Old 05-12-2009, 06:16 PM   #16246
JayL's Avatar
Originally Posted by King of B Main View Post
I know when the rear end in my car would step out I tried everything.. Then I saw one of hara set up sheets and he had the bigger spacer in the rear hubs in front and the little spacer in the rear of hub. Hopefully it make sense if not hit me up with a pm.
so shim the rear arms back, longer wheelbase. I will check it out
JayL is offline   Reply With Quote
Old 05-12-2009, 06:23 PM   #16247
EJ20's Avatar
He said the rear HUBS.
EJ20 is offline   Reply With Quote
Old 05-13-2009, 10:20 AM   #16248
JayL's Avatar
ah, duh, space the hubs back
Old 05-13-2009, 11:59 AM   #16249
I'm curious about switching the shims in the hubs around myself and wondering if it will make the rear end of the car follow through with the front any better.
airwoods is offline   Reply With Quote
Old 05-13-2009, 12:03 PM   #16250
JayL's Avatar
will post up after testing
Old 05-13-2009, 12:18 PM   #16251
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
It worked for me and I looked at all the team drivers cars here in SoCal and they are running it that way..
King of B Main is offline   Reply With Quote
Old 05-13-2009, 12:50 PM   #16252
STLNLST's Avatar
Trader Rating: 17 (100%+)
Good luck.
STLNLST is offline   Reply With Quote
Old 05-13-2009, 03:07 PM   #16253
Trader Rating: 28 (100%+)
Ditto....its the way alot of the Team guys are running in thier setups.Works very well.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-13-2009, 03:09 PM   #16254
STLNLST's Avatar
You can still sign up for the Reedy and join some guys in the invite class
Old 05-13-2009, 03:10 PM   #16255
LOL! fook that! I think ABR and Mini should be considering that since they are on such a roll as of late.I am just a washed up backmarker.
Team I'm Over It
Old 05-13-2009, 04:47 PM   #16256
I would think that set-up adding 2mm to the wheelbase would make the car less aggressive and transfer its weight front to back a tad slower which is great for a larger sweeping track and keeping smoother but for short track with lots of hairpin turns 2mm shorter wheelbase should be better as it should be quicker on turn-in and get its weight transfer to the back end faster also.In theory it would be anyways.
Old 05-13-2009, 05:38 PM   #16257
STLNLST's Avatar
Everyone should be thankful that the reedy isn't this weekend. It's showing a high of 101 The jaco's in mod at those temps would be hurting no matter if you're Hara or not
Old 05-13-2009, 11:26 PM   #16258
We are running on a short track with alot of hairpin turns. All were trying to say is try it . If it helps great.
Old 05-13-2009, 11:36 PM   #16259
EJ20's Avatar
Did you ever compare the difference on the wheel base changed between either arms or hubs?
Old 05-14-2009, 12:26 AM   #16260
No, I have only been running the HB car for 3 months. I was given 3 setups sheets one from Hiro,another from Sean W., and Scott B gave me Hara's. All three setups are very close and they all work very well.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
