Old 05-09-2009, 09:32 AM   #16216
I thought of that but the screw head doesn't seem to get to the edge of the out drive. I ll have to check again in better light. Thanks. By the way as far as the tub breaking i cut the back off all the way to the edge of the rear suspension mount. That extra area behind could give a fair amount of leverage on an area that does not have a lot of support. Trust me i stress tested it a lot last weekend and it is still ok
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.0 SR, TLR 22-4 1.875,CRC XTi WC, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 05-09-2009, 10:50 PM   #16217
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Team STPN View Post
Yup see ya tomorrow
I was fast 2day
STLNLST is offline   Reply With Quote
Old 05-09-2009, 10:57 PM   #16218
Team STPN's Avatar
Originally Posted by STLNLST View Post
I was fast 2day
Lucky.....
I you sure everyone else wasn't slow.....
Team STPN is offline   Reply With Quote
Old 05-10-2009, 10:46 AM   #16219
jag88's Avatar
Korey, what is the latest and greatest shock towers we should be using ? I've come up with three different part numbers and don't know what the difference is between them other then one of them is 3.5 mm thick. Front and rear.
Also what is the part number for the shock o-ring we should be using ?
Have you ever tried Tamiya o-rings ?
Thanks.
jag88 is offline   Reply With Quote
Old 05-10-2009, 11:47 AM   #16220
SammyZ's Avatar
Trader Rating: 138 (100%+)
jag-The WCE towers are very nice, lots of shock mounting options! The TC towers are very similiar but if im not mistaken may be a touch (1mm?) taller or shorter than the WCE towers.
Im using HPI #6820 Silicone O-ring with great success, I have been told it is the same silicone O-ring used in the Tamiya TRF dampers, but I will confirm this myself later this week!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-10-2009, 06:21 PM   #16221
STLNLST's Avatar
Lucky.....
I told everyone that when I was done testing motor and speedo's I was going to get the set up dialed
Old 05-10-2009, 07:05 PM   #16222
tc3 racer sc's Avatar
Originally Posted by Jonnydb View Post
hey superior hobbies.com hve them i bought one last week im waiting may get it tomorrow
tc3 racer sc is offline   Reply With Quote
Old 05-10-2009, 10:06 PM   #16223
Korey Harbke's Avatar
Thanks.
There are two sets of shock towers that have the "half-hole" adjustments. Which one you choose just depends on what you are doing, and which upper bulkhead you have on you car.
If running the upper bulkheads with 4 camber link positions that come in every kit other than the Cyclone TC, then you want to use the 61090, and 61091. If you are running on foam tires, HB offers some lowered versions so you can slam your body down more, you'll want to use 61287 and 67705. These towers are 2mm lower.
If you are running a cyclone TC, or you are running the newest upper bulkheads that only have 2 camber link positions, then you want to run 61287 and 67705. The newer upper bulkheads are 2mm taller, so you need to use the lowered shock towers to get the correct geometry. I personally run this combo.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-11-2009, 07:05 AM   #16224
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
thanks man but is out of stock :S
Jonnydb is offline   Reply With Quote
Old 05-11-2009, 07:10 AM   #16225
xraysteve's Avatar
I have a setup question. what are some things you could try to get rid of a hook. I go around the corner and when I get on the gas the car just wants to spin the way I was just turned. It is not really loose. It just wants to keep going in a circle and not straighten up. This is on asphalt.
p.s. dont let lazerguy see this
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 05-11-2009, 08:03 AM   #16226
Coldn's Avatar
Send a message via MSN to Coldn
verify its diff not this very untied.
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 05-11-2009, 08:10 AM   #16227
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Well guys,
Finally ended buying for my already fully upgraded Cyclone S :
- 3Racing CF Chassis
- 3Racing CF shock towers (f/r)
- 3Racing CF Upper Deck
So, in about 2 weeks i will have a fully race ready CF Cyclone "S" ... right now i tested again my "S" tube chassis fully upgraded against couple TC5's at the track (asphalt, 13.5 brushless, nimh 6 cells, rubber tires) and im behind couple of ones and in front of another ones lol !, im a heavy chassis compared to the others, hope to get a little improvement once i install the full CF parts,
thanks for all for now guys, you have been very helpfull people !!, i have a race coming this weekend and i will attend it with tube chassis, hope to get some video of it !!, this is the track layout ! (back straight its about 60 meters long) :
cya !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 05-11-2009, 08:24 AM   #16228
Seems to me weight is not really an issue anymore as eveyone has to run extra anyway, unless you are not runnng Lipo.
Old 05-11-2009, 09:51 AM   #16229
Trader Rating: 16 (100%+)
It sounds like you need to transfer more weight to the rear of the car (barring any mechanical problems). Try letting the front end rise a little more (droop adj). This should allow more weight to the rear of the car on accelleration.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-11-2009, 10:28 AM   #16230
bigz's Avatar
check your shocks or maybe, ur using stiff springs and stabilizers out back.
if all these fails, check your diff.....it may be too tight. please wait 1 second(s) for an uncompressed image, or press Ctrl+F5 for original quality page
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
