Old 04-29-2009, 11:13 AM   #16081
Trader Rating: 66 (100%+)
Default Which version is best?
I currently run the original cyclone and I am ready to retire it and get another one. My lhs has a morespeed and a hara edition on the wall that I can get a good deal on, but would I be better off with the TC or wait to see if a new car comes out soon? I am running 13.5 rubber tire medium grip carpet, thanks for any help. And will a smc 6000mah 28c lipo fit in a cyclone?
Gwoodrc is offline   Reply With Quote
Old 04-29-2009, 11:19 AM   #16082
SammyZ's Avatar
Trader Rating: 138 (100%+)
hey man i sent you a PM, check!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 04-29-2009, 11:45 AM   #16083
I have basically the same question. Looking to get a cyclone(coming from the pro4). Should I go straight to a TC or should I keep my options open on some of the older cyclones? Because I really want a cyclone. Just not sure which route to go with. Where's the best place to find a used TC??
Lazer Speedway - Every place else is just a parking lot!
www.lazerspeedway.com
RC-DriftNewb is offline   Reply With Quote
Old 04-29-2009, 12:02 PM   #16084
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
you can get a new tc from stormer hobbies for 350.. nuf said
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-29-2009, 12:57 PM   #16085
RC MARKET's Avatar
Best Price !
RC MARKET is offline   Reply With Quote
Old 04-29-2009, 01:08 PM   #16086
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Hello,
Would you use a center one-way with a spool or do you use a center one-way with a one-way in the front??
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 04-29-2009, 06:00 PM   #16087
Trader Rating: 5 (73%+)
Send a message via AIM to illz302
hey guys I just put a Novak Havoc 8.5 brushless system in my Cyclone S RTR and my differentials are slipping is there any company that makes a nice upgraded diff for the car? Or is a gear diff better? If so who makes a gear diff? Sorry for the questions but I am somewhat new to this RC hobby and I have no idea where to look.
illz302 is offline   Reply With Quote
Old 04-29-2009, 07:26 PM   #16088
rx7ttlm's Avatar
tighten the diffs until they stop slipping.. gear diff would be nice for sport / racing when you want repeatable settings.. but not a requirement. if you let them slip to long you will need to rebuild your diffs and start again..
Old 04-29-2009, 07:41 PM   #16089
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Well
Today first test, not track test, just parking lot test near home ... and the car seems very good (remember, a fully upgraded Cyclone S i bought NIB).
The thing is that i geared for 4.8 FDR and the car went reeeeaaaally good (13.5 brushless class, novak SS system with GTB).
Today at a friends store, he installed for me a new rotor, the upgraded one from novak, and we tested the car on the street simulating track behaviour and timing, ans changed the gearing to 4.39 FDR and the car seems to have a lot of power, lots of initial torque and the temp went down a little ...
Any tip/opinion on 13.5 novak racing with the upgraded rotor ?
On the other side, my friends at the store never saw a cyclone before, but comparing to 85% TC5's they see at the track, they told me my car was brick heavy ... its this true about the Cyclone S ?, do i have to go and buy carbon fibre chassis and towers ?, other than that i have it all purple hotbodies parts upgraded ...
thanks,
thanks,
Pat
Tabushi is offline   Reply With Quote
Old 04-29-2009, 08:22 PM   #16090
mangoman's Avatar
Yes the cyclone S is a lot heavier than the regular cyclone.
However, if you are allowed/using LiPos i suspect this will not be an issue....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 04-29-2009, 08:44 PM   #16091
artwork's Avatar
Trader Rating: 59 (100%+)
I am not going to pass judgment, but if you are new to the hobby you should not be running an 8.5 brushless motor. That is a lot of motor even for a seasoned racer. The Cyclone S RTR is not really designed for the labors of modified motors. The Cyclone S RTR is not designed for the high end racing segment. I would offer a couple of suggestions.
1) try a 17.5 or 13.5 motor in your car and really spend some time learning about the car, setup and basics on on-road racing.
2) Move up to the Cyclone TC and take full advantage of a world championship caliber car.
Honestly, I would suggest option 1 and really hone your skills for the future. The more time you put in now learning the basics the better off you will be in the long run. I can bet a large sum of money that you will be faster around the track with a 17.5 motor then with that 8.5.
I guess I did not really answer you question...
There are lots of option parts for this car...you could add a spool to the front and an upgraded diff in the rear.
Check here for some upgrade and option parts.
http://www.hotbodiesonline.com/parts...pe=OPT&lang=en
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 04-29-2009, 08:54 PM   #16092
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Tabushi View Post
Well
thanks,
thanks,
Pat
What do you mean by upgraded rotor? The motors come with 12.3mm rotors which are basically a rpm rotor. The optional 13mm rotor offers more bottom end torque and less rpm. Due to the increased torque the motor can be geared higher to get the rpm back some. The bigger rotor also runs allot cooler than the smaller one. Also....if you start to race your motor will be illegal with the 13mm rotor.
STLNLST is offline   Reply With Quote
Old 04-29-2009, 10:34 PM   #16093
Originally Posted by Ummmm View Post
Hey there, just got myself a cyclone S as the TC's aren't available where I shop I've never ran on road before so I need help.
FYI I plan to run Lipo's on asphalt
1. Gearing for a 17.5 or 13.5 Pinion and Spur pls not just Final drive (Starting point anyway)
2. Basic idea of suspension starting point - springs, oil, piston
3. Sway bars
4. any tips pointers to consider before going racing.
thanks in advance
Can anyone help me out?
Ummmm is offline   Reply With Quote
Old 04-30-2009, 04:42 AM   #16094
Thanks for the help guys. I am not totally new to RC just to the TC end of things especially racing but after driving the car the 8.5 is exactly what I was looking for power wise.
Old 04-30-2009, 10:30 AM   #16095
artwork's Avatar
1. Gearing for a 17.5 or 10.5 Pinion and Spur pls not just Final drive (Starting point anyway)
3. Sway bars
thanks in advance
1) Gearing will depend on track size. for 13.5 try 5.0 FDR. for my TC that would be 100 spur 43 pinion with a 2.167 internal ratio.
2) Gold up front and silver springs in the rear. 45wt oil. pistons#2. 1.5mm under the toe blocks all the way around. 3deg in the rear 1.5 up front (toe blocks)
3) Silver front sway bar copper in the rear.
4) all of this is a guess since I do not know what kind of surface and track size. You can download a setup and try to make changes from their based on track conditions.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
