Old 05-11-2009, 11:00 AM   #16231
jag88's Avatar
Originally Posted by Coldn View Post
verify its diff not this very untied.
Does that answer your question ?
You know what Russ would say, don't you ?
Get a Cyclone ! ;-)
jag88 is offline   Reply With Quote
Old 05-11-2009, 11:09 AM   #16232
xraysteve's Avatar
I am running diffs front and rear. The rear diff is not too tight. I have softened up the rear a lot. I also added more front droop. I am running 17lbs springs in the front and 14lbs in the rear. It seems like the rear is to soft or not rebounding enough. Like the car rolls over in the corner and the front levels out and the rear is still leaning. Does that make any sense
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 05-11-2009, 11:29 AM   #16233
Coldn's Avatar
Send a message via MSN to Coldn
try anti-squat.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 05-11-2009, 09:50 PM   #16234
bigz's Avatar
try anti-squat.
check your shocks. there may be no more rebound.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-12-2009, 12:48 AM   #16235
decibels's Avatar
Rebuild your shocks and try a slightly lighter oil in the rear like 5 to 10 weight less!! and check your roll centres and camber links make sure your rear links are never longer than the front.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 05-12-2009, 05:18 AM   #16236
xraysteve's Avatar
i have never heard that before. i will check my links and shocks. thanks for all the help everyone
Old 05-12-2009, 06:42 AM   #16237
Get a Cyclone ! ;-)
Yea.....Get a Cyclone You know you want one
That I know of your Xray never hooked before ?????
As you know my Cyclone hooked and the only way I could stop it then and still have good steering was to use a heavy sway bar and lighter springs on the front.
We both have changed many things, I'm not sure what I changed that stopped my hook but I don't seem to need the heavy sway bar anymore
One of the things I changed was I now have more ackerman action then I ever had before.
Guys......Could more ackerman stop an on power hook coming out of a turn????
Lazer Guy is offline   Reply With Quote
Old 05-12-2009, 09:12 AM   #16238
xraysteve's Avatar
i was asking for a friend. my xray is great.
Old 05-12-2009, 10:39 AM   #16239
JayL's Avatar
need more rear in-corner grip
already running 3 degree per side toe
have tried every spring/oil combo and droop settings
I'm thinking roll centers, where is the best place to shim to get more roll in the rear?
JayL is offline   Reply With Quote
Old 05-12-2009, 10:41 AM   #16240
TheCoolCanFanMan's Avatar
If you have 4mm Ackerman then reduce it to 2mm it wont be so aggressive turning in, which stops the back from following the front round to quick, you may feel the steering being a bit numb, but it will smooth the car out
TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-12-2009, 11:18 AM   #16241
xraysteve's Avatar
TCCFM
so to turn easiers you want more of a angle or less
Old 05-12-2009, 11:26 AM   #16242
Trader Rating: 28 (100%+)
1.5 under the hinge pin blocks is a good starting place.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-12-2009, 04:43 PM   #16243
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Didnt you used to run a Tamiya? I didnt even notice you had a cyclone last time i was at the track lol!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 05-12-2009, 05:38 PM   #16244
JayL's Avatar
I will always run Tamiya unless huge $$ comes my way
But I work on other people's cars.......
Old 05-12-2009, 05:41 PM   #16245
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
I know when the rear end in my car would step out I tried everything.. Then I saw one of hara set up sheets and he had the bigger spacer in the rear hubs in front and the little spacer in the rear of hub. Hopefully it make sense if not hit me up with a pm.
King of B Main is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
