Old 10-25-2005, 11:04 PM   #1591
nordheim's Avatar
Originally Posted by rc-zombies
this one even better... $375.00 on ebay
http://cgi.ebay.com/Hot-Bodies-Cyclo...QQcmdZViewItem
I got mine from this company. Super fast shipping!!!
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 10-25-2005, 11:15 PM   #1592
Edwin Lee's Avatar
Originally Posted by nordheim
Did anone have trouble with the rear diff during assembly? It seems very sloppy. I took it apart a dozen times and it doesn't seem right. There is too much play in it. I put it together exactly as the instructions stated but I'm about to pull my hair out.
The rest of the assembly went extremely smooth. Anyone out there with ideas about this diff?
I have the same problem and thought that it was a manufactuing defect. However, I think it is a design defect and was meant to be sloppy. Dont worry too much about it as I think it does not affect the car's performance. Just ensure that the diff is tight enough and does not slip.
Edwin Lee is offline   Reply With Quote
Old 10-26-2005, 12:45 AM   #1593
Skill's Avatar
My diff is also "sloppy" but it doesn't seem to affect the performance of the diff or the car, so it shouldn't be a problem, although it doesn't feel too good...
Skill is offline   Reply With Quote
Old 10-26-2005, 01:33 AM   #1594
JonboyGB's Avatar
Mine too is sloppy. Took it to my LHS to get an experienced guys view and he said ďthats sloppy! But wont be a problem to the performance of the carĒ.
He then went on to mention a little tip he had learnít from Andy Moore. Andy has replaced the 2 spacers in the diff (part nos. Z857) with an additional ball bearing - part no. B020. Reckoned this made the diff more stable when running.
Iíve still havenít run my Cyclone so canít say if this makes any difference.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-26-2005, 03:48 AM   #1595
The Belt pulley on the Diff will 'rock' on the large diff balls. This is normal as the belt will pull the diff straight when spinning. However adding the extra ball race as mentioned above does help
crangon is offline   Reply With Quote
Old 10-26-2005, 04:38 AM   #1596
Skill's Avatar
Yea, I've been running my diff with the 2 bearings inside after what RC Zombies said about making it smoother, as said before though I still have slop.
Old 10-26-2005, 04:52 AM   #1597
JonboyGB's Avatar
Does anyone know where to get a locked centre pulley from?
Old 10-26-2005, 05:36 AM   #1598
V12
V12's Avatar
If you canīt get the Cyclone locked centre pulley the one from the TRF415 also will work.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-26-2005, 06:13 AM   #1599
pro4_chris's Avatar
you can get a locked centre pulley from www.apexmodels.com hb70725 £9.99
pro4_chris is offline   Reply With Quote
Old 10-26-2005, 06:13 AM   #1600
JonboyGB's Avatar
cool. cheers V12 and chris.
Old 10-26-2005, 06:53 AM   #1601
Teddy's Avatar
Hi all,
First run with my new Cyclone last sunday.
The car work good also with standard set-up.
But after some run both front driveshaft bend, without crash.
Someone else had this problem?
Steel driveshaft are available ?(also from other brands)
Teddy is offline   Reply With Quote
Old 10-26-2005, 06:58 AM   #1602
Originally Posted by Teddy
Hi all,
Did you use a spool or one way.
No they are not available yet.
I use a spool with titanium racing drive shaft and no problem, no wear.
Hugo is offline   Reply With Quote
Old 10-26-2005, 07:03 AM   #1603
pro4_chris's Avatar
yeah TIR Driveshafts are really light and strong work really well
Old 10-26-2005, 07:05 AM   #1604
Teddy's Avatar
It was with one-way.
Where did you find titanium drive shaft?
Old 10-26-2005, 07:07 AM   #1605
You can buy online:
http://www.titaniumracing.com/
I've ordered directly and they are very good!!!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
