-Surikarn Edition
-Andy Moore Edition
-WC Edition
-S Edition
-TC Edition
Anyone heard of a "Black Edition" of the HB Cyclone? When is this edition placed?
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-21-2009, 04:34 PM   #16330
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Questions??
Hi,
Does anyone know what is causing the delay on the Hot Bodies Cyclone TC Kits (67700) being available in the hobby stores
Places like Stormer and Tower have not had a kit for some time. In fact Tower indicated availability as Mid-May, then Late May, and now Mid June
Any ideas
Thanks in advance
cosmo1974 is offline   Reply With Quote
Old 05-21-2009, 05:40 PM   #16331
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
-Normal Edition
-Surikarn Edition
-Andy Moore Edition
-WC Edition
-S Edition
-TC Edition
The Black edition is just the normal one. It was one of the first kits to come out.
mild seven is offline   Reply With Quote
Old 05-21-2009, 05:48 PM   #16332
cyclone x's Avatar
there is also the cyclone tc
Chase Chandler
Old 05-21-2009, 05:52 PM   #16333
tc3 racer sc's Avatar
Originally Posted by cosmo1974 View Post
Hi,
Any ideas
Thanks in advance
igot my cyclone tc from superior hobbies in orlando fl look them up cpl weeks ago
tc3 racer sc is offline   Reply With Quote
Old 05-21-2009, 05:54 PM   #16334
cyclone x's Avatar
also i think rcmart sells them
Chase Chandler
Old 05-21-2009, 06:04 PM   #16335
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Cyclone X,
Im from Chile - Southamerica, and that track its at CACH Club, here is a small video of it, lot of different layouts, one different every race :
http://www.vimeo.com/3536193
That video its from GT Class
cya !
Pat
Tabushi is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
