Old 04-19-2009, 09:47 PM   #15946
Trader Rating: 14 (100%+)
Slipper spool seems to be working. Tried in front of the house which is very abrasive blacktop and it does not slip under power, although i can turn the wheels by hand in the car. Now i just have to see how well it holds up! By the way this is the first spool i have ever run, we cant run one ways in the series e are doing for RCGT. what should i expect steering wise? I think i read it will have less turn in than a one way and a diff but more exit steering than a diff? Is this correct? Thats kind if what i have been feeling but its hard to tell with out being on the track.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 04-19-2009, 10:33 PM   #15947
Trader Rating: 66 (100%+)
Default diff screw?
Will the pro-spec diff screw fit in the standard diff and if so is it stronger than the standard diff screw? I would buy a pro-spec diff, but everywhere I looked is out of stock.
Gwoodrc is offline   Reply With Quote
Old 04-19-2009, 10:43 PM   #15948
Scott B's Avatar
Trader Rating: 43 (100%+)
No, the pro-spec diff screw does not fit the 1st gen. diff.
Call Billy at Speedworld, he had 3-4 pro diffs hanging on the wall.
http://www.speedworldraceway.com/Con...tore_Hours.cfm
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 04-19-2009, 10:57 PM   #15949
Thanks, I'll call tuesday as I see there closed on monday.
Old 04-20-2009, 06:09 AM   #15950
tomracing's Avatar
found on the lrp.cc website ronald volker worlds setup:
http://www.lrp.cc/de/service/setup-sheets/?file=2266
but blue rear, RED front spring????
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 04-20-2009, 07:48 AM   #15951
artwork's Avatar
Trader Rating: 60 (100%+)
Looks like Volker took the German Indoor race with what everyone is assuming is the new car. Trying to find better pics, but so far only one.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 04-20-2009, 08:38 AM   #15952
fluxhonda's Avatar
the current set up
a friend was telling me i should mess with the camber settings so i did and it improved the handling a lot using these cheap 35 shore foam tires
and this is the body i use, i don't think it's legal to use in the mod class races?
so i might have to get a legal sedan body
hb|hpi|futaba|team orion|muchmore|smc
fluxhonda is offline   Reply With Quote
Old 04-20-2009, 09:08 AM   #15953
Trader Rating: 28 (100%+)
I have watched the choices of items in which you have chosen over the last couple weeks and was hoping the others who were helping you would point out certain things.You are new to the racing portion of the hobby and your relatively local to me so I thought I would try my hand at helping.If your plan is to do competitive racing,pick yourself up some of the new Speedworld Sorex Premounts as these will be the tire to run at almost any track local to you and they work.From there you will need to find a setup that works.If your ever in the Norcal Hobbies area on a race day,I will personally set your car up for a baseline setup that will work.Pick yourself up a Mazda 6 or Mazda Speed 6 body and you also may consider running the 17.5-13.5 classes before you run Modified sedan.If you plan on just blowing up and down your street at terminal velocity,please feel free to keep your current setup on your car and ignore anything I have said so far either way have fun!
Originally Posted by fluxhonda View Post
the current set up
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 04-20-2009, 09:54 AM   #15954
mac853's Avatar
Questions??
Excuse me, could somebody tell me if is any matter to put LOSI's LCD steering set for the Cyclone?
Make the difference?
Best regards
mac853 is offline   Reply With Quote
Old 04-20-2009, 10:14 AM   #15955
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
hopefully its just a topdeck and chassis change??? lol
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-20-2009, 10:42 AM   #15956
fluxhonda's Avatar
Yes the body and tire change is a must for racing.
I have 3 sets of foams I'm still going to go through before I pick up some 24mm slick premounts.
As for testing... I've been testing the car at a business center parking lot
I don't plan on ever using this car to "blowing up and down your street at terminal velocity"
If I wanted to do that I would have just gotten a RTR and throw in a fast motor in it.
I set up a nice practice track with good turns (business center parking lot)
With that I am able to see how the car reacts and tune the car.
So far I have done about 10 runs and no crashes.
I don't plan on switching to 17.5 to 13.5 anytime soon.
Although 3.5 or "mod" class is advance and fast... I can handle it.
I don't plan on racing at Norcal Hobbies anytime soon.
If it's any track I'll go to it would be Speed World Raceway.
Thanks for the advice
"please feel free to keep your current setup on your car and ignore anything I have said so far"
(keep your head up man!)
Old 04-20-2009, 11:14 AM   #15957
Scott B's Avatar
If you are coming to SWR this weekend, Billy will be out of town but I will be running the shop and getting the track ready for practice. And if you need any help don't hesitate to ask.
Racenut, are you going to run RCGT at the Reedy??
Old 04-20-2009, 11:45 AM   #15958
Good luck.
Team I'm Over It
Old 04-20-2009, 11:49 AM   #15959
He is all yours.
If I run anything it will be 13.5.Although RCGT is a great class for club level stuff,I already see the ringer mentality building for Reedy.Not my thing.
Team I'm Over It
Old 04-20-2009, 11:53 AM   #15960
STLNLST's Avatar
Trader Rating: 21 (100%+)
He is all yours.
What up sucka?
STLNLST is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
