Hot Bodies Cyclone
Suspended
just wondering id anyone has a setup for the Colosseum in MD running Jaco Blues
Korey, looks like our track is switching over to Jaco blues (we're running Sorex 28 now) for 13.5 TC. Talk is that we're going to lose .2 sec. from the Sorex. What has been your experience ?
Any suggestions on setup changes ?
Carpet.
Thanks.
Carpet.
Thanks.
On asphalt... The team has been working really hard to figure out the Jaco blues. Generally slowing weight transfer a bit... and creating more sidebite seems to be the ultimate goal when using jaco rubber tires.
The team has been trying a lot of things, and the best change I've done is run a little more camber than you would typically run with a Sorex, and soften up the suspension a little bit. I actually kept the same springs I have been running and just layed down the shocks a bit. It seems to just slow weight transfer a bit and with the added camber the car won't just ride on the outer sidewall. You'll probably have to maker a few more adjustments, but those are the 2 main ideas that have helped out.
We have also been playing with the Hara springs as well, as they tend to smooth out the car a ton and make it transfer weight slower. I think most of us have gone back to the linear pro 4 springs though.
If you are running on carpet... I actually thought the Jaco blues were pretty dialed. When the grip comes up they don't make your car feel so tippy.
-Korey
-Korey
-Korey
-Korey
Yea, on capret they seem pretty solid. My good buddy Weylin was commenting how they lasted for a long time as well. I'll still admit... I'm still a sorex fan.
Suspended
How much difference is there between the worlds car and the tc? The last cyclone I had was a surikarn 2 years ago. I had to sell it to raise money when I bought my house.
Snapped another tub chassis'This makes 3-in two weeksas before nothing was hit hard just went over a corner dot.Again it is the exact same spot _buy the rear pulley slot.I have a 9yr old losi xxx-s that has never broken anything besides 1 c-hub(my fault).I am not a novice driver and I went the sport route because I cant fork out the money right now for tc.Love the car but what the heck is going on--anyone else?? by the way it only had a 17.5 in it, so it wasn't overpowered.
Snapped another tub chassis'This makes 3-in two weeksas before nothing was hit hard just went over a corner dot.Again it is the exact same spot _buy the rear pulley slot.I am not a novice driver and I went the sport route because I cant fork out the money right now for tc.Love the car but what the heck is going on--anyone else??
the TC has all the latest updates, frp flexy plate, pro spec diff, new chassis, top deck, new sway bar design, oneway/spool, new towers, no battery tray design, reversible arms, etc.
I think I can live with the worlds car and just put the pro spec diffs in it. I mainly run offroad right now, but wouldnt mind the option to run some tc every now and then.
It has happened to my friends cyclone s as well same spot-I dremmeled off the rear to the pivot holder on the replacement and it still broke in the same spot.these are all new kits less than 3 wks old-Have they changed materials??I am now told by the shop that chassis are back ordered-anyone make a fiberglass version?can't seem to find an aftermarket graphite one in stock anywhere either.I think HB makes one but it's like 70 bucks and no standoffs-May have to go into business
