Old 05-05-2009, 10:40 PM   #16156
bigz's Avatar
Default hara springs
hi, anyone familiar with hara springs ver 1. can't figure out which is the equivalent of the hpi blue and pink springs.
hara springs are in kg while hpi are in lbs.
thanks.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-05-2009, 10:57 PM   #16157
Hello all, I am trying to complete my build and mounted a Tekin Redline in my chassis and it looks like it touches the lower plate. Is this correct or do I need to do something different?
Since this is my first brushless combo with this chassis I dont have anything to compare to. All help and tips are appreciated.
Ron P.
RMP750 is offline   Reply With Quote
Old 05-05-2009, 11:51 PM   #16158
STLNLST's Avatar
Trader Rating: 17 (100%+)
thanks.
If they haven't changed....the Hara springs are progressive and the HPI's are linear. Correct me if I'm wrong. It's sort of like apples to oranges.
STLNLST is offline   Reply With Quote
Old 05-06-2009, 12:32 AM   #16159
linger's Avatar
Hey Failure. That's the problem with the internet. Someone spews out some info and everyone treats it as fact. I keep hearing at the track that the Hara Springs are progressive cause they read it on the internet.
A progressive spring has a non-constant pitch or non-constant diameter. Take a look at your precious Hara spring. It's fixed pitch and fixed diameter. That means it's linear.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 05-06-2009, 12:37 AM   #16160
Korey Harbke's Avatar
Not trying to step on your toes Ling, but I will agree that the construction of the spring itself is "linear"... The springs still feel as if they are "progressive" on the track. Even Hara himself says that. They are similar to the Xray springs which are just rated with a spring constant rather than a spring rate.
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-06-2009, 12:56 AM   #16161
linger's Avatar
Korey - you really should learn not to agree with STLNLST on anything. It's a slippery slope. It will be a matter of time before you show up to the track in a dress.
Sorry - my fingers aren't calibrated enough to differentiate a progressive spring from a linear one, and I don't know what a progressive spring is supposed to feel like on the track. What matters is if the spring works - then it really doesn't matter if it's progressive or linear - unless you are an engineer and you need to know why.
I do know that if you hand a Hara spring over to any engineer - they willl tell you that it's linear. And I bet that if I ever get a change to measure it - they will measure linear.
Old 05-06-2009, 01:17 AM   #16162
LOL too funny. Maybe we should have you measure the hpi pro 4 springs and the hara springs for the heck of it sometime.
-Korey
Old 05-06-2009, 02:20 AM   #16163
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Its funny how you say you know that yet you havnt measured nor handed it to an ME, but yet you still know it as if you already did. Kinda breaking your own argument when you simply could have replaced that funky statement with "i am 100% sure they are linear."
Oh to sit as a neutral party and witness the amazingness that is internet forum posting.
Syber Serulean is offline   Reply With Quote
Old 05-06-2009, 05:04 AM   #16164
bigz's Avatar
thanks.
so, its difficult to compare??
Old 05-06-2009, 08:20 AM   #16165
Hey,
New to the forum.
I currently have a Pro4 and am looking to get a belt car. Are parts still compatible from the older pro4 to a newer cycone (CF race version). It would be nice to be able to use what i have.
Also, have anyone here driven both cars and can say how they compare?
Thanks,
Tom
Pro4
Twism86 is offline   Reply With Quote
Old 05-06-2009, 08:44 AM   #16166
Yes,the Older versions of the Cyclone use the same Arms,C-hubs,Knuckles,bearings,and toe blocks.The cars drive similar,but the cyclone feels more refined.I would say,pull trigger on a getting a cyclone.You wont regret it.
Originally Posted by Twism86 View Post
Hey,
New to the forum.
Thanks,
Tom
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-06-2009, 09:55 AM   #16167
Thanks for the info. I love my pro4, so i bet i would like a cyclone too.
Pro4
Old 05-06-2009, 11:31 AM   #16168
mangoman's Avatar
Compared to the cyclone the pro 4 pushes in corners, which is typical of shaft drive cars. I found that if you are a good driver then the pro 4 can be fast in the spec classes. But generally speaking the handling of the Cyclone is far superior to the Pro 4 (which is also pretty typical of shaft vs belt).
Been a while since i drove my pro 4 though....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 05-06-2009, 12:18 PM   #16169
TheCoolCanFanMan's Avatar
Originally Posted by B18C Turbo View Post
really?!
Its an old LOSI joke everything comes out in 2 weeks when it comes from LOSI
CCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 05-06-2009, 02:46 PM   #16170
KDR
thanks.
Bigz,
Not sure if this helps you or not, in any event it is a great item to keep in your pit box. See attached.
-Steve
Steve B.
HB Team Driver*Sweep Racing Tires*Speed Passion Team Driver
hotbodiesonline.com
KDR is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
