Old 04-22-2009, 09:01 AM   #16006
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by GasGod View Post
The purple nutz are the way to go-tried the black and blue ones- but ouch
We will have nut testing this weekend at Spedworld. I'm looking for a tenth or two I'll see what color the two fastest guys in my area are running. RACENUT/SCOTTY.....what color nuts are you guys using? This question could have gone so wrong. Good thing Advil isn't on the boards yet
STLNLST is offline   Reply With Quote
Old 04-22-2009, 09:38 AM   #16007
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Nuts, Ball Diffs, Shaft drive, lubes...what the hell are you all talking about in these forums?!?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 04-22-2009, 09:52 AM   #16008
Super Moderator
Marcos.J's Avatar
Trader Rating: 151 (100%+)
He needs to lay off the tire sauce
Old 04-22-2009, 10:07 AM   #16009
Korey Harbke's Avatar
I'm pretty sure they do Clint. You should try some plain silver ones. They will reflect UV rays better and prevent distortion and the deterioration of the nut action....
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-22-2009, 11:34 AM   #16010
Trader Rating: 5 (73%+)
Send a message via AIM to illz302
I hope this is in the right area. I am having a clicking noise come from my cyclone and I can't figure it out I have cleaned everything and still get this noise. Has anyone else had this problem?
illz302 is offline   Reply With Quote
Old 04-22-2009, 12:02 PM   #16011
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Finally !!! ... got confirmed from the postal service, my Cyclone its here !!! ... will deliver to my door tomorrow night
cya !
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-22-2009, 12:14 PM   #16012
cya !
Congrats I absolutely love mine. Now to figure out this clicking noise lol
Old 04-22-2009, 12:16 PM   #16013
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
*wondering what tire sauce they are using so I can stay away from it*
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-22-2009, 12:20 PM   #16014
artwork's Avatar
Trader Rating: 56 (100%+)
Have you checked your pullies? Could have something in the teeth. Anything stuck in your spur gear or pinion gear?
Also look at your outer hinge pins and make sure they are in place. Check CVD/Universal joints as well.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 04-22-2009, 12:21 PM   #16015
Check to make sure the ballstuds for the inner camber link mount aren't too long. If they are too long they will dig into the bearing holder for the diffs, and put a lot of stress on the 10x15mm bearings causing some interesting noise.
Other than that... clean your pulleys really good, and make sure the rear brace is on correctly. There is a side with a larger cut out by the layshaft, and that larger cutout goes on the drivers side of the car. If you don't do that it will also put some unwanted stress on bearings in the center layshaft.
Hope that helps!!!
-Korey
Old 04-22-2009, 12:45 PM   #16016
STLNLST's Avatar
That's the Korey type answer I was looking for. I feel faster already
I'm not really sure which sauce is the cause to my random postings On carpet we used paragon and on asphalt we are using tire tweak and buggy grip. If this is what you are currently using be prepared to loose some brain cells
Old 04-22-2009, 03:45 PM   #16017
Nehpets's Avatar
Trader Rating: 23 (100%+)
Originally Posted by DG Designs View Post
why would you want the smaller pulleys?
To make gearing a 3.5 motor a bit easier. I've been told that I need to run an FDR of about 11 to 12 and the 16t pulleys seem to allow for those ratios better than the 18t pulleys.
Maitland Off/On Road Radio Car Club - http://www.morcc.com/
Nehpets is offline   Reply With Quote
Old 04-22-2009, 03:57 PM   #16018
Nehpets's Avatar
Originally Posted by janux View Post
Yep, you will need new ones(they are a bit shorter than TC's ones):
Front - #HB70738 BELT(169T)
Rear - #HB70739 BELT (62T)
Thanks again.
Old 04-22-2009, 06:20 PM   #16019
Trader Rating: 28 (100%+)
I have had Blue Nutz.No good. Purple Nutz too. Not fun....but when My nutz are Black and Knurled,well,it seems things come out alot smoother.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-22-2009, 08:53 PM   #16020
Trader Rating: 34 (97%+)
Send a message via AIM to King of B Main
Check your cvd pins....I had the same noise and it was my cvd pins...
King of B Main is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
