Old 05-06-2009, 02:39 PM   #16171
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by linger View Post
Korey - you really should learn not to agree with STLNLST on anything. It's a slippery slope. It will be a matter of time before you show up to the track in a dress.
Sorry - my fingers aren't calibrated enough to differentiate a progressive spring from a linear one, and I don't know what a progressive spring is supposed to feel like on the track. What matters is if the spring works - then it really doesn't matter if it's progressive or linear - unless you are an engineer and you need to know why.
I do know that if you hand a Hara spring over to any engineer - they willl tell you that it's linear. And I bet that if I ever get a change to measure it - they will measure linear.
See.....this type of info will only help you in the rcgt class. No wonder you're not going to win this year You call it failure........I say it's a life experience.
STLNLST is offline   Reply With Quote
Old 05-06-2009, 02:39 PM   #16172
EJ20's Avatar
Originally Posted by bigz View Post
hi, anyone familiar with hara springs ver 1. can't figure out which is the equivalent of the hpi blue and pink springs.
hara springs are in kg while hpi are in lbs.
thanks.
I'cant tell you what exactly LBS. right now since I don't have the chart on hand but I can tell you the HPI Pink is about 18 LBS. and the HPI Blue is about 16 LBS. If you asking about the Hara's, they are totally different things. They start at about 17 LBS down to 13 LBS, but when you try to compress it by your fingers (someone said not suppose to) you will notice it start soft at the beginning and getting stiffer. Compare to HPI's, you could fully compress the Springs all the way. So, you need to try it and see which one is good for.
EJ20 is offline   Reply With Quote
Old 05-06-2009, 02:44 PM   #16173
STLNLST's Avatar
Originally Posted by Korey Harbke View Post
Not trying to step on your toes Ling, but I will agree that the construction of the spring itself is "linear"... The springs still feel as if they are "progressive" on the track. Even Hara himself says that. They are similar to the Xray springs which are just rated with a spring constant rather than a spring rate.
-Korey
You just earned yourself a soda when you get down here. Thanks for having my back against the norcal FAILURE!!!!!
Old 05-06-2009, 02:54 PM   #16174
Trader Rating: 17 (100%+)
I believe he still has more wins than you...heck, Kathy has more wins than you. In fact, she has more wins in the last 3 races than you have in your sedan career! FAILURE!
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-06-2009, 03:07 PM   #16175
linger's Avatar
Originally Posted by KDR View Post
Bigz,
Not sure if this helps you or not, in any event it is a great item to keep in your pit box. See attached.
-Steve
don't you wonder where all those measured spring values came from?
6542 Blue: 273 g/mm, 15.29 lb/in
Measured 14.29, 14.27 - average of 14.28
6543 Silver 302 g/mm, 16.91 lb/in
Measured 16.34, 16.07, average of 16.21
6544 Gold 340 g/mm, 19.04 lb/in
Measured 17.38, 17.60 - average of 17.49
6545 White 363 g/mm, 20.33 lb/in
Measured 20.35, 19.33 - average of 19.84
6546 Yellow 388 g/mm, 21.73 lb/in
Measured 20.27, 20.77 -average of 20.52
6547 Red 400 g/mm, 22.40 lb/in
Measured 20.61, 20.60 - avearge of 20.61
6548 Pink 320 g/mm, 17.92 lb/in
Measured 16.60, 16.88 - average of 16.74
to get from g/mm to lb/in - just multiply by 0.056
Thanks to James Arluck for donating his new HPI spring set to get measured. The measured values do differ from the published values - which is absolutley normal. Also interesting to note that the HPI Yellow and Red practically overlap in values.
The HPI springs are indeed linear. I have the entire force/displacement curves to prove it.
Are you going to borrow money from Tina to buy Korey a soda?
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 05-06-2009, 03:23 PM   #16176
EJ20's Avatar
Thanks Ling for your Info.
Old 05-06-2009, 04:56 PM   #16177
STLNLST's Avatar
That's not true. I have a good handful of wins over the years. You were at a couple of them too She is the fastest Davenport in your household though
Old 05-06-2009, 04:57 PM   #16178
STLNLST's Avatar
I'm going to use the money I saved by switching to Geico
Old 05-06-2009, 05:02 PM   #16179
Team STPN's Avatar
toasty......
As Dr Phil would say...How does that make you feel?/
Sometimes the truth hurts.....
Team STPN is offline   Reply With Quote
Old 05-06-2009, 05:02 PM   #16180
HA! She has gone 3 for 3 in the last 3 weeks. How about you for....let's just say the last 3 years? LOL
She has the most wins, our son has the fastest lap. I'm just old, fat and slow, and I can still beat YOU!
P.S. Don't blame me....blame the HB car we have her driving. She was never this successful with all of the other cars.....
Old 05-06-2009, 05:06 PM   #16181
Team STPN's Avatar
Don't you mean how much the Ol lady saved by by switching to Geico
Old 05-06-2009, 08:58 PM   #16182
bigz's Avatar
Bigz,
-Steve
Hi Steve,
i can't open the file.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-06-2009, 09:05 PM   #16183
bigz's Avatar
that's what i've heard also. so if im using HPI Pink and Blue i can't find a match with the Hara springs since their softer...... have to try each at the track.
Old 05-07-2009, 03:55 AM   #16184
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hi Steve,
you need acrobat reader to view the file
sometimes you might need to save the file to your PC, then try opening it
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-07-2009, 06:31 AM   #16185
Progressive or linear discussions asside, when do you use HPI or Hara springs?
Personally im starting to like the hara springs for long, flowing tracks. I feel it makes the car feel more predictable and smoothes the steering. For twisty tracks i like the HPI springs as it feels more sharp turning in.
What are you thoughts?
Itchy is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
